For Sale: Kubota GL-6500s Low Boy Generator
17K views 4 replies 2 participants last post by  NUTKINS
For Sale: Kubota GL-6500s Low-Boy Diesel Generator -- $2,400 OBO (No Trades).
http://orlando.craigslist.org/for/3932922752.html
Generator has been meticulously cleaned and maintained since purchase date. Serviced recently with oil and battery replaced. Less than 300 hours total on machine. Diesel is extremely reliable over gasoline powered generator cranks on the first turn. Optional 2-Wheel kit makes moving easy. Get it in time to prep for the hurricane season.
Specs:
Generator
Model GL6500S
Type Rotating field single-phase AC generator
Frequency (Hz) 60
Maximum Output (kW) 6.5
Rated Output (kW) 6
Rated Voltage (V) 120/240 Dual Voltage
Rated Current 50.00 / 25.00
Number of Poles 2
Power Factor (%) 100
Engine
Type Kubota horizontal liquid-cooled 4 cycle diesel engine
Model ZB600-GL-S
Rated Output (HP/rpm) 12 / 3000
Displacement [cu in (cc)] 34.78 (570)
Number of Cylinders 2
Fuel Tank Capacity [Gal (Liter)] 5.02 (19)
Engine Oil Capacity [Gal (Liter)] 3.17 (3.0)
Cooling System Pressurized radiator, forced circulation with water pump
Starting System Battery assisted electric starter
Noise Level (dBa) Approx. 68
Emergency Stop Mechanism In case of abnormal oil pressure or water temperature
Accessories
Model GL6500S
Pilot Lamp Standard
AC Voltmeter Standard
Fuel Guage Standard
Key Switch Standard
Glow Lamp Standard
Monitor Lamps - Oil Pressure, Battery Charge, and Water Temperature Standard
Idle Controller Standard
Ground Fault Circuit Interrupter Standard
Circuit Breaker Standard
Full Power Switch Standard
Automatic Voltage Regulator Standard
AC Repectacles Standard
Dry Battery Standard
Center Hook Standard
Hour meter, control panel cover and lock, side door lock, 2-wheel kit, remote-control unit, thermostat kit* Optional
Contact at (407)-496-4938,
-Ben.
Located in Orlando, FL.
You have insufficient privileges to reply here.
