Page 3 of 7 FirstFirst 12345 ... LastLast
Results 51 to 75 of 152
Thread: The bicycle thread
  1. #51
    Jan 2006
    Inkster, Mi
    Re: The bicycle thread
    Hey zank Jody on welding tips and tricks gave you a shout out. Here's the video
    Will Supports Autism Awareness
    My Toys
    BobCat 225 PLus
    Millermatic 130
    Miller Spectrum 300 Cutmate
    Everlast Power Tig 185 Micro
    April is Autism Month .
  2. #52
    Nov 2011
    Figured that you guys will like this. Just finished this earlier today...
    Motorboating...in the Cleavage of the Tetons
  3. #53
    Dec 2009
    Sutton, MA
    Still hot.
    Mark O by Zanconato Custom Cycles, on Flickr
  4. #54
    Dec 2009
    Las Vegas, Nevada, USA
    Mike, As always, gorgeous weld. Nice job.
    That last photo sparks a couple of questions.
    --Do you make an attempt to control the direction of the "stacks of dimes" on the weld? do you go all the way around the joint in the same direction, ending up with the last round 'dime' in the most non-visible location? (((((((((O(((((((((
    --Isn't there enough room in the Anvil jig to weld complete joints, or is that strictly a tack up holding fixture?
    --Zip
  5. #55
    Dec 2009
    Sutton, MA
    Thanks, LB. I do best going clockwise around the joint. I break the joint up into quadrants and do 10:30 to 1:30 and 4:30 to 7:30 first. I do this on the three joints (I leave the BB for last) of the frame. This helps keep the alignment pretty straight. In most cases, it's nearly the same as just tacked. Then I'll do the ears. Basically it pulls to the side you do second. So if I need to pull the DT/HT joint to the drive side, I'll do the non drive side ear first. All that said, each joint will have two stops, and I orient them off-axis at about 10:30 and 4:30.
    I only tack in the fixture. The metal is going to do what it's going to do as it reacts to the heat. So I think it's best to weld it on the bench rather than constrain it in the jig. In terms of access, I could braze a whole joint in the jig, but I couldn't weld one in it. There just isn't enough room or line of sight for me.
    Hope that helps. And I will take some pictures of the beer bottle drill this week.
  6. #56
    Nov 2011
    Wow, those welds are humbling. That is some hand-eye mastery.
    Not nearly in the same league, but this is what I have been up to...
    Here is the beginning of a whole new product line, using cogs tig welded together to create really unique, memorable items. I will be doing a lot with lights, including sconces, outdoor lighting, hotel/restaurant lighting, tea lights, and more. Here is a little taste of much, much more to come. This one can be hung, put on a table, mounted as a sconce, or used to throw incredible shadows. I haven't seen anyone doing exactly this. I will be adding fused and stained glass to the insets, check it out!
    This is hung as a corner light, porch light, or sconce.
    Here is the bottom (for on a table) or top (chandelier)
    And here is a cute little tea light. I will be adding fused glass to the cogs. (it's not totally welded together yet)
    The ladies are gonna dig this one by the bath...
    MUCH more on the way
  7. #57
    Nov 2011
    Glass is next on the 'to learn' list.
    I will be cutting and soldering the fused glass, that's not too hard.
    Right now I am all about figuring out Tig!
  8. #58
    Dec 2009
    Greenville TX
    hi zank, here's some of my wet paint.. a couple of close-ups on fillet brazed frames, if you dont mind me posting in your thread
    thermal arc 252i - millermatic 350P - miller XMT, cp300ts, 30a 22a feeders, buttload of other millers, handfull of lincolns, couple of esabs - Hypertherm 1250 G3
  9. #59
    Nov 2011
    Gary would approve.
  10. #60
    Dec 2009
    Sutton, MA
    Beautiful paint. And please post more. This thread is for everyone!
    rideit, I love the disk rotor. Great touch. All of your stuff looks sweet.
  11. #61
    Oct 2012
    East Van BC
    Nice seat tube cluster! That colour change paint shows it off well.
    SqWave 200
    Millermatic 190
    Airco 200 AC
    Hypertherm PM45
    Boice-Crane Band Saw
    Victor O/A
  12. #62
    Dec 2009
    Sutton, MA
  13. #63
    Nov 2011
    BEAUTIFUL!
    Are you doing a 'sleeve' at the seatpost junction (seperate seat tube) for strength, or manufacture ease? (Matching ideal post size to tube set?)
    I think I see why, but I would love to hear your take?
  14. #64
    Quote Originally Posted by rideit View Post
    Do you weld each chain link to keep the chain like that?
  15. #65
    Nov 2011
    Quote Originally Posted by Hanzelz View Post
    Yup. Little Tig tack, four per 1" link. It's kind of time consuming, but everyone asks about it, so it's pretty unique.
  16. #66
    Apr 2012
    Athens - Greece
    Nice touch on the seat tube zank. I wonder why most manufacturers don't do this (outside from cost and extra work of course but we are talking expensive frames anyway).
    I have seen way too many frames crack in that area
  17. #67
    Dec 2009
    Sutton, MA
    Exactly. I used to epoxy in a composite shim, but have gotten away from that. The welded-in extension serves three purposes.
    1) it allows me to use a 27.2 mm seatpost with a 31.8 mm seat tube. I hate forcing customers into an oddball post size.
    2) it really beefs up that area, especially at the bottom of the slot and relief hole.
    3) it makes doing a repair a lot easier than trying to remove a shim that has been bonded in with 3M DP420.
    And it's only about 25 grams heavier overall. It's more work, but I like it better.
  18. #68
    May 2012
    Fishers, IN
    Nice work. Do you finish your bikes with components?
    If so, do you buy them retail or have you found a wholesaler that will sell to frame builders who do not have a retail store?
    Thanks
  19. #69
    Dec 2009
    Sutton, MA
    As many complete bikes as I can. Yes, the big wholesalers will work with framebuilders, but we have to put together a pretty good case without a store front.
  20. #70
    Jun 2011
    Boise, ID
    Here's a bike I built about 4 years ago. It was a fun little project. Wish I wouldn't have sold it.....
    Miller Dynasty 200
    Millermatic 211
    Instagram?.... find me @ WELD_MEDIC
  21. #71
    Feb 2010
    Do you guys have trouble with the threads after welding. I noticed the welds were close to the crank threads.
  22. #72
    Dec 2009
    Sutton, MA
    I have some bronze heatsinks really cut down on the distortion of the bottom bracket shell, seat tube, and head tube. I can usually still thread a BB in by hand after welding.
  23. #73
    Dec 2009
    Sutton, MA
    Back from powdercoat.
    Aaron B by Zanconato Custom Cycles, on Flickr
  24. #74
    Oct 2012
    East Van BC
    Quote Originally Posted by kevinstj View Post
    Mere mortals have to chase the threads a bit. Nice work Zank
    SqWave 200
    Millermatic 190
    Airco 200 AC
    Hypertherm PM45
    Victor O/A
  25. #75
    Close up please.
Page generated in 1,713,293,506.92993 seconds with 19 queries
