I have an Esab Heliarc 252 that I bought used at a school auction. When I use it for TIG, while in DC, the arc is sporadic and quickly burns through. I'm using a red tungsten and 100% argon for stainless and mild steel. It also doesn't want to strike an arc at times and you have to almost scratch start it, although I'm using a pedal. I have not attempted AC.
I also hooked up a mig wire feeder (Hobart) and attempted to use it as a simple DC power source. It initially shoots a flame from the tip(similar to a torch flame) and then the wire will just pile up on the base material without melting any base.
I am wondering if anyone has any experience with this type of problem or any direction I can look to fix it.
Thanks for any help.
