Results 1 to 25 of 33
Thread: Need help Welding Pinhole on High pressure steam line.
    Nov 2013
    May be the wrong place to be asking this. but top welding forum on Google
    I work on steam lines with an average 140 PSI. On a 8 inch, 80 grade, 300PSI Max, carbon steel pipe. I installed a welded-in gate valve. I also installed a bypass, which where 2 holes
    on the pipe on each side of the valve and welded a weldolet on the holes. My welds for the gate valve to the pipe were x ray tested and passed as solid. my weldolet welds were not
    tested, i told the inspector not to worry about them. (BAD MOVE). both my welds on the valve and weldolets were a single pass with 1/8 6010 5P rod. the hot pass and cap for both were
    3/32 7018. few weeks later they fully charge the line, about 3-5 days later my weldolet begins to leak. it sounds like a leaf blower walking up to it from 100 ft yet a 3/32 rod wont fit in
    the pinhole. Anyways today i begin to weld over the pinhole to try and stop the leak. after chasing the pinhole for about an hour i manage to get it down to a quiet hiss. by now i have
    this 2 inch ball of metal under my weldolet, which i plan to fix when that line gets shut down in February. For now i need to take care of the leak which will most likely get bigger. i came
    here to ask if anyone had any suggestions. after some thinking today i may hammer in some wood, maybe it'll hold the pressure back enough to run a bead over it? Obviously an outage
    is not possible until February.
    Oct 2011
    Jacksonville Florida
    Re: Need help Welding Pinhole on High pressure steam line.
    I can't help because I haven't done anything like that, curious about the answer to the problem though. Maybe start the bead 1/4-3/8" away from the pin hole and wash the 6010 into it to seal then run a 7018 over that? Did you grind around the hole any?
    Airco Ac/Dc 300 Heliwelder
    MillerMatic 200 (stolen)
    Miller Maxstar 150STL
    Miller AEAD200LE (welding and generating power)
    Hobart MIG
    Nov 2013
    i wired wheeled the hole, got it nice and clean. yes i did exactly that, started about an 8th of an inch away welding above it going downhill , tried going uphill, left to right, right to left. i was there for an hour. i actually got it to stop for about 5 seconds then i could hear it cracking then it begins to hiss. i turned the heat down to dig less metal but that damn hiss always comes back. when welding over the pin hole, in the puddle is a needle size hole the moves around with the puddle. i plan to either jam wood in the hole, or try to stop the leak completely again for that short time and spray a jet stream of ice water on it to harden it and keep running a bead, cooling it, another bead, cool it. until i can run 7018 over it. i'm motivated to fix it because i was able to bring it down from the sound of a leaf blower to a quiet hiss.
    Oct 2011
    Could you hammer a nail into it then weld over it? I don't think wood would hold but I don't know. Or maybe heat it with a torch then hammer a nail into it, when it cools it may be sealed good enough.
    Hobart MIG
    Dec 2009
    check your PM
    Nov 2013
    You may have something there with heating a nail and hit it in, thanks. but yea i didn't use a nail instead i used a rod, i actually sharpened it into a point on and when i hit in it actually worked a little, then i welded it and the rod i guess melted. i'll try a nail next time.
    Nov 2013
    is there a soft metal i can sharpen into a nail? maybe brass? i'm thinking the pinhole may not be a perfect circle. if i hit the nail in, it either may make the hole bigger because nails are strong or not completely cover the hole and it leaks by, leaks less but still leaks. i say a soft metal i can hammer in, that will take form of the hole and hold off pressure, which is the idea behind jamming wood, it'll take shape of the hole. and i assume the steams condensate would seep into the wood and expand the wood
    Dec 2011
    Tampa FL
    Center punch around the hole to push the metal into the hole and close it up. Then you may be able to weld over it, since it wont be an active leak.
    Nov 2013
    well then i was being very hard headed because my co worker kept trying to do that, he tried about 4 times after each weld but he only made the hole worse. at one point it worked and quickly welded over it but the hiss came back. kept telling him to stop, shouldve been more patient and kept trying that.
    Dec 2011
    Tampa FL
    It doesn't always work, some times you can get it this way. I have never done it on a steam line, but pipes with various liquids in them.
    Dec 2011
    Tampa FL
    If you get it to stop leaking then try putting just a couple of quick tacks over it. After a couple of tacks then you should be able to put a weld over it, you have to keep it a rather cold bead or it will just blow out again.
    damn, this is scary.
    Nov 2013
    "It doesn't always work, some times you can get it this way. I have never done it on a steam line, but pipes with various liquids in them."
    yea my guess is that while welding it diggs in too deep and the metal holding the pressure gets soft. maybe lower the heat and arc at that point
    Nov 2013
    "If you get it to stop leaking then try putting just a couple of quick tacks over it. After a couple of tacks then you should be able to put a weld over it, you have to keep it a rather cold bead or it will just blow out again."
    yea that's the plan i was gonna try to spray it with ice water as well to help harden it faster.
    Jul 2013
    Ok this is a joke?
    I am a Steam a Fitter welder. If there is that much pressure the only way to repair your weld and make "safe" is to shut off the steam. Trying to weld over it, or tack it will not tie into the base metal enough to be a permeant fix.
    The leak is in the first pass and made its way through all the other weld.
    Turn off the steam, grind it out, and repair. That's the right way.
    Local 83
    Nov 2013
    Quote Originally Posted by RodBender View Post
    Ok this is a joke?
    Definitely the right way, i understand that. this steam lines goes into an old government building. an outage is not possible, until February.
    i'm going to stop this leak even if i have to weld a nipple on the pin hole and put a cap on it. the location of this valve is 50 ft below ground in a 50 year old manhole which is 130F.
    no standards being followed here and lack of quality. its too late. now i just need to get the job done stop the leak until Feb
    Nov 2013
    Farson, Wyoming
    Rodbender hit it on the head. Do it right, and save alot of headache. You have to repair the root first, or keep chasing the hole. We ALL have to swallow our pride sometimes, (it doesn't taste very good either) but it's better than spending a whole lot of time on a single pinhole problem that can be repaired in an hour. jmho. Rick
    Nov 2013
    Quote Originally Posted by Rickswelding View Post
    i may have to do that, i'll give it another try then leave it alone
    Nov 2012
    Weld a thread-olet around the leak, then screw a valve or plug into the o-let.
    Apr 2013
    NE
    What caused the leak in the first place? What temperature was the base metal when you welded it?
    Jul 2012
    Ok this is a joke?
    It almost seems like a troll. Isn't this an ASME pressure pipe connection? Wouldn't Hartford, Factory Mutual or another insurance company be on the hook, thence be involved. A lot here I'm having trouble swallowing, especially with the talk of it (?) being a government building.
    Jun 2007
    I almost always carry horse shoe nails in my pockets. They are very useful for fitting and stuff. You can go ahead and try pounding one into the hole and welding around the head, but not my recommendation. What if it blows back out? What if it breaks off inside? Where is that steam going lol? I once heard a story about a guy taking a broom handle and waving it in front of a pinhole in a steam line. It cut the broom handle in half. I also just recalled a friend of my dads getting really badly burnt by steam at work. I was going to suggest throwing quick tacks over the hole then an over lay of beads, but I think Ill pass. Be safe!
    Nothing Ever Got Done By Quitting, Never Give Up.
    May 2013
    Chicago
    Ime no expert but that just sounds like a bad idea.
    PROUD AMERICAN
    Nov 2013
    Quote Originally Posted by TimmyTIG View Post
    Yes i may do that, but after reading a few suggestions i may have to leave it alone. Suck it up and wait till a shutdown in Feb.
    Nov 2013
    Quote Originally Posted by TSCGG13 View Post
    I believe when running the root weld on the weldolet i didn't penetrate the base metal enough. At eye sight it looked fine but the x ray test wouldve showed cracks or slag
Page generated in 1,664,638,780.58933 seconds with 11 queries
