Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 76 to 100 of 232
Thread: Esab
  1. #76
    Feb 2004
    BULVERDE, TX.
    Re: Esab
    Mine was included.
    QamuIs Heg qaq law' lorvIs yInqaq puS
  2. #77
    Feb 2011
    Austin, TX
    Re: Esab
    I stand corrected...
    DDA52. Your in Bulverde. Maybe I could come and take a look at your machine some time...
  3. #78
    Jun 2005
    Re: Esab
    Howdy all, ESAB I sent you a PM. Just picked up a 350MPI and 4HD. The hold up is it came with no guns. It does have a broken L-TEC Mig 41. It "appears" as though only the plastic casing/ trigger is broken. Any ideas on a repair/parts source? Could do with some advice on which foot control (14 pin), tig torch and stick stinger that would work with this inverter. As far as the hard wire gun, I'm leaning towards an air cooled
    Q-300. I'll also need drive rolls and guide tube for the hard wire. I know that's a bunch but I appreciate any advice you'all might offer. Have a good one, John B.
  4. #79
    Feb 2011
    Austin, TX
    Re: Esab
    Ok... This could take a minute so bear with me...
    Gun consumables. Most likely it will be our GunMaster 400. Not to sure, but that would be my guess. You can go to our website and there should be a breakdown of the parts that you would need. If you would like you can PM me your email and I can email the breakdown to you.
    http://products.esabna.com/EN/home/a...gun_master_400
    Here is the link for the Gun. After you are on the site, click under the picture on the right, on Product data sheet, and that should pop up a PDF with the details on the Gun.
    You should be able to go to any LWS that is a dealer and they can order the parts. Dont know where you are at so hard to say any names.
    For the tig foot control we have two different one. Standard duty is Part# 0558004234, and the Heavy duty is 33841. Again, go to your LWS and they can order this for you.
    Here are you tig torch options:
    Tig Torches - 2-piece cable and hose assembly with Twist Lock
    Cable Connector for direct connection to the power source.
    HW-17V-2-TL, 12.5 ft................................................ ....... 35857
    HW-17V-2-TL, 25 ft................................................ ........ 35856
    HW-26V-2-TL, 12.5 ft................................................ ...... 35858
    They stinger will be a basic 50MM dinse connector with around a 300amp electrode holder. If you want to order from us the part number is 21226. It is a 300amp 15' holder assembly.
    On the 4HD feeder below are the consumables, Guide tubes and drive rolls. Just pick your wire information and order the part numbers and you should be good.
    Wire Diameter Type Drive Roll Qty. Outlet Guide Qty. Center Guide Qty. Inlet Guide Qty.
    .023 in. (0.6mm) V-Solid 21155 2 21163 1 34612 1 34615 1
    .030 in. (0.8mm) V-Solid 21155 2 21164 1 34612 1 34615 1
    .035 in. (0.9mm)** V-Solid** 21156** 2 21165** 1 34612** 1 34615** 1
    .045 in. (1.2mm)** V-Solid** 21156** 2 21165** 1 34612** 1 34615** 1
    .052 in. (1.4mm) V-Solid 21157 2 21166 1 34613 1 34616 1
    1/16 in (1.6mm) V-Solid 21157 2 21166 1 34613 1 34616 1
    .030 in. (0.8mm) K-Cored 21160 2 21164 1 34612 1 34615 1
    .035 in. (0.9mm) K-Cored 21160 2 21165 1 34612 1 34615 1
    .045 in. (1.2mm) K-Cored 21161 2 21165 1 34612 1 34615 1
    .052 in. (1.4mm) K-Cored 21161 2 21166 1 34612 1 34615 1
    1/16 in. (1.6mm) K-Cored 21161 2 21166 1 34613 1 34616 1
    5/64 in. (2.0mm) K-Cored 21162 2 21166 1 34613 1 34616 1
    .035 in. (0.9mm) U-Soft 21158 2 21167* 1 34612 1 34615 1
    3/64 in. (1.2mm) U-Soft 21158 2 21168* 1 34612 1 34615 1
    1/16 in. (1.6mm) U-Soft 21159 2 Not Required 1 34613 1 34616 1
    Ok that was a lot more that I thought it would be but should get you everything you need. Let me know on a PM if there is more you need and I can point you in the right direction.
  5. #80
    Jun 2005
    Re: Esab
    First, thanks for all the info. that answered several questions and puts me on track. I should be able to get to an Arcet retailer Saturday and get most of what's needed ordered. I'll PM you shortly with some details that might further zero this in.
  6. #81
    Feb 2004
    BULVERDE, TX.
    Re: Esab
    Quote Originally Posted by ESABREP View Post
    Fine with me. Have a truck project taking up the entire shop at the moment. Would be better in a few weeks. I can drop you a note after its cleared.
  7. #82
    Aug 2009
    Re: Esab
    The MIG 41 is still made.
    products.esabna.com/index.php/library/1172588176_mig-41.pdf
    The Gunmasters take Tregaskiss-style consumables. Don't mix tips with Tweco as the thread pitch is different. You can use the Euro connector gun of your choice on the 4HD feeder.
    We don't buy special TIG torch setups, and instead just clip a scratch-start rig to the stinger. You can then reach as far as you want. We buy Radnor TIG torches which last fine. Unless it's a mandatory proprietary ESAB part we avoid getting it from them because their stuff is expensive.
    Download all your manuals/parts books from the ESAB site then TELEPHONE order from Scott Gross. They beat my LWS and we are just down the road from ESAB in Florence. It all gets drop-shipped anyway!
    http://www.esabna.com/us/en/support/downloads/index.cfm
  8. #83
    Jun 2005
    Re: Esab
    Now there's some good news farmall. Big relief to know the parts are still there. I'll shop for a repair. I was told a local LWS repairs them. I mentioned to David the closest LWS is an hour away in Roanoke, Va. Anything I can get to appear at the shop door in a brown truck is better. I'm getting a mig gun headed this way tomorrow. I'm figuring SG for the drive rolls. I was looking at weldcraft torches last night. I'll check out the Radnor tonight. This keeps up I could be burning steel next week. Anyboby interested in a MM251?
  9. #84
    Aug 2009
    Re: Esab
    Look at the manual first. There isn't much to them, and you can swap parts faster yourself than farming it out.
    http://www.esabna.com/us/en/support/...es/Mig_Torches
  10. #85
    Jun 2005
    Re: Esab
    Thought I'd drop in for an update. Odered A Q-400, drive rolls and tube at tthe same time couple of weeks ago. Got a HOBART male plugin to the power source that'll fit the standard 3 prong dryer hook up. Gas bottle/regulator seems serviceable . 400 should be here this week. Only thing it's short then is maybe a stinger and the tig set up. That might have to come next payday.
    I'd just about bet the FXR on FARMALL being right. You look at someting a couple of times and figure it out. I might take it by the repair site and ask for some conversation and a parts purchase. See if we can work something out. Keep you posted though, Yall been good about this, Thanks, John B.
  11. #86
    Re: Esab
    Esab 2200i I need some moe information on one, other than the standard boiler plate. I need hands on with one and I'm not having much luck. Thanks William.
  12. #87
    Jan 2009
    Nolalu (near Thunder Bay) Ontario, Canada
    Re: Esab
    Just last weekend I went to the ESAB website and used the "Contact Us" page to ask a question. Still haven't seen an email from them.
    Am passively interested in the ESAB Caddy MIG 200i. They advertise that it is good for aluminum welding so I want to know if they have a spool gun or a push-pull gun for it. Sure hope they don't think that a teflon liner is an attractive solution to me.
    I like the weight of this unit. Too bad it isn't dual input voltage like the Miller 211 MIG.
    Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
  13. #88
    Re: Esab
    I'm looking at a used Migmaster 250 with a spool gun, tank and reg. for $1850. It's about 2 years old and has not had a spool of wire run through it. Is that price fair, high or low?
  14. #89
    Jan 2005
    Re: Esab
    Quote Originally Posted by FrankT View Post
    Depending on the spool-gun, it's fair to good. The ST-23 gun is the more expensive, and better built spool-gun. Does the machine have a black face or tan front? Older is the Tan color front. Much older unit, but still a good unit. Very few changes over the years.
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    Thermal Drag-gun 35C
    INE 1500
    Klutch 140i
  15. #90
    Re: Esab
    I have not seen the spool-gun yet. He's having trouble finding it (says it's in storage) but I'm guessing it's a MT-250 SG. I don't really need the spool-gun. What would the spool-gun be worth if I sold it? $450-475? Black front on the welder.
  16. #91
    Jan 2006
    Re: Esab
    if it is the st-23 and the machine is as you say then, yes it is a fair deal. Not great, but you will not be taken either. it is fair for the both of you. I love the 250 and an st 23.
  17. #92
    Re: Esab
    Make certain the tank is privately owned and not rented or leased. What type of shielding gas does the tank contain?
    On mild steel the Migmaster 250 is one of my favorite short arc units (clean smooth arc with very light spatter) with C-25 shielding gas.
    ESAB Migmaster 250
    Hobart Ironman 230
    Multimatic 215
    TWECO Fabricator 181i & 211i
    HH125EZ - nice little fluxcore only unit
    Maxstar 150 STH - very nice
  18. #93
    Re: Esab
    It's is definately the MT-250 spool-gun and it looks to have been used once to try it out. He does have two tanks with it, that I did verify he purchased. One is a R size straight Argon and the other a D with C25. He also has a second regulator for the argon tank, all the paperwork that came with the machine, extra tips, etc. The machine is dusty from sitting but looks to have had VERY little use in his home shop. I think I'm going to try $1650 for the package and see what happens.
  19. #94
    Feb 2004
    BULVERDE, TX.
    Re: Esab
    Esabrep, you have a PM.
  20. #95
    Jan 2005
    Re: Esab
    With two tanks, and that spool-gun, it's a good deal at $1850. (IMO) You will not get close to that deal with a used Miller or Lincoln. Although the Esab really is the best machine in that class. (Again IMO)
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    INE 1500
    Klutch 140i
  21. #96
    Re: Esab
    I ended up getting it for $1750. Thanks for the input.
  22. #97
    Jan 2005
    Re: Esab
    Good deal!
    If you decide to run .030 wire, run the correct outlet guide tube.(#21164) It cleans the arc up just a bit over the stock unit. Get good wire like Hobart HB-28/Esab 86 and then you will start out knowing how good the Migmaster is. C-25 for short-arc welding.
    http://products.esabna.com/index.php...master_250.pdf
    Esab/Lorch ET-220i
    Esab 160i caddy
    Thermal Pee-Wee 85s
    INE 1500
    Klutch 140i
  23. #98
    Re: Esab
    FrankT,
    If you haven't powered the unit up yet, I'll warn you ahead of time that cooling fan produces quite a bit noise.
    Without a spool hub spacer to center the roll of wire up better with the drive rolls, an 8" diameter spool of wire can have some feeding issues. I generally run 12" diameter spools of wire on mine, and haven't had any feeding issues. I just finished up a roll of .030 Hobart HB-28 and it was running great on the unit on 1/8" - 1/4". Now I am know working on burning up an old roll of .035 Prostar, on 1/8" - 1/4", that performs very well on this unit.
    If the unit doesn't already have it, you may want to purchase the add-on spot/stitch/ burnback module. My unit had an issue with the wire sticking in the weld puddle at the end of quick tacks where I didn't pull the gun back. I added the above mentioned module. I gave the burnback timer just a fraction of a second of arc on time, and I no longer have an issue with the wire sticking in the weld puddle.
    ESAB Migmaster 250
    Hobart Ironman 230
    Multimatic 215
  24. #99
    Re: Esab
    Brought my New-To-Me Migmaster home today. In it's previous life it was driven only on Sundays by a Little Old Lady.
  25. #100
    Jan 2006
    Re: Esab
    nice!
Page generated in 1,623,660,960.18228 seconds with 12 queries
