Hi Guy's I have a Century 130 Mig that is giving me issues. The welder acts like the Ground is bad but it does not appear to be the case. Can anyone help me out and tell me how to troubleshoot it.
Thanks
Thanks
S',
I think you need to be more descriptive.
What makes you think it's a bad ground?
How do you have the welder set up?
-wire type
-where it's plugged in
-what polarity the ground and whip are attached to
And anything else you can think of. Remember, we can't see what you can.
Hey also, offering up nudey pics of your sis or free beer will get you faster responses
Ok well the ground thoughts are Basicley just a thought that I had but affter looking closer it appears to be ok. What happens is when I pull the trigger it strikes an arc and just stops? Almost like the ground isn't good. That was why I thought maybe it was the cause. As far the wire and contact tip they are .030
Thanks
Where's the setings on the knobs at?
Have you changed the contact tip?
How old's the liner in the whip?
Does this happen at all voltage and wire speed settings?
Where's the aforementioned beer?
The settings can be anywhere because this makes no difference at all the burn back happens each and every time. I bought the liner last year when I thought that it may have been the issue. Tips have been changed too. I'm a mechanic and have been around this sort of stuff for a long time just never had any issues with them... Welders that is...As far as the bear goes if you square me away I'll take care of you! My boy's are dying to learn how to weld and I think it's time that I teach them so I don't have to fix there stuff forever if you know what I mean....
(4) using a piece of wood put end of wire about 1/2" away
(5) pull trigger, it should push your torch back or the wire will push off the wood. If this does not happen, is the feed motor is running? If not replace motor.
If the motor is running then these are the things to check.
(1) wire drag to tight
(2) wire roller is the wrong one for the wire size
Feed motor is running for sure. How do you tell what size the roller wheel is? What is the best way to set the tension on the break? I looked around on the Net for a manual with no success any idea where to get one? I suppose if I e-mailed Lincoln and asked maybe I might be able to acquire one....
S',
From what you're saying, sounds like the voltage output is stuck on high.
From what I know, this is the output selector, the shunt, or the pc board. i'm not familiar with your 130, and am guessing there really isn't a pc board but I could be wrong.
Have you taken it apart, even though you don't have a manual?
If so, does anything look or smell burned?
Thanks Guy's! I am going to look this manual over and maybe I will be able to find out whats happening? I'll take it apart and see what makes it tick. Wish me luck!
Hey Mechanic I looked at that manual and unfortunately that is for a Lincoln Mig My welder is a 110V Century 130 Md# 117-052 003
If you see anything out there in Cyberspace or anywhere for that matter let me know!
Thanks again!
I know its a Lincoln manual. Lincoln makes Century they are basically the same. Believe me this manual will give you what you need to know as far a adjustments and settings.
Ok well the unit looks completely different and as far as the electronics go I'm not sure. I will check it out and see hopefully I will be able to see what's happening?? If not I will have to write Lincoln to see if they can provide the correct one.
Thanks
I have the manuals Send me your e-mail by private message with the model number 117-052.
and I will send you both manuals.
Bad liners can cause the wire to stop feeding, release trigger move gun around and some time the wire will pop out of the tip a little.
Related Threads
WeldingWeb - Welding Community for pros and enthusiasts
posts
1.8M
members
82K
Since
2003
Community Forum for Welding Professionals and Enthusiasts To Interact and Learn - Free
