Page 2 of 13 FirstFirst 123412 ... LastLast
Results 26 to 50 of 321
Thread: 1936 SA200 Restoration
    Sep 2010
    Taxxachusetts
    Re: 1936 SA200 Restoration
    There are 5 screws that hold the Main Brush cover in place. The top two screw into angled tabs. These tabs are held in place behind the top bolts for the Welder bracket and exciter frame.
    I tried every possible tool and way I could to access and loosen the bolts. No go.
    I had to strieghten the tabs in order to remove the bolts, not a huge deal as long as they dont crack and break off when I bend them back for reassembly
    14 SA200's from 1936 to 1973
    SA250, Classic 300D she hasnt seen yet...Yes she has
    ESAB Power Cut 1600
    2 LN25 innershield, Mig
    Magnum SG Spool Gun / Control Module
    Tig Module K930
    250/250 round top
    Power Mig 180C
    Sep 2010
    Taxxachusetts
    Now I have a question.
    I have removed the 4 bolts that connect the Welder bracket/exciter frame to the generator frame. The Armeture bearing is inside a "pillow block" that the grease cup is threaded into.
    This "pillow block" is assembled with 4 bolts. You can see 3 of the 4 bolts beyond the exciter coils in the photo. Also the tube from the grease cup is blocking the fourth.
    I installed the puller that i have used to remove the same frame from the armeture shafts on "newer" sa200's. I applied some pressure and got no movement.
    I have no desire to break somthing that I cannot replace because I did not ask for help.
    Do you know what the propper dissasembley method is for this frame removal?
    ATTACH]349111[/ATTACH]
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  3. Likes John Baptist liked this post
  4. #28
    CT
    I've taken on some lost causes in my day, this is quite and undertaking, if you pull it off, and I'm sure you will the reward will be great. What is the earliest version of the SA 200. I mean what year was it first built and what did it have for components?
    "Si Vis Pacem Para Bellum"
    Lincoln Idealarc 250 AC/DC
    Millermatic 251 Syncrowave 300 30A spoolgun
    Lincoln MP210
    Hypertherm 45
    (2) LN 25
    (2) Lincoln Weldanpower 225 CV
    (4) SA200 1 short hood SA250 SAM 400
  5. #29
    May 2012
    texas
    thats just plum cool
  6. Likes John Baptist liked this post
  7. #30
    Aug 2012
    Belmont CA
    Wow that is a crusty dog, good luck with the restoration! Wish I could help but I don't know anything about the old SAs. I wouldn't doubt that after sitting so long lots of pentetrating fluid, heat and force might be needed to get the sucker apart. Don't know about the old engine but I'd bet if you can find parts it is repairable, doesn't look like much going on. Wonder if you could run modern pistons/rings in that sucker.
    Good luck with it and keep us posted.
  8. #31
    Oct 2011
    Elkhorn, WI
    Great Site for more help!
    http://www.smokstak.com/forum/
    Go over here and sign in, then post for engine parts and info!
  9. #32
    Feb 2011
    Near Dallas, TX
    Andex, just wanted to thank you for sharing this project. I love seeing this old stuff brought back to life while making it look almost new.
    Best of luck and keep us posted.
    Papa
    Lincoln Idealarc 250 (circa 1962)
    Lincoln Weldpak 155 w/Mig Kit
    Lincoln Squarewave TIG 175
  10. Likes John Baptist liked this post
  11. #33
    Nov 2012
    cool thread
  12. #34
    May 2010
    Lizella Ga.
    Do you think the notch was a swage to lock the pin in place, creating a lock nut?
  13. #35
    Sep 2010
    Taxxachusetts
    jones2780. I thought the same thing, the pin has a small amount of rotational movment but none lateraly. The notch is very straight and clean as if it were machined. No bulgeing as if it were swaged.
    I recieved some good info from Kaye at Bills Welder Repair on how to propperly disassemble what I will call the, bearing cage, for now and the armeture bearing. I wont have a chance to get back at it until this weekend. More pic's to follow of course.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  14. Likes John Baptist liked this post
  15. #36
    Feb 2013
    I've seen these pin type nut locks on old pump jack (oil field) equipment coming through the shop.
  16. #37
    Dec 2011
    Ted Kennedys Socialist Utopia
    Looks good Paul, Glad to see its getting done.
    Miller Big 40G
    Miller HF-251 D High Freq
    Victor OA
    Lincoln 135 Mig
    MK 3A Cobramatic
    Bridgeport J Head
    Cronatron Oxylance
    Radnor ACAG Torch
    Weldcraft TIG Torches
    1 blown knee and two 5 Gallon pails away from being a hero.
  17. #38
    Feb 2011
    South Plainfield NJ
    thats a anco nut bethlehem steel sold them
  18. Likes John Baptist liked this post
  19. #39
    Sep 2010
    Taxxachusetts
    jcp, Pavinsteelman
    Just did a search on " anco nut " and they are still available.
    Cape Cod Gary
    I parked it front of all the rest and in the way of others. and it worked.
    I will be back at after work tomorrow. Now that Bill and Kaye have given me some good info to dissasemble the " Bearing Cup " I have been itching to get to it.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  20. Likes John Baptist liked this post
  21. #40
    Dec 2012
    Valley City, Ohio
    That is supper cool. Keep the pictures coming.
  22. #41
    May 2012
    Western Pennsylvania
    Andex, I found just the person who can suck those old fuel lines and oil lines clean for you on your restore. Shes been doing it for some time by the looks of it.
  23. #42
    Sep 2010
    Taxxachusetts
    Good evening all, time for a belated update.
    Finally got at today.
    The generator is now removed from the engine.
    It took about 8+ hours to get it done but I did not want to rush into it. I had to run to the auto store and purchase a few items to modify into tooling.
    All came apart without any breakage. I believe all will be reusable with some time, effort and a good dose of patience. Oh yeah and a wad of cash..
    I will be posting the photos with comments.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  24. #43
    Sep 2010
    Taxxachusetts
    A view showing one of four of the bearing cup bolts. long 1/4x20. Dont break it..
    Also note the head of the rocker (rack) screw.
    From inside the exciter housing
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  25. Likes John Baptist liked this post
  26. #44
    Nov 2011
    Wakefield, MA
    wow what a job
  27. #45
    Sep 2010
    Taxxachusetts
    I could not remove the two side bolts from the bearing cup. The excitor coils were in the way. So they had to come out
    This is just to note the size and location should they bag get ripped.
    I bag and tag all hardware as it comes off of the machine. I have always been able to put things back together no matter how long it had been since taking it apart. But I am a liitle older and who knows when it will be back together. Months, years ...?
    Excitor coils and laminations. Still in very good condition.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  28. #46
    Sep 2010
    Taxxachusetts
    Bearing cup bolts and grease cup removed
    A few taps with hammer and drift from the back side and the cup moves forward
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  29. Likes John Baptist liked this post
  30. #47
    Sep 2010
    Taxxachusetts
    Bearing cup removed, finally.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  31. Likes John Baptist liked this post
  32. #48
    Sep 2010
    Taxxachusetts
    Now that thas out of the way what have we here.
    The Armeture bearing nut, retained by a tab over washer.
    I had to dig up a really long handle chisel, found an old rock chisel and ground a new edge on it. the tab was really tight on the nut
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  33. #49
    Sep 2010
    Taxxachusetts
    To remove the Armeture nut I picked up an axle nut socket and a short piece of exhuast pipe. miged the two together and off came the nut ,. the nut is 2 1/4 and the socket is 2 1/2 but it is hex with the corners cut off. I was going to resize it a bit but gave it a try as is and it worked. its deffiinately not pretty and will get some mods before I use it again.
    I twisted up the bent hook and used a magnet to get the washers out. The grease had them stuck together and to the bearing face.
    Here is what came out. Bolts, bearing cup, Armeture nut and washers.
    I think the washers also act as shims.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  34. #50
    Sep 2010
    Taxxachusetts
    Ready to pull
    Not fancy but it's worked every time
    It Moving !!!!!
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
Page generated in 1,632,483,302.45571 seconds with 13 queries
