troubleshooting maxstar 150 stl
5K views 5 replies 4 participants last post by  enlpck
DISCLAIMER: i am a welding virgin, complete n00b and generally am a kinda slow learner. fyi
i just picked up a used maxstar150stl and decided to see if it works (after i got home). i flipped it on and can get a arc from the stick mode, but nothing from the pos or neg tig settings. i checked and its getting 18v between the pos and neg terminals on the machine, the wiring diagram on the inside cover says thats right, but im not getting any arc at all. here comes the total n00b question: do i need the argon there to get the spark? i dont think i do, electricity is electricity and the argon just keeps atmospheric gases from contaminating the weld. correct me if im wrong. i just dont want to tear it apart to figure out the problem if its just me being a dumass. any way i can test with a multimeter? please help!!
#2 ·
" i dont think i do, electricity is electricity ..."
Well, it USED to be true that electricity was just electricity... But today, with all the lawsuits and regulations and low-cost technology available, you never know how many interlocks and safety features have been added to a machine without (1) a manual, (2) opening it up and looking inside, or (3) asking someone who knows to show you how to set it up.
I don't know anything specific about the Maxstar, but getting a manual and studying it is always the best first step with new (to you) equipment. Miller is very good about providing manuals on just about anything they make or made at:
http://www.millerwelds.com/service/ownersmanuals.php
Have your exact model designation and serial number at hand when you log in.
Another option is to ask your local Miller dealer. He will be annoyed that you went elsewhere for your welder, but he will also want to gain a new customer for consumables and parts. Give it a try.
Have fun with your new toy.
awright
#3 ·
Tough to diagnose without handling the machine, but you do need gas hooked up for proper operation. I don't think the maxstar has a sensor to prevent operation without gas, and the torch may be damaged without argon or helium to help cool it and prevent the tungsten from burning.
As to why you can't get a start, be sure the proper start mode is selected (lift arc, no remote control), be sure the work lead is properly connected to the workpiece, the workpiece is clean, and the leads are in the proper terminals (work lead in the positive, torch lead in the negative.) The lift arc start may not work if the leads are swapped, and you will certainly not like the result at the torch. The lack of gas flow is bad enough, but positive torch puts a lot more heat into the torch than straight polarity.
#6 ·
Glad it's ok. My machine gets loaned out periodically (I have several friends that do site work with engine drives, and when a job comes up where the can't use it (30th floor of an office complex, for example,) I sometimes get a call at 2AM "I'm around the corner. Can borrow your machine? I need to be in the city by 6". First time it came back, I marked one terminal in red paint pen with the word "TORCH". Funny, there are few people I have no problem loaning gear to. Never the planishing hammers. Or the good woodworking tools. But the welding machine? No prob, since I know it will come back working (and it paid for itself in two jobs after I got it, about 4 years ago)
