Looking at building a grizzly for gravel screen out of pipe or tubing.
Does any one know which would have the greatest probability of NOT bending.
3 inch round steel pipe with 1/4 inch wall.
3 inch square steel tubing with 1/4 inch wall - welded inplace on the edge not flat side
2 x 3 inch rectangular steel tube with 1/4 inch wall welded in place on the 2 inch side so 3 inches high
why am I looking at these items? because there is a big difference in price between them and 1 inch thick x 4 inch wide x 8 feet long steel bars.
distance with out support under the tube or pipe is 8 feet; total length of pipe/tube 8 feet
rock and gravel would be slowly dumped onto the bars and gravel would pass through to screen under bars. may be at most one ton on bars at one time.
frame would be 8 feet long and 10 feet wide.
the frame would tip up (hinged on one side to lower screen frame) to clear the rock on top of it that did not slide off on a sloped pitch.
Any comments all appreciated.
