Results 1 to 20 of 20
Thread: Radiator welding
    Dec 2005
    Sacramento
    Radiator welding
    Ok guys I got one for you. I have been doing a couple custom radiators for some motor swaps. When using all new parts they weld awesome. On the other hand if anything as had coolant in it it weld ok until the very end and it develops a pin hole that will not close. I clean all the parts with Scotch Brite and wipe them down with acetone before welding, but that last little bit won't close up. The only way I have been able to finish the jobs is to drill out the pin hole with a 1/16" bit and weld it then.
    Am I missing anything or is this my best method?
    "If you live in Sacramento you have seen my work."
    Laredo, Tx
    Re: Radiator welding
    what welding process are you using? pertinent information maybe?
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    Feb 2011
    Martinez CA
    It's called "OUT GASSING" caused by pressure build up from oil or some other combustible.....Clean it out better
    and vent it......Race car and bike frames are bad about this and that's why you see 1/8" vent holes in roll cages
    You can vent the tank and come back after it cools and weld up the vent hole.I would think just leaving the cap off would be enough, probably not clean inside.....
    Miller Dynasty 350
    Twenty Six Hammers
    Three Crow Bars
    Big Rock
    Jan 2006
    In A Nice Comfy Chair
    Quote Originally Posted by B_C View Post
    Why would a radiator without the cap or the hoses on it need a vent hole??
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    May 2012
    Western Pennsylvania
    A friend of mine used to have a radiator repair shop and he used an acid of some kind to clean the places he was ready to solder up first. He even wore a special respirator when doing the cleaning. I do not know what the acid was but I am guessing with some Web searching you will find out. I did a small search and came up with Castrol Super Clean that they use today to clean brass & copper radiators before soldering them up. Clean it down 1" to bare metal all around the soldering area before soldering it up.
    Feb 2011
    Martinez CA
    ...zap!
    as usual you didnt read my whole reply......it said it was probably not clean
    Miller Dynasty 350
    Twenty Six Hammers
    Three Crow Bars
    Big Rock
    May 2012
    I have that what you call out gassing and boy does it piss the wife off.
    Jan 2006
    Oh I read the whole reply but @ 5 AM the brain was not functioning in sync with the engagement of the typing fingers...
    My mistake.
    Carry on.
    ...zap!
    Do not attempt.
    Sep 2010
    China
    My mistake.
    Carry on.
    ...zap!
    Sounds like someone needed their coffee.
    Miller Maxstar 200 SD
    Piperliner #10 Gold
    Jan 2006
    Quote Originally Posted by smilexelectric View Post
    I had just got it and it was WAY too hot to drink..
    ...zap!
    Do not attempt.
    Sep 2010
    China
    ...zap!
    You need some of this stuff, it rocks. Though it does have a fair bit of sugar and I like my coffee dark. Ill take any type of coffee I have had some pretty nasty stuff before so it doesn't bother me.
    Piperliner #10 Gold
    Feb 2011
    Martinez CA
    My mistake.
    Carry on.
    ...zap!
    I still like you .........:{
    Miller Dynasty 350
    Twenty Six Hammers
    Three Crow Bars
    Big Rock
    Feb 2011
    Alberta, Canada
    Quote Originally Posted by Inkydoggy View Post
    Muriatic Acid?
    Leo
    Apr 2009
    La / Ga
    On alum tanks if we run into this we take a center punch and hit the pin hole and close it , then finish the weld off. Might be worth giving it a try .
    Feb 2011
    Martinez CA
    Or wait till it cools.....
    Miller Dynasty 350
    Twenty Six Hammers
    Three Crow Bars
    Big Rock
    May 2010
    laguna niguel, Ca USA
    soldered up a radiator last week it was wirewheel clean flux heat wirewheel clean add more flux wirewheel clean till all the crap was gone then flux it up and lay in the solder and call it a day
    Miller Xmt 350
    Lincoln Ln-25
    Ahp 200x
    Smith Gas Mixer AR/H
    Tig is my Kung Fu
    Throwing down dimes and weaving about
    Instagram http://instagram.com/weldor_wes
    WeldorWes@WcWeldingLLC.com
    Feb 2011
    Martinez CA
    Quote Originally Posted by WookieWelding View Post
    Aluminum Tig..........
    Miller Dynasty 350
    Twenty Six Hammers
    Three Crow Bars
    Big Rock
    May 2010
    Did not see where material was specified
    but now rereading the OP
    I would assume it was aluminum cause most do not weld up copper
    but still does not state the Material being welding in the OPs post
    Miller Xmt 350
    Lincoln Ln-25
    Ahp 200x
    Tig is my Kung Fu
    Feb 2011
    Martinez CA
    Yeah I noticed that also but the largest majority of Custom radiators are Aluminum
    not saying that ALL custom radiators are but the issue he described was typical of
    an aluminum radiator that is out gassing ......
    Miller Dynasty 350
    Twenty Six Hammers
    Three Crow Bars
    Big Rock
    Dec 2005
    Sacramento
    Sorry guys. It is a brand new Griffin aluminum radiator. Tig process, Miller Dynasty. I believe I was running about 80 amps with 3/32" Lanthanated Tungsten, AC set at 70.
    The caps and hoses were off. Mostly it welded perfect, until the last little hole opened up and just would not fill. It was tiny, only single drops would come out under pressure. I drilled it with a 1/16" and welded it up one shot.
Page generated in 1,628,127,558.19668 seconds with 11 queries
