Results 1 to 4 of 4
Thread: Ranger 250 question
    Feb 2011
    Ranger 250 question
    I'm looking at a ranger 250 haven't seen it in person yet cause its a little bit of a ride from me ,but he's asking 1000 it has 2145 hours on it and guy said it needs a battery and on off switch and it does not come with leads what is the average life expectancy of one of these machines and is worth the money? Mainly will be used as a power source and I would like to get a suit case mig for it
    Jul 2013
    Re: Ranger 250 question
    your taking a big chance, you have no way of knowing what maintenance has been performed on ths welder, 2000 hours on a welder means it has been used, I would also look at the travel expense and the items it needs to bring it on line, just be careful I repair these welders for matheson tri gas, always have men coming in with welders they bought for almost nothing at the auction, or from a friend of a friend, some turn out to be good deals, some go the other way, I don't like to see people taken advantage of, once you buy it, it is yours problems and all.................
    Mar 2009
    2k+ hours is quite a bit of run time on a 250.
    Jul 2010
    Tioga county, PA
    Quote Originally Posted by 02f250 View Post
    Be careful! I own a Ranger 250. Gasoline powered. The main board went on it a year ago. Cost me over $600 to get it fixed. Be sure you can test it to the max. Weld test it above 200 amps. test the ac side. Put a power load on like a couple of 2500 watt heaters. Or try starting a compressor with it. It has a 9kw power source. So it should handle starting motors.
    Embrace theTea Party movement. Congress! Restore, Honor, and abide by the Constitution of the United States of America.
Page generated in 1,713,275,950.02139 seconds with 18 queries
