Results 1 to 13 of 13
Thread: Tig cooler gets started
    SoCal-LA
    This is the conglomeration I have now.
    Tank section.
    Morton, Washington
    Re: Tig cooler gets started
    Is the round thing to the left in the first picture a radiator?
    SoCal-LA
    Yes. Somewhat of a precooler to take advantage of the tempurature delta between room temp air and the hot coolant from the torch. The hot coolant enters at the bottom and exits the top and is dumped into the bowl of the tank. It shaves off a few degrees.
    SoCal-LA
    Anyway, the new one will be a variation of this convection unit we built last year.
    SoCal-LA
    Jan 2013
    ...Shoulder of Orion...
    @ shovelon - the integrated kart-H2O cooler is slick. The diamond plating look is pro all the way. Gleening ideas for a future build....
    Mahalo for posting your work in progress.
    I keep thinking a baseboard fin tube heater would make a good convection cooler.
    What are you cutting those smooth circles with? Plasma?
    Feb 2010
    Northern MN
    Quote Originally Posted by atg View Post
    The toe kick units have a lot more fin area in a smaller space. You could also use a car radiator without a fan if the capacity is large enough so heat saturation isn't an issue.
    Utah
    Everytime I see that 700 I feel like less of a man for only having the 280. That thing is such a beast.
    I love your cart, btw, the plating makes it rock.
    Apr 2010
    Quote Originally Posted by Robert Hall View Post
    Terry let me run that for a bit bob.....It's awesome the amount of power it has but he does weld 1 inch and thicker plate with that and as i learned you need it to get the puddle going ...Watching Terry run it it looks simple...It's not at least for me
    The only thing i had a problem with was the torch and supply cables are something that would take some getting used to ...That is not your common tig torch and cables and is kind of awkward in my hand
    What would SATAN do ??
    Miller Trailblazer 302 AirPak
    Miller Digital Elite
    Optrel Welding Hat
    Arcair K4000
    Suitcase 12RC / 12 VS
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    Utah
    I could only imagine!
    Any progress on the cooler shovelon? Ps your inbox is full.
Page generated in 1,634,950,455.39780 seconds with 11 queries
