Results 1 to 16 of 16
Thread: Uncommon Weld Joint Question
    Nov 2013
    Hello All,
    Please see my attached image. I am making a hybrid tee weld. On the opposite side of the weld, there is another piece of steel. So, I am only making a fillet weld on one side of the steel.
    Are there any other situations where a similar weld joint is used?? I'd like to take a look at other examples of this type of weld, so I can do it correctly!
    Thanks!
    Costa Rica
    Re: Uncommon Weld Joint Question
    Uncommon isn't really the term I had in mind. Elaborate on what this is. Bigger than a toaster ? 200 feet long ?
    Bubble gum
    Tooth pix
    Duct tape
    Black glue
    GBMF hammer
    Screw gun --bad battery (see above)
    Nov 2013
Size:  19.7 KB Hi Burpee, I am attaching an additional photo. The weld is around the circumference of the circle. Imagine the circle diameter is 3 inches.
    Costa Rica
    That's more like it. What thickness is the tube ?
    Bubble gum
    Tooth pix
    Duct tape
    Black glue
    GBMF hammer
    Nov 2013
    It's about 0.03 inches thick.
    May 2013
    Virginia
    Almost like a socket weld. But not really.
    Would work for reference though.
    Oct 2013
    Houston, Tx
    Wow. .030 is like lightweight bicycle tubing thin.
    I think if I were not Tigging it, I would have to roll it out, on the downhill side.
    Shoot, I might even filet braze it.
    Nov 2013
    I enjoyed reading this post. I congratulate you for the terrific job you've made. Great stuff, just simply amazing!
    Nov 2013
    Thanks for the responses everyone. Geezerbill, I am new to welding. Can you give me an explanation on why you would suggest brazing the joint? What are the advantages? akabadnews, thanks for your insight - it definitely looks close to a socket weld, good reference point. The one difference between a socket weld and my situation is that there is an additional wall behind the first weld wall. As geezerbill said, it is a thin wall tube. I did a poor job of adding description to the image. The grey area represents the potential weld. I sectioned a pizza slice out of the circle to give a better view of the wall/weld joint.
    Sep 2006
    NJ, USA
    Brazing suggested because welding some 0.030 wall tube is in the realm of NotEasyToDo.
    Brazing suggested because then you are only getting things hot enough to melt and flow the brazing filler and not melting the tube or the 'plug'.
    The weld geometry is not really unusual or anything. Just a fillet weld on a circumference.
    The best laid schemes ... Gang oft agley ...
    Oct 2013
    Houston, Tx
    Quote Originally Posted by MoonRise View Post
    Yeah, it can disappear almost magically
    If you are new to welding, you might be able to accomplish a filet braze sooner than a good weld on .030.
    But, if you can get a stable arc at low enough amperage, and run it downhill, keeping most of the heat on the bottom (thicker?) piece, you can make the weld.
    You would need only to wash up a bit on to the .030, not needing equal build-up on it as might be on the thicker piece.
    I did some bicycle tubing (TIG) at about 10 amps, using .045 mig wire as filler.
    No foot pedal.
    It was exciting.
    I hope you have some extra similar material to get the feel of it.
    Let us know how it goes.
    Morton, Washington
    I'd think brazing would be the method of choice as the capillary action would provide much greater bond to larger inside shoulder than a small weld around the outer lip. Another possibility would be silver solder (braze), depending on the use. Can you face groove the part so the tube slides into a slot? This would give you a stronger joint and cleaner finish when brazed.
    Dec 2011
    Texas
    +1 on brazing or silver solder if you can get a good tight fit up. If you absolutely positively have to weld it, I'd want a 3" diameter chill bar inside the tube, a low amp tig, and a tig finger.
    I am admittedly a novice and low class bedframe welder and so would not even try to do weld that.
    Feb 2013
    56% silver braze and paste flux. Flux the mating surfaces of the plug and tube. Assemble, concentrate the flame on the heavy plug until the tubing gets red. Apply braze on outside of tube (where your weld is in the diagram) and allow it to wick into the joint. Use the flame to move the braze to where you want it. The braze will follow the the flux and heat.
    From the diagram, it looks similar to brazing on a cap to the end of a tube.
    Dec 2011
    Tampa FL
    I would have to agree with Forhire, cut a groove in the cap and silver solder. Even if welding a groove would make it a lot easier to pull of, you would be working a little bit of the end of the tube that way.
    Feb 2010
    Northern MN
    Pretty common to see that exact type of joint in the ORV world in suspension and steering links, the tubing is quite a bit heavier but the principal is the same. The joint is use is almost always in some sort of tension with the insert removing the lateral load from the weld joint and basically converting a portion of it to tension.
Page generated in 1,627,732,381.26495 seconds with 14 queries
