Page 3 of 7 FirstFirst 12345 ... LastLast
Results 51 to 75 of 155
Thread: sa200 1979 f163 connecting rods
  1. #51
    Feb 2013
    Northern NJ
    Re: sa200 1979 f163 connecting rods
    Kits arriving today. Going start peicing the block together today. I'll post some pics of progress as they occur
    They call me ... youtube
    1979 SA 200 RED seal w/ wp26
    RealGear Mig 140
    Linde AC 250 Amp Stick
    Lincoln AC/DC 225 buzz box w/ #9 flex scratch start Smith precision tig flowmeter
  2. #52
    Feb 2013
    Northern NJ
    So I got my kit. Didn't send me my gaskets though In the meantime i put the cam shaft bearings in and put the cam in, and the gear with the cam plate. Cam is all locked up though. I did lubricate before i assembled. Going to take the cam out tomorrow and see if i half to ream a bearing. Sound like a bad idea? Pistons look good though. The piston pin has a tenth or so play and it just glides in and out. fits the cylinder good too.
    RealGear Mig 140
  3. #53
    May 2008
    Orange, TX
    I trust you know the engine block-to-front cover plate gets installed before the cam gear but seeing as you didn't get the gasket set it's kind of hard to do so.
    On the cam locking up, if the cam went in the block without trouble before installing the gear, my guess is you didn't use the correct thin head bolts to hold the cam retainer plate. The cam gear will contact standard size bolt heads prevent it from turning.Name:  100_0758a.jpg
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  4. #54
    Feb 2013
    Northern NJ
    I did use the correct screws. I should of gotten the hint when I started turning the cam but and the shaft didn't want to turn. I'll take it out and check for burrs in the bearings and hope for the best. Seems I can't do much more then put the valves in til I get my gaskets. Going to order cranks this paycheck too
    RealGear Mig 140
  5. #55
    Feb 2013
    Northern NJ
    I got the gaskets today. Reamed out the bearings but the gear side one is still giving me problems. Is there suppose to be a bearing between the gear and the cam plate or plate and block.
    RealGear Mig 140
  6. #56
    May 2008
    Orange, TX
    Nope. No other bearing between cam and thrust plate or plate and gear.
    Are you sure the cam is binding at the gear end bearing? Could be a spot at the rear or center bearing just as the cam reaches running position.
    Also check to make sure the thrust plate isn't distorted or burred causing the binding.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  7. #57
    Feb 2013
    Northern NJ
    The thrust plate isn't on. I'm 100% on that bearing. I revered the cam so only would touch the one bearing and it's hard to turn Only had like 10 minutes to work on it today
    RealGear Mig 140
  8. #58
    May 2008
    Orange, TX
    Then you should be able to see a shiny spot or spots on the bearing that's evidence of the binding.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  9. #59
    Feb 2013
    Northern NJ
    I don't see any. But it got a little easier to turn. Still takes 2 hands on the gear Using a honer now. Little more and it should be good I hope
    RealGear Mig 140
  10. #60
    Feb 2013
    Northern NJ
    I got it to spin really good until it sits flush when the cam plate goes on. Not sure what gasket goes on that plate u mentioned
    RealGear Mig 140
  11. #61
    May 2008
    Orange, TX
    No gasket on the cam thrust plate (plate with two bolts) and the block-to-front cover adapter plate gets a gasket that should have come in the gasket kit you received yesterday. However, the adapter plate wouldn't have any effect on the cam.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  12. #62
    Feb 2013
    Northern NJ
    I did not get a gasket for the timing cover. And I'm sure silicon sealant won't cut it. On the other end of the cam gets a plug of some sort? Or the round fabric like gasket blocked off by the motor plate
    RealGear Mig 140
  13. #63
    May 2008
    Orange, TX
    The cam bearing bore on the other end of the block gets a welch type plug (kind of like a soft plug) and if the kit didn't include a "timing cover set", you'll need to get one. Fel Pro part number TCS5418.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  14. #64
    Feb 2013
    Northern NJ
    I'm going to call the kit supplier and figure out what happen to the one i bought. It was a Full gasket set. Apparently not full when they shipped it. Right above cam hole (gen side) theres a hole that goes into the engine block water jacket. Would this be for a sensor or a plug. I want to put a oil pressure, water temp gauge in and was wondering if i could use that hole for a temp gauge switch. I'm ordering connecting rods tomorrow, f226d400 to match my 50/50 tang bearing set. Then I'll have to find a new caliper to measure the bushing i need.
    RealGear Mig 140
  15. #65
    May 2008
    Orange, TX
    Here's where the water temperature gauge sensor goes. In the cylinder head.Name:  100_1687.jpg
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  16. #66
    Feb 2013
    Northern NJ
    Ok. Then I got a bit of research to figure out what goes in there. Today gonna get some more work on timing gears and work on cam shaft and valves tappers ect
    RealGear Mig 140
  17. #67
    Feb 2013
    Northern NJ
    Got the crank in. And a plug for the water jacket Gotta get a plug for the cam Ordered rods. Gotta pickup some main cap bolts. Grade. 8. Ss Getting heavy fast. Going to be fun to put into place. Going to silicon seal that cover on by the timing gaskets
    RealGear Mig 140
  18. #68
    May 2008
    Orange, TX
    Are you saying you're not going to use adapter plate and timing gear housing gaskets but rather just use a silicone sealer?
    Do you have the screen that goes over that oil pump pick-up?
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  19. #69
    Feb 2013
    Northern NJ
    Red face Re: sa200 1979 f163 connecting rods
    No no no. I'm using sealant between adapter plate and block and buy the timing gasket. And I do have the screen. Took it off to clean up the oil pump before I put it in for good. I got the seal and rear sealer block in. Motor plate on and almost ready enough to attach to the generator so it stops looking like a locomotive and I can start doing some wiring and put lifters gov carb starter back in. Still don't have the voltage reg for the alternator or a gas tank. Also gonna need oil and air filter kit. Plugs. Probably missing a few things off the top of my head. Have it written down
    RealGear Mig 140
  20. #70
    May 2008
    Orange, TX
    That timing cover set I listed has the adapter plate-to-block gasket in it.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  21. #71
    Feb 2013
    Northern NJ
    I got the motor mounted to the generator now. Going to get the gasket for the timing cover at napa tomorrow. trying to get the valves installed. Going to have to make up a tool to compress the springs. My two spring compressors wont work (ment for ohv). Then I'm gonna clean up the oil filter put her in, along with the govnr, alternator and water pump. All of a sudden its starting to look like something. not to mention how much less cluttered the floor is.
    RealGear Mig 140
  22. #72
    Feb 2013
    Northern NJ
    Putting the gears and rear motor mount in today. Cover gasket is finaly in. Going to get starter in and figure out my plan to make valve spring compression tool
    RealGear Mig 140
  23. #73
    May 2008
    Orange, TX
    Make it easy on yourself and pick up one of these (or similar design) small engine valve spring compressor.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  24. #74
    Feb 2013
    Northern NJ
    I should of looked better. First one I saw was 75$ and I said I'll make one for 10$.
    RealGear Mig 140
  25. #75
    Feb 2013
    Northern NJ
    So the connecting rods came in today. Only one slight slight problem. 3 are tanged on one side and the fourth is tanged on the other all f226d400. 3 are from f163 and the 4th is from f227? not sure if this makes a problem or not. Have to order new bearings or return the one rod.
    3 Left and 1 right.
    RealGear Mig 140
Page generated in 1,713,242,231.98076 seconds with 19 queries
