Results 1 to 6 of 6
Thread: Will magnets cause arc blow?
    Aug 2012
    AR
    Understanding that magnetized steel can cause arc blow when using DC, does the use of the right-angle magnets similar to these to hold pieces together while tacking or welding cause arc blow?
    Seems that the magnetic field created when those are used must be greater than, say, used oil field pipe or similar magnetized material.
    Sebeka and Bemidji MN
    Re: Will magnets cause arc blow?
    Yes they do screw with your arc
    Try to tig weld next to one with low DC current
    On youtube watch The Story of Alternating Current Arc Welding - 1944
    About minute 3:00 they actually show it.
    Syncro 350
    Aug 2012
    AR
    That was a pretty convincing video. Thanks for posting it.
    I used one of the magnets to hold a couple of pieces of steel at right angles for about a 1" bead and as an afterthought, noticed that the arc had been much more erratic than the following beads after I removed the magnet. At first, I thought it was just me and a lousy bead, but now I realize it must have been the mag. I was using some 5/64" 6013 DCEP for a small project that didn't need as much penetration and the magnet probably just ate that small rod's lunch.
    You're probably right - little arc didn't have a chance
    My friend learned it by experience too. Tried to tig right over where the magnet was. No dice.
    Syncro 350
    Feb 2009
    Central Illinois
    http://weldingweb.com/vbb/showthread.php?t=61966
    Here is a problem I had with magnets.
    Dan
    May 2012
    Lakewood, Washington, United States
    You have the arc wander issue, which I haven't experienced, because when I tried to tig with magnets holding material, the filler was not very fun to manipulate. Kept wandering toward the magnet.
    -Aaron
    Jet 17.5" Drill Press
    1942 South Bend 16x84 Lathe
    1980s Miller 320A / BP --- 2013 Power Mig 256
    2012 Jet 7x12 Horizontal Bandsaw
    Victor O/A Setup
Page generated in 1,627,772,377.24777 seconds with 12 queries
