Results 1 to 12 of 12
Thread: morning home training vertical 7018
    Feb 2009
    i have just finished my one month welding school course, so i bought an 140 amps inverter so i could practice at home since i couldnt still get a job. All good and bad commentarys are apreciated.
    vertical welds done with 120 amps on 7018 3.25 rods
    Feb 2007
    Hamlin NY
    Re: morning home training vertical 7018
    L9ooks good, if you clean (grind) off the mill scale, the undercutting may go away.
    David
    Real world weldin.
    Sep 2008
    Central PA
    Lookin' good. As mentioned, grind all mill scale prior to welding, and if you have one, remove all slag after welding with a wire wheel. Looks like you were pausing on the left side properly, but not enough time on the right.
    Keep up the good work.
    Dec 2008
    Belleville, IL
    i'm in welding school right now and i have been doing the vertical up also.. to get rig of the under cut pause a sec. longer but other than that its a very nice weld..
    Dec 2008
    Superior, WI
    Good looking welds, the little undercut you do have could easily be eliminated by changing your rod angle a little.
    - If you can jump across it you can weld it! - anonymous old boilermaker
    The undercut/underfill is so consistent I would also suggest changing rod angle.
    Feb 2009
    trying to get better
    more training on vertical
    Feb 2007
    Hamlin NY
    Looks pretty darn good to me!
    David
    Real world weldin.
    Ca, USA
    mmm that IS nice! Flat face with no undercut and nice wet in at the toes. Tastey.
    MM350P/Python/Q300
    MM175/Q300
    DialarcHF
    HTP MIG200
    PowCon300SM
    Hypertherm380
    ThermalArc185
    Purox oa
    F350CrewCab4x4
    LoadNGo utilitybed
    Bobcat250
    XMT304/Optima/Spoolmatic
    Suitcase12RC/Q300
    Suitcase8RC/Q400
    Passport/Q300
    Smith op
    Nov 2007
    Not too bad at all. And practice makes perfect---so they say.
    May 2006
    Ontario,Canada
    The weld looks good , just looks a little to big of a fillet for that plate. Should only be the same thickness of the plate. Or it could just be the picture.
    Feb 2009
    yes Bikespot, its a little big for the plate because underneath i practised a t joint with 3 passes and then i did the vertical, i need to save € on the steel.
    regards
Page generated in 1,713,259,278.40532 seconds with 19 queries
