Page 5 of 13 FirstFirst ... 34567 ... LastLast
Results 101 to 125 of 320
Thread: 1936 SA200 Restoration
  1. #101
    Sep 2010
    Taxxachusetts
    Re: 1936 SA200 Restoration
    Another step in the rite direction. The crankshaft is out. It took a little finagleing to get the herringbone drive gear to unmesh from its frozen mates
    Ah!! room to work. The block still has a grip on the oil pump shaft.
    14 SA200's from 1936 to 1973
    SA250, Classic 300D she hasnt seen yet...Yes she has
    ESAB Power Cut 1600
    2 LN25 innershield, Mig
    Magnum SG Spool Gun / Control Module
    Tig Module K930
    250/250 round top
    Power Mig 180C
  2. #102
    Sep 2010
    Taxxachusetts
    It time push .. breathe...... push
    and it's #1
    Take a deep breath and push again... #3
    Breath, breath, breath .... push... #4
    Oh but wait #2 isn't ready... We will just have to wait a little longer...
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  3. #103
    Dec 2012
    Denison TX
    Looks like someone used it as a boat anchor
  4. #104
    CT
    looks like some of those parts are candidates for the electrolytic rust removal , I have been fooling with this lately and it works pretty good.Little investment and it's passive, you dump it into the solution and let it do the work while you do other things, sleep, go on vacation, whatever.
    "Si Vis Pacem Para Bellum"
    Lincoln Idealarc 250 AC/DC
    Millermatic 251 Syncrowave 300 30A spoolgun
    Lincoln MP210
    Hypertherm 45
    (2) LN 25
    (2) Lincoln Weldanpower 225 CV
    (4) SA200 1 short hood SA250 SAM 400
  5. #105
    Houston, TX
    Sure hope this works out well. Does Waukesha still list engine parts?
  6. #106
    city of Four Flags
    You Sir are a brave soul......this is an epic project and you are making good progress.
  7. #107
    Oct 2008
    Delaware, USA
    You sir have the patience of a saint! In fact, if you get this thing working, it'll be a miracle... we'll have to write the pope!
    I'm willing to bet if you have issues with the coils or any of the electrical bits a motor rewinding shop can help you out. Wouldn't be cheap but it'd be worth it.
    I second the electrolysis Idea. [ame=http://www.youtube.com/watch?v=gsBEv8HdvDI]Check out this youtube vid.[/ame]
    Lincoln Weldanpower CC/CV engine drive
    Lincoln LN-25 wire feeder
    Miller Syncrowave 180 SD
    Various oxy-fuel setups featuring Victor, Harris, and Prest-o-lite products
  8. #108
    Sep 2010
    Taxxachusetts
    jamesyarbrough
    Almost an anchor yes. Just filled from the inside out rather than from the outside in.
    kolot
    I have been considering the electrolysis treatment for awhile myself. I just havenít taken the time to give it a test run. Of course I could not start out with a 5 gal bucket and some smaller less valuable pieces. Oh no, I was thinking more on the lines of a plastic 55 gal bucket etc..... I can see it now, "whatís that mess in the tub" Donít worry honey the hydrogen will float away and not bother a thing.
    vwguy3, moya034
    Thanks for the kind words of encouragement and suggestions.
    The Pope, Some may think I need a blessing to keep out of the nut house. And like all things restored the miracle is maintaining the patience and perseverance to complete the task. The two most expensive items are Time and Money. Both of which I have to budget wisely in order to get it done.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  9. #109
    Sep 2010
    Taxxachusetts
    Sunday I was able to return and actually complete the motor disassembley.
    There were only a few things left to free from the grip of corrosion.
    1 piston, oil pump, camshaft, idler gear and to find whatever is holding the governor in place.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  10. #110
    Sep 2010
    Taxxachusetts
    it took a lot of scraping rust, wire brushing and tapping back and forth but #2 is finally free to join the rest of the quadrupletís.
    It did leave behind the worst pitting in the cylinder wall. Rite at the bottom of the stroke where the rings will stop.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  11. #111
    Sep 2010
    Taxxachusetts
    Again more tapping with the little ball peen hammer and the oil pump is free. Now that it's free of the cam it still spins.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  12. #112
    May 2010
    Lizella Ga.
    The cam looks pretty bad off. What will you do about that?
  13. #113
    Sep 2010
    Taxxachusetts
    The Waukesha manual states to remove the camshaft, remove the cam retainer bolts and slide the camshaft out of the block. This is not that difficult when the cam is free and will rotate so that you can access the bolts. But the cam is locked in tighter than a .. so I figured I would pull the gear and get at the bolts. The first attempt showed me that there is very little on the gear to get a hold on and I had great misgivings about the gear cracking or chipping. So I did everything but apply heat as I did not want to melt the bearings. Alas to no avail. It was time to go for broke and pull the gear. It really didn't want to come off but finally did.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  14. #114
    Sep 2010
    Taxxachusetts
    After a littile clean up things are looking a little healthier. There's the bolts
    Bolts and retainer removed
    It took a lot of effort but the cam finnaly was free
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  15. #115
    Sep 2010
    Taxxachusetts
    The governor is free. No extra bolts or pins. it was just a tight fit to the front plate and some corrosion holding it in place. Lucky it didnt get jarred free and land on the ground in pieces.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  16. #116
    Sep 2010
    Taxxachusetts
    The Idler gear, again the manual says to remove the bolt and slide it off of the stub shaft. Of course the the bronze bushing isn't spinning on the shaft so I removed the stub shaft with gear.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  17. #117
    Sep 2010
    Taxxachusetts
    Next was the front plate. Nothing fancy just three bolts and a dowel pin.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  18. #118
    Sep 2010
    Taxxachusetts
    Oil pressure relief spring removal. It took a lot of carefull digging to free the spring and checkball. The check ball was really difficult.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  19. #119
    Sep 2010
    Taxxachusetts
    except for plugs it's Bare.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  20. #120
    Sep 2010
    Taxxachusetts
    Quote Originally Posted by jones6780 View Post
    Like all the iron in this motor it looks rough but will probably polish up quite nicely.
    As this is a low rpm motor a few thou off the lift of the cam wont be noticed. This motor was used in a lot of different applications and I am sure that there is a cam out there for it. Will the cam profiles be the same ? But it wouldnt be the first to be sent out and reground.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  21. #121
    Sep 2010
    Taxxachusetts
    Now its time to consider the next phase of this quest.
    Acquiring all the known needed parts for reconditioning. From whom? and for How much?
    The generator appears to be in amazingly good condition for its 77 years of age. But now is time to test it out and consider what should be done to it for its next 77 years. Originality being of prime concern. I can do the basic ohm / continuity tests but what should the values be? This is a little outside my comfort zone and assistance will be needed from those that do have the knowledge.
    The Motor is in my comfort zone. There is little that cannot be sleeved bushed or replaced if need be.
    But again finding all the needed items is probably going to absorb a lot of time and money. There are a lot of paper thin gaskets between all the surfaces of this motor and some may be quite peculiar to this application.
    ESAB Power Cut 1600
    Tig Module K930
    250/250 round top
    Power Mig 180C
  22. #122
    Feb 2013
    Now that's what I learned as ' torn down to parade rest'.
    This is one of the best threads of restoration I've come across......please keep us posted.
  23. #123
    Oklahoma Indian Land
    Your idea of the 55 gal drum for rust removal is right move.
    Maybe we need to start a needy fund to help out with the cost of this, at least that way you won't have to mortgage the house.
    It is a real treat and thrill to look at this each day to see the progress and just how bad this engine condition is. I am amazed at the condition of this engine internally.
  24. #124
    Jul 2009
    Friona, Texas (Rhea)
    Really love seeing this project on there and the info you are providing on history as well !! Those engine covers with "Shield Arc" are my favorite. You need to gold plate those or something lol.
  25. #125
    Sep 2012
    Saskatchewan Canada
    Thumbs up Re: 1936 SA200 Restoration
    Quote Originally Posted by Fixalinc View Post
    Those things are great!Chrome the heck out it!
Page generated in 1,624,262,025.53727 seconds with 12 queries
