Miller diversion 165
13K views 30 replies 11 participants last post by  rwells173
I ve been looking for a decent priced ac/dc tig welder. I found a brand new diversion 165 online for about 1200.00 bucks. Anybody got any experience with this welder? I wanna get my feet wet with some aloooooooooooominum welding. Is this welder the ticket?..............Thanks for the help Rich
#3 ·
I have had a Diversion since October. It suits my hobby needs perfectly. I've found that it welds aluminum quite well, but keep in mind that I am the opposite of an expert!
#5 ·
I used one at miller, great little welder. Its about exactly what a Tig welder should be for a guy wanting to fabricate from about 1/4" and under. Its probably really at home doing 3/16 and under though, but with pre-heating even castings should be doable.
#14 ·
be careful on how thick of aluminum you want to weld with the diversion. The new weldcaraft torch that is wired in is only good for 100 amps AC and is not interchangeable on that welder. It is also a pretty big ticket torch because the controls are integral to the handle.
#16 ·
I saw that the handle controls the amps. I don t know if i like that. I think i would like a foot pedal better. I dunno. I guess its something i would have to try.
#23 ·
Yes, it's an inverter.
165 amps maximum.
About $1200
You're on the internets.
You're off your meds again.
#21 ·
Yep,
Perfect candidate for a Miller Diversion 165.
Doesn't want to expend the effort to download the spec sheet and "read" the machine capabilities.
Already has visions of using the machine for material it was never designed to do.
Hasn't downloaded or requested a copy of Miller's 2009 catalog. Clearly states that a foot pedal option (RFCS-RJ45 Foot Pedal #300 432) is available.
Machine comes with a set-up and operation DVD. That's great. Won't even have to read the owners manual. Also allows unlimited questions on the Miller welding forum.
And, the final kicker, the machine comes complete with a book, "Tig Welding for Dummies with content by Miller". With this exhaustive reference, no additional study of the tig process will be required.
