Results 1 to 7 of 7
Thread: Price for steel plate
    Feb 2009
    Central CA
    I was quoted a price of $90 for a piece of steel 1/4 X 2ft X 3ft. That seems expensive to me, since guys here have been talking about buying steel for less than $.50/lb. But then, I'm new. The seller told me that plate was especially expensive--true?
    Edit: Sheesh. With ONE phone call I found a place a little bit further away that is half the price. I'm learning.
    Tim
    Re: Price for steel plate
    No only are you paying for the sheet, but you are also paying to have them cut it to your specifications.
    Nov 2006
    Quote Originally Posted by timrb View Post
    . . .The seller told me that plate was especially expensive--true?
    Ya... But not that expensive.
    That cut weighs only 60 lbs.
    Good Luck
    Mar 2009
    upland, ca
    i was quoted $95 for 2'x4' 1/2 inch in so cal
    Dec 2008
    Superior, WI
    I usually go to my steel supplier and look for drops that are the size that I need, that way I'm not paying for them to cut it.
    - If you can jump across it you can weld it! - anonymous old boilermaker
    Cassville, Missouri
    Like they all said buying less than a full sheet will cost you, but that's a bit high even for a cut.
    Tough as nails and damn near as smart
    Jul 2009
    Winter Garden, FL
    I just got a 4x8 16ga the paper said 80lbs $42 and change
Page generated in 1,635,135,399.31274 seconds with 11 queries
