Page 4 of 13 FirstFirst ... 23456 ... LastLast
Results 76 to 100 of 320
Thread: 1936 SA200 Restoration
  1. #76
    Livingston, MT/Houston, Tx
    Re: 1936 SA200 Restoration
    Man that is nuts looking at the level of corrosion, and looking at what you are doing it actually looks like you are going to get it running again eventually.
    I wonder if you will wind up having to sleeve the cylinders or not to make em right?
  2. #77
    Jan 2012
    east haven, CT
    holy cow! you my friend brought a whole new meaning to "restoration... @andex
  3. #78
    Sep 2010
    Wow. (is an understatement I'm sure).
    I'm impressed. By the looks of the communicators I'd say it'll weld.
    And by looking at your pics I'd say you can make it do just that.
    Good luck on your project man,
    Slowhand
  4. #79
    Sep 2010
    Taxxachusetts
    MinnesotaDave
    I have a "Big Hammer", it wieghs 12lbs and it's name is "Patience"
    Wolf
    I have been looking into a couple of shops in my area that could do a thorough job of any refurbishment that the generator may need. I have sent messages to a few friends in the antique engine world. They are of the of the get it done like it was the first time mind set. The hard part of that is that they dont give to much thought to the cost. Flawless restorations but you could start a college education with the funds.
    MrBeast
    I have delt with worse, but I didnt have to be anywhere near as concerned with not damaging original parts. Replacement parts were readily available and cost less for new than trying to save the old. Also "Patience" got to play, lots of heat and the cutting torch sped things up.
    Sleeves ? As bad as it looks I had a F163 that looked worse than this motor. After a cleaning and a quick hone I was able to use pistons of the same size. I have found a source for pistons. They are aluminium not iron as the originals. Although I have found that it came with either. So it will come down to what size the cylinders will clean up at and what size pistons are available.
    mattyg1405
    Its a passion
    slowhand
    I would say that the total hours on this machine were very very low. I believe it has the original brushes in it.
    14 SA200's from 1936 to 1973
    SA250, Classic 300D she hasnt seen yet...Yes she has
    ESAB Power Cut 1600
    2 LN25 innershield, Mig
    Magnum SG Spool Gun / Control Module
    Tig Module K930
    250/250 round top
    Power Mig 180C
  5. #80
    Sep 2010
    Taxxachusetts
    In between Easter activities I was able to get it little bit more done.
    I just had to get the valves out if it would let me. And it did but there was a bit of resistence.
    When I compressed the valve springs the locks didnt seperate from the retainers. So it was time to Adapt Overcome and Improvise. The paw on the crowbar had just the rite spread so I could lift the retainer and give the valve a good wrap with the deadblow hammer and presto the two were seperated.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  6. #81
    Sep 2010
    Taxxachusetts
    Now I could compress the spring
    and coax the locks out with the magnet
    All 8 valves are out and all the parts are salvageable if replacements cant be found
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  7. #82
    Sep 2010
    Taxxachusetts
    TDC mark centered over a bolt hole
    Front of flange, not keyed or Pinned
    Rear, #1 was just past TDC and both valves were closed, Looks like I will reference #1 to TDC before reinstalling the flange
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  8. #83
    Sep 2010
    Taxxachusetts
    Rear seal retainer. It does bolt to the lower crankcase.
    Backside of retainer
    Seal removed, I was a little surprised to see that much rust on the oil slinger.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  9. #84
    Sep 2010
    Taxxachusetts
    And its seperated
    In this photo you can see the other hidden pin below the Magneto bracket.
    and thats it til......
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  10. #85
    CT
    Friend of mine was cleaning out the garage, said you like to mess around with flathead side valve engines, here!
    [ATTACH]359021[/ATTACH
    For reaching in and compressing the valves, bet Andex would have to have quite a squeeze to free up those valves on his 36. I just picked up my first short hood , will post later.
    "Si Vis Pacem Para Bellum"
    Lincoln Idealarc 250 AC/DC
    Millermatic 251 Syncrowave 300 30A spoolgun
    Lincoln MP210
    Hypertherm 45
    (2) LN 25
    (2) Lincoln Weldanpower 225 CV
    (4) SA200 1 short hood SA250 SAM 400
  11. #86
    May 2010
    Lizella Ga.
    Did you put that dab of white paint on the end of the crankshaft? Looks to line up with the timing mark.
  12. #87
    Sep 2010
    Taxxachusetts
    kolot
    That looks like one of the tools my dentist used to pull my tooth, then used it on my wallet to help fund his sons college education... Actualy I had a version of these years ago that I used on mower motors. Hmm they might be somewhere in the garage.
    jones6780
    I did put the dab of white there for reference in the photos. The crank flange had no mark to reference it to the crank.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  13. #88
    May 2008
    Orange, TX
    Not sure if those particular bushings are available but Lord is still alive and well.
    http://www.lord.com/products-and-sol...l-bushings.xml
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  14. #89
    Sep 2012
    Saskatchewan Canada
    Quote Originally Posted by andex View Post
    I read somewhere that springs should not be blasted,supposed to harden them and make brittle.Just in case new ones aren't available.Just a thought...
  15. #90
    Sep 2010
    Taxxachusetts
    7A749
    duaneb55
    I spent a few minutes at the website. I have not measured the pins or bores bu I dont believe they will be anything strange. Should be able to match somthing up once I find a good parts reference from them.
    57 Long Hood
    Could be true. There can be a bit of heat generated from the blast media.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  16. #91
    Sep 2010
    Taxxachusetts
    Got a bit more done on the engine Sunday afternoon and tonight.
    I was able to locate an original Waukesha service manual.
    although it was printed 22 years after this motor was made.
    I looked at what it had to say about removing the Governor.
    It doesnt go into great detail or get very complicated or even refer to Fig. #, but it does say " Remove Governor"
    So lets start there.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  17. #92
    Sep 2010
    Taxxachusetts
    Ok remove the upper and lower mounting bolts. Still tight to the cover.
    Lets remove the cover.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  18. #93
    Sep 2010
    Taxxachusetts
    A few bolt and the front pulley.
    More shims, behind the nut
    The pulley was snug to the shaft but I was able to pull off by hand
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  19. #94
    Sep 2010
    Taxxachusetts
    One more item first.
    The Magneto Bracket bolts into the front cover. Oh but wait,
    first the mag has to be removed from the bracket
    to access on of the bracket bolts.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  20. #95
    Sep 2010
    Taxxachusetts
    So three bolts and two tapered pins and the mag bracket comes off.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  21. #96
    Sep 2010
    Taxxachusetts
    Inside the front cover..caked with sludge and a coating of rust.
    Why change the oil when all you neeed to do is add some? The good is the sludge protects what under it. The bad will be seen later.
    OH MY!
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  22. #97
    Sep 2010
    Taxxachusetts
    So what was it that we were doing? Oh yes, remove governor. Hmmm.
    The Governor drive gear is held on by a taper pin and of course we are looking at the fat end. But what is holding the Governor to the plate? cant see it yet.
    Cam bolt and indexer.
    Idler gear, watch out, another shim.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  23. #98
    Sep 2010
    Taxxachusetts
    This old rack is working out way better than I ever thought of originally. To think I aved it from the scrap man many a year ago.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  24. #99
    Sep 2010
    Taxxachusetts
    Are we ready to look inside?
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  25. #100
    Sep 2010
    Taxxachusetts
    This is the first rod bearing to come out. Original....
    Notice how all the bearing journals have a black discoloration. This is a sign of old engine oil that has become acidic. The acidity starts to eat at the babbit in the bearings. Also note the original shims are still intact.
    This is the first sign of engine failure. #1 rod bearing had spun in the rod.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
Page generated in 1,624,260,557.90309 seconds with 12 queries
