Results 1 to 25 of 35
Thread: Sheet-Gauge Thickness Chart
    Oct 2003
    Birmingham Al
    Thickness Weight
    Gauge Frac. Inch Dec. Inch mm oz/ft^2 lb/ft^2 kg/ft^2 kg/m^2 lb/m^2
    0000000 1/2 .5 12.7 320 20.00 9.072 97.65 215.28
    000000 15/32 .46875 11.90625 300 18.75 8.505 91.55 201.82
    00000 7/16 .4375 11.1125 280 17.50 7.983 85.44 188.37
    0000 13/32 .40625 10.31875 260 16.25 7.371 79.33 174.91
    000 3/8 .375 9.525 240 15 6.804 73.24 161.46
    00 11/32 .34375 8.73125 220 13.75 6.237 67.13 148.00
    0 5/16 .3125 7.9375 200 12.50 5.67 61.03 134.55
    1 9/32 .28125 7.14375 180 11.25 5.103 54.93 121.09
    2 17/64 .265625 6.746875 170 10.625 4.819 51.88 114.37
    3 1/4 .25 6.35 160 10 4.536 48.82 107.64
    4 15/64 .234375 5.953125 150 9.375 4.252 45.77 100.91
    5 7/32 .21875 5.55625 140 8.75 3.969 42.72 94.18
    6 13/64 .203125 5.159375 130 8.125 3.685 39.67 87.45
    7 3/16 .1875 4.7625 120 7.5 3.402 36.62 80.72
    8 11/64 .171875 4.365625 110 6.875 3.118 33.57 74.00
    9 5/32 .15625 3.96875 100 6.25 2.835 30.52 67.27
    10 9/64 .140625 3.571875 90 5.625 2.552 27.46 60.55
    11 1/8 .125 3.175 80 5 2.268 24.41 53.82
    12 7/64 .109375 2.778125 70 4.375 1.984 21.36 47.09
    13 3/32 .09375 2.38125 60 3.75 1.701 18.31 40.36
    14 5/64 .078125 1.984375 50 3.125 1.417 15.26 33.64
    15 9/128 .0703125 1.7859375 45 2.8125 1.276 13.73 30.27
    16 1/16 .0625 1.5875 40 2.5 1.134 12.21 26.91
    17 9/160 .05625 1.42875 36 2.25 1.021 10.99 24.22
    18 1/20 .05 1.27 32 2 .9072 9.765 21.53
    19 7/160 .04375 1.11125 28 1.75 .7938 8.544 18.84
    20 3/80 .0375 .9525 24 1.50 .6804 7.324 16.15
    21 11/320 .034375 .873125 22 1.375 .6237 6.713 14.80
    22 1/32 .03125 .793750 20 1.25 .567 6.103 13.46
    23 9/320 .028125 .714375 18 1.125 .5103 5.493 12.11
    24 1/40 .025 .635 16 1 .4536 4.882 10.76
    25 7/320 .021875 .555625 14 .875 .3969 4.272 9.42
    26 3/160 .01875 .47625 12 .75 .3402 3.662 8.07
    27 11/640 .0171875 .4365625 11 .6875 .3119 3.357 7.40
    28 1/64 .015625 .396875 10 .625 .2835 3.052 6.73
    29 9/640 .0140625 .3571875 9 .5625 .2551 2.746 6.05
    30 1/80 .0125 .3175 8 .5 .2268 2.441 5.38
    31 7/640 .0109375 .2778125 7 .4375 .1984 2.136 4.71
    32 13/1280 .01015625 .25796875 6 1/2 .40625 .1843 1.983 4.37
    33 3/320 .009375 .238125 6 .375 .1701 1.831 4.04
    34 11/1280 .00859375 .21828125 5 1/2 .34375 .1559 1.678 3.70
    35 5/640 .0078125 .1984375 5 .3125 .1417 1.526 3.36
    36 9/1280 .00703125 .17859375 4 1/2 .28125 .1276 1.373 3.03
    37 17/2560 .006640625 .168671875 4 1/4 .265625 .1205 1.297 2.87
    38 1/160 .00625 .15875 4 .25 .1134 1.221 2.69
    Stangnet
    Shop Full Of Stuff.
    Joey
    Oct 2003
    Birmingham Al
    Jul 2005
    ohio
    Just out of curiosity does anyone know what gauge aluminum foil is?
    Feb 2005
    Las Vegas
    atrain,
    According to the Aluminum Association;
    aluminum foil is considered "less than .006"
    plate = 1/4" or more
    sheet = .249" to .006"
    foil = less than .006"
    I just found this out last night, then I see this post today, so there you have it .
    Jul 2005
    ohio
    thanks chuck
    Florida
    Printable table in Word
    Great information, thanks. I formatted it into Word so I could print and post it. Sheez, allergies, keep me up all night....
    Okay, I made the file smaller, so I could upload it. You can put your own title on it.
    Attached Files Attached Files
    Jul 2006
    Washington State in the San Juan Islands
    Re: Printable table in Word
    Thanks - for your efforts getting all the info to line up in "word". A real good refernce!
    Jun 2005
    Taberg, NY ( near Syracuse )
    Re: Sheet-Gauge Thickness Chart
    Does anyone know what the gauge of typical car body metal is ?
    Uhmmm particuliarly the older vehicles like a TR-8 ??
    Aug 2006
    near rochester NY
    newer cars can go to 26gage but most older are closer to 18.
    thanks for the chart, verry helpfull.
    summer is here, plant a tree for mother earth. if you dont have time or space, sponcer some one else to plant one for you.
    feel free to shoot me a PM or e-mail me at [email]james@newyorkmetalart.com i got lots of time.
    Jan 2005
    Indiana
    Had to save that. Thanks for the chart!
    Soda springs,Id
    My thanks to Vipermanz and Bobcatter for the chart. I printed off 2,one for my shop and one to make bets on how thick 10 ga is. Everyone i've ever talked about it w/ has always said it is 1/8", including myself!!!!
    Thanks again,
    Mike
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    i allways thought 10 gauge was 3.2mm thats what the old guys refer to in old money welding rods 12 gauge was 2.5
    Aug 2006
    Middleburg, FL USA
    I found this online at davesport.com
    Grade and Description Chemistry Tensile Yield Rockwell Hardness
    Units typical ksi ksi typical
    1010
    ERW tube C .08-.13
    Mn .30-.60
    P .035 max
    S .035 max
    45 32 RB55 min
    1020
    DOM tube C .15-.25
    Mn .30-.60
    P .040 max
    S .050 max
    80 70 RB80
    4130
    DOM tube
    (chromoly) C .28-.33
    Mn .40-.60
    P .035
    S .040
    Si .15-.35
    Cr .80-1.10
    Mo .15-.25
    100 90 RB90
    As you can see, DOM tubing is nearly twice as strong in tension, and more than twice as strong in resistance to bending in comparison to the ERW tube. Also, the 4130 chromoly tube is only 20% stronger than standard DOM in tension.
    Weights of typical tubing sizes
    Outside Diameter Wall thickness Inside Diameter Type Weight, lbs/ft. Wgt/80ft.
    1.25" 0.120 1.010" HREW/DOM 1.448 116
    1.375" 0.120 1.135" HREW/DOM 1.608 128.6
    1.5" 0.095" 1.310 HREW/DOM 1.426 114
    1.5" 0.120" 1.260" HREW/DOM 1.769 141.5
    1.75" 0.109" (FIA) 1.532" DOM 1.910 152.8
    1.75" 0.120" 1.510" HREW/DOM 2.089 167.1
    Gauge
    Number
    Thickness (Inches)
    Pounds Per Sq. Ft.
    Nominal
    Tolerance Range
    10
    .1345
    .1405 to .1285
    5.48695
    11
    .1196
    .1256 to .1136
    4.87911
    12
    .1046
    .1106 to .0986
    4.26718
    13
    .0897
    .0947 to .0847
    3.65933
    14
    .0747
    .0797 to .0697
    3.04740
    15
    .0673
    .0723 to .0623
    2.74552
    16
    .0598
    .0648 to .0548
    2.43955
    17
    .0538
    .0578 to .0498
    2.19478
    18
    .0478
    .0518 to .0438
    1.95001
    19
    .0418
    .0458 to .0378
    1.70524
    20
    .0359
    .0389 to .0329
    1.46455
    21
    .0329
    .0359 to .0299
    1.34216
    22
    .0299
    .0329 to .0269
    1.21978
    23
    .0269
    .0299 to .0239
    1.09739
    24
    .0239
    .0269 to .0209
    .97501
    25
    .0209
    .0239 to .0179
    .85262
    26
    .0179
    .0199 to .0159
    .73023
    27
    .0164
    .0184 to .0144
    .66094
    Always looking for another old VW, especially in the southeast.
    Dec 2004
    Saudi Arabia
    Thanks guys
    Great infos
    Aug 2007
    Can someone PLEASE explain to me why I didn't find this message board until last week, when I really needed all this info 3 weeks ago???
    Hee Hee
    Oct 2007
    Great info...
    Saving most of it...
    Aug 2006
    near rochester NY
    well at first glance one would think this is very helpful. BUT all it really dose if confuse you even more ???
    none of the #'s match ???what chart do we trust ??
    vipermanz...............VS................bugdust
    COLOR="blue"]vipermanz[/COLOR]...............
    20 3/80 .0375
    27 11/640 .0171875
    15 9/128 .0703125
    20 .0359
    27 .0164
    15 .0673
    at first i just thought it was a simple question of rounding it up to keep the # from going on forever, but???? 20 gage .0375 and 20 gage .0359 are way to far to be rounding for simplicity sake ?? so what gives ?? must be a tolerance thing ??
    the only solution i see is ....
    Jan 2008
    Arkansas
    blow this up 2x to read it
    Jan 2008
    Port Jervis, NY
    very helpful!!!!! printed a copy for the tool box... Thanks everyone
    Aug 2008
    Smile I was to hasty in my previous reply.
    In the start window I get the button 'Try It' which I clicked. But it still ends after 10 minutes.
    Reno, NV
    Just to point out ferrous metal sheet and aluminum sheet gauge numbers refer to different thicknesses, meaning 10 ga. steel sheet is different thickness that 10 ga aluminum sheet. Though there are several good sources on the web, I like Aircraft Spruce and Specialty's info sheets out of their online catalog. The catalog is worth having just for the info, just like the old Starrett catalogs, verituble encyclopedias of measuring and setup info. Try this page:
    http://www.aircraftspruce.com/catalo...metalinfo1.php
    Apr 2008
    Charlotte NC
    Quote Originally Posted by Bobcatter View Post
    thinks guy for the printable info. I had written down the common guages used and posted it on my tool box for purchasing info. This is more better. Thanks again.
    Miller TrailBlazer 251
    Miller HF-250-1
    Miller MaxStar 150 STL
    HyperTherm PowerMax 380 plasma
    Lincoln PowerMig 180
    Millermatic 252
    Miller Diversion 180
    Jun 2008
    Central California
    Machinery's Handbook has these plus other 'odd' and British standards too. It is a very good reference book, although having the chart printed out for your wall or toolbox is also a great idea.
    Well, after doing a search here, I see that the Handbook has been mentioned on site fairly regularly, so I won't say more now.
    Apr 2008
    Delaware
    The chart is going on my wall and I will be handing out copies to my students....It well be a lesson in the making...I always used my pipe fitting book to look up thicknesses...this chart puts all the info in one spot...THANKS
    Jonesy
    Nov 2007
    Pittsburgh Pennsylvania
    Wow all this time and i didnt even notice this thread. I just printed one out. Thanks alot!!!
    Ya gotta spend money to make money!
Page generated in 1,713,294,977.88531 seconds with 19 queries
