Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
Thread: Bicycle Frame
    Jul 2013
    Eugene, Oregon
    Re: Bicycle Frame
    I have been a professional production frame builder (among other things) for over 7 years, and worked on many thousands of frames (either machining tubing, welding, brazing, finishing, powdercoating, etc.). If you were to make from standard .035" 4130 tubing, it could cost anywhere from ~$80-120 for tubing (roughly). That's not counting machining for BB shells, headtubes, and dropouts. Those parts would add anywhere from around $40-300, depending on options (steel). I wouldn't build a Ti frame as your first foray. I'd build steel frames for awhile first.
    As far as a jig, you could conceivably make a honeycomb core wood plate, then use that to build the rest of your jig from. That's if you were wanting to work on the cheap. You could then use some kind of alignment "stick" on each side of the frame after welding to get some idea of rough alignment.
    It's well within the realm of what you can do, based on your welding picture, and a good mental exercise.
    Miller Dynasty 200 DX
    Miller CP-300 with 30A feeder
    Hypertherm Powermax 900
    Oxy-fuel w/Harris torches
    Scotchman Glide-in bandsaw
    Monarch 10EE lathe
    Emi-Mec Autoturn lathe
    Deckel FP2NC milling machine
    Pro-Tools 105 Bender
    Dec 2009
    Stevens Point, WI
    Re: Bicycle Frame
    I'd just stick with buying bikes from walmart.
    Jul 2013
    Eugene, Oregon
    Re: Bicycle Frame
    Walmart doesn't carry bicycles - just bicycle shaped objects (not the same).
    Okay, that's pretty callous of me, but all those department store bikes are of such poor quality that I just can't bring myself to consider them an actual bicycle. Many of them are downright dangerous.
    Monarch 10EE lathe
    Feb 2013
    So Cal
    Re: Bicycle Frame
    I also ride bmx and while my welding skills may not compare at all to guys on this forum I do know a bit about bmx. As others have said 4130 chro-moly would be the best way to go, although (like others have already said) there is much more to frame building than just sticking tubes together. Set up is very important and geometry plays a huge role, especially when talking bmx bikes. You have to look at your bb height specs, what kind of bb fitting are you looking to make (Spanish, euro, mid), got to keep in mind the top tube height and angle, the headset angle, chainstays, seat post, 1 degree higher and you got a less responsive bike but more stability shorter chainstay you have a more responsive bike for 360s. The abuse bmx bikes take is incredible Especially now a days with all the "big riders" guys doing 360s off of 16 stair sets and what not, the last thing any rider wants is for something to malfunction while hopping over something at full speed, lots of road rash and lots of Vicodin. Speaking of which I took a pretty bad fall today keep those brain buckets up and ride on
  5. #30
    Feb 2013
    So Cal
    Re: Bicycle Frame
    Quote Originally Posted by Fifelaker View Post
    But that comes after "Hold my beer and watch this"
    I was trying to find a video for you guys about this guy who seemed to be heavily under the influence... Goes up to some kids and tells them he can do what they're doing, his beer courage came out. Goes up to a loading dock jumps off on one of their bikes and lands straight on his ***.... Poor guy probably broke his coccyx bone or something, probably too drunk to feel it. Would've been perfect for that quote, shucks you can never find things you want when you want them.
  6. #31
    Oct 2012
    East Van BC
    Re: Bicycle Frame
    something like ?
    SqWave 200
    Millermatic 190
    Airco 200 AC
    Hypertherm PM45
    Boice-Crane Band Saw
    Victor O/A
  7. #32
    Feb 2013
    So Cal
    Re: Bicycle Frame
    Haha yeah something like that. Thats an impressive wallride
  8. #33
    Oct 2012
    East Van BC
    Re: Bicycle Frame
    Here's some home made bikes:
    bikeforums.net-Show-us-your-builds
    SqWave 200
    Millermatic 190
    Airco 200 AC
    Hypertherm PM45
    Victor O/A
  9. #34
    Apr 2012
    Washington State
    Re: Bicycle Frame
    Sweet!
    lloyd.plywood
    HF 90amp flux wire welder
    Hobart 125 Mig/Flux
    HF 80amp inverter stick/tig
    Smith oxygen acetylene torch
Page generated in 1,664,394,209.31749 seconds with 11 queries
