I found an older Hobart Handler 135 for a friend that can be bought way in the money. The problem I have found with it is the wire feed speed dial will not control the speed of wire coming out of the gun. It flows out at maximum speed regardless where the dial is set.
What could cause this and what kind of fix would be necessary to get this working correctly again, if that is even possible.
Thanks for any insight.
