Results 1 to 6 of 6
Thread: Water Cooled TIG Setup On The Truck
    Sep 2006
    Marlborough, The Peoples Republik of MA
    Finally got around to putting together a proper set up for TIG welding aluminum on my truck. After I cooked my WP-26 last year doing a heavy aluminum job, I started gathering up water cooled stuff. Here we are, all set up, gonna go to horrible freight later and get some parts to make a cart for the new "unit"
    Sep 2006
    Re: Water Cooled TIG Setup On The Truck
    Miller seriously screwed themself by making the new TB DC only, I forgot how good this thing ran an aluminum TIG bead. I will be damned if I am buying a new engine drive and a Dynasty to do what this old machine does.
    May 2008
    Orange, TX
    Quote Originally Posted by TozziWelding View Post
    Miller seriously screwed themself by making the new TB DC only, . . .
    Yep. I can't figure out why seeing as it's already in there.
    Maybe it was an "intern" project.
    Did I just ding Miller?
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jul 2010
    Haslet Texas
    There is another thing they left out.
    115v on the 14 pin plug.
    Correct me if I'm wrong, but doesn't the hf starter require 115v?
    Sep 2006
    I need 2, 115v plugs and the 14 pin to run this setup.
    May 2008
    Orange, TX
    Quote Originally Posted by AMC724 View Post
    Yep, another oops but much more easily remedied with a single wire and 14-pin terminal than no AC weld output.
    Yes it does but the standard 115VAC power configuration on the HF-251D-1 is a separate household type plug/cord unless one modified the unit to incorporate the 115VAC power supply in the 14-pin as I did on mine (http://weldingweb.com/vbb/showthread.php?t=44369 post #20). Unfortunately now my HF-251D-1 couldn't be used as is on a new Trailblazer.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
Page generated in 1,624,503,996.07432 seconds with 10 queries
