Results 1 to 7 of 7
Thread: Convert spoolmatic 30a to bernard centerfire tips?
    May 2009
    San Luis Obispo, CA
    I'm thinking about trying to convert my spoolmatic 30a to use centerfire front end parts. Has anyone done this?
    I've read this thread: http://weldingweb.com/vbb/showthread.php...help-requested, but no one ever said how it actually worked out.
    The bernard parts sheet:http://www.bernardwelds.com/files/SpSh_SGA12345.pdf
    Ian Tanner
    Kawasaki KX450 and many other fine tools
    May 2008
    Orange, TX
    Re: Convert spoolmatic 30a to bernard centerfire tips?
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jul 2010
    Haslet Texas
    I didn't click on either links, but I asked my weld supply salesman to get me the parts, and he said they were to expensive
    Jul 2009
    SW Washington State
Size:  31.0 KBName:  30A 5.jpg
Size:  35.9 KBName:  30A 6.jpg
Size:  45.1 KBName:  30A 7.jpg
Size:  29.3 KBName:  30A 8.jpg
Size:  36.8 KBName:  30A 1.jpg
    Hello fortyonethirty, I have done just that to 3 units. Didn't like the old style system with all of the myriad of parts and also had issues with tip fouling quite often. As another poster here mentioned there is a factory conversion available that is plug and play, unfortunately, it is rather expensive. The one that I came up with utilizes some of the original parts and with a bit of modification a brass/copper nipple of your choice and some shrink tube or rubber sleeving removed from a length of welding cable you can set up a very useable and serviceable replacement to the old system. I will see about including some pictures to explain this process better. You do need to purchase the new diffuser, tip, and nozzle as well the bronze liner segment. Good luck and best regards, Allan
    PS. please forgive me for the double posting of the pictures, this new format is still in a formative stage for me.
    aevald
    Jun 2015
    Quote Originally Posted by aevald View Post
    Hey Allan, would you happen to know which parts those are exactly? I'm having a hard time finding the parts you used
    Thank you sir,
    Garrett
    Jun 2010
    Is there an issue I am missing regarding the 30A gun? I thought that was one of their better guns. Just wondering, because I use one.
    Jan 2008
    Lansing, MI
    Not really, some ppl just prefer the Bernard center fire tips and nozzles over the OEM ones on the older guns. They also offer a conversion kit for the Miller Fastip consumables as well, which is what I have on mine.
Page generated in 1,627,455,262.93029 seconds with 12 queries
