Page 376 of 682 FirstFirst ... 276326366374375376377378386426476 ... LastLast
Results 9,376 to 9,400 of 17039
Thread: Show us what you welded today
  1. #9376
    Mar 2016
    Re: Show us what you welded today!
    Uintas, that’s a serious table base. Looks great!
  2. #9377
    Feb 2019
    Austin, Tx
    Andy, welcome to the forum
    Is that the Miller 211 MIG?
    I'd like to know which laser you bought and what you'll be cutting, thanks
    Richard,
    Thanks. Yes, it is a miller 211. I've also have an Everlast 256 Tig/Stick/Plasma machine, though the plasma isn't working. One of these days I need to get that fixed.
    The laser is a DIY contraption. http://www.lasersaur.com/. I bought it used from a hacker space out in El Paso Texas last July. I have very limited space, so its been riding around in my van since then. My van is my mobile storage unit
    As to what I will cut on it, mostly thin plastic and plywood. I've used one at our local hacker space to make storage boxes, small gifts etc. Once I get it up and running again, I'll figure out what I can make with it. Its kind of like a welding machine, I bought that out of a vague desire to stick bits of metal together. It greatly expands what I can do.
    I have no illusions about my welding abilities. I stay well away from anything structural. Still, its fun, and slowly I get better better at it. I'm in awe of the welders that produce the beautiful welds here. I had no idea of the skill involved until I tried to do it myself and failed.
    I got started by taking a continuing education class at a local community college,5 plus years ago. They started with stick, then in a later course moved on to TIG and MIG. I weld it my garage, so I gravitated to TIG because I was less likely to burn the house down!
    Andy
  3. #9378
    Quote Originally Posted by AndyH View Post
    the 14ga sheet metal buckled in the center. I should have made some plug welds along the braces. Hopefully with the torch and a wet rag I can shrink it down.
    Yep, sounds like a job for flame straightening.
    Virgil posted a good video of the process a while ago.
    https://weldingweb.com/vbb/showthread.ph...-straightening
  4. #9379
    Feb 2019
    Austin, Tx
    Quote Originally Posted by p4nh4ndle View Post
    p4nh4ndle,
    Thank you for that. I wish I had watched that before I put the top on. The frame warped a bit during welding. I could have probably straightened it. I'll know for my next project, whatever that may be. Its amazing how much bend they put in the beams.
    Andy
    Everlast 256
  5. #9380
    NW New Jersey
    Quote Originally Posted by flipsk12 View Post
    Yes both the drive wheel and tracking wheel are crowned. I cant speak for the drive wheel but the tracking wheel was made at 3 degrees. We'll see if its enough. If its not I built an arbor that
    I can press into the wheel and change the angle. Everything I could find was saying to crown them at 3 degrees. I also made adjustment to the idler wheel hinge so you can further adjust tracking. That helped immensely.
    Should I maybe just do a build thread?
    I did one for my positioner and it was lost in the great wipeout of 2018.
    Yes, a build thread would be good.
    I've been searching all over for that positioner build thread, do you still have any pictures. I almost have all the parts needed to build one. It would be great if you could repost some of the pictures.
    Did yours use a dart dc motor controller with a 13 rpm gearmotor?
    Keep up the good work, your pictures are great.
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
    Primeweld 225 ac/dc
    Primeweld mig180
    Miller AEAD-200
  6. #9381
    Feb 2012
    mine was a 16rpm and then a 3:1 on gear reduction. I think 13 would be just fine. Looks like I'll do two threads. Pm me with any questions.
    Sent from my SM-G920T using Tapatalk
  7. #9382
    Oct 2011
    france
    Quote Originally Posted by lost_in_tx View Post
    Thanks ! Yeah, hopin' this one will last for a while !
  8. #9383
    Feb 2012
    Those look awesome
    Quote Originally Posted by Gamble View Post
    And done and shipped
    Attachment 1698018
  9. #9384
    Feb 2019
    Austin, Tx
    Well, this only involved some soldering, but in light of the day, hopefully you'll cut me some slack. My artistic and romantic quotas, such that they are, have been met for the year.
    Andy
    Everlast 256
  10. #9385
    Mount Tabor VT
    My mentor made friendship rings for himself, and his girl. A belt, with buckle. Precise like a jeweler might, but his carved from solid silver. After his death, 50 years later she showed them off proudly.
    I'm impressed with your work, as I was with his. If you want her to wear it, scale it down.
  11. #9386
    Mar 2013
    Savannah, Ga.
    A 52ft ladder/flote level indicator that had to be done by Monday
    Sent from my Pixel 2 using Tapatalk
  12. #9387
    Jul 2018
    Cumbria, UK
    In progress
  13. #9388
    Oct 2011
    france
    Nice corners and welds munkul ! I'm gonna have to build something similar for my new drill press (a base)
    My (slow) progress
  14. #9389
    South Central Kansas
    Nice fitup on your corners Munkul. What are you making?
  15. #9390
    Sep 2015
    West coast of Florida
    Quote Originally Posted by colindstark View Post
    Nice fab work, and shop
    Richard
    Website
  16. #9391
    Jul 2018
    Cumbria, UK
    Quote Originally Posted by gnewby View Post
    thanks good accurate mitre bandsaw to thank. I mitre all the joints I can, just to avoid unsightly end caps. The outside edge gets TIG welded so it gives a softer corner, easier to make it look good than MIG.
    It's a frame for a 40kw tractor driven generator. Still got the hitch frame to make.
  17. #9392
    Jul 2018
    Cumbria, UK
    castors on and test mounted
  18. #9393
    Jul 2018
    Cumbria, UK
    Quote Originally Posted by uintas View Post
    My (slow) progress
    That's gonna look good when it's finished! I assume all the pegs are for hanging clamps etc from?
  19. #9394
    Nov 2014
    PDX PNW
    I’m guessing that bench is getting slats instead of a big single plate
  20. #9395
    Jun 2016
    SE Saskatchewan, Canada
    Completed this pair of "treating vessels".
    Will be used as a prototype and "proof of concept" for a customer involved in food and beverage process.
    A couple of other shots of nice welds.
    Red Seal Journeyman Welder (2003), Red Seal Journeyman Metal Fabricator (2018), Welding Engineering Technologist (2005)
    Pressure - ASME Section IX
    Structural - CSA W47.1, CSA W47.2
    Transport tanker - CSA B620
    Aerospace - AWS D17.1
  21. #9396
    Apr 2013
    Looks great
  22. #9397
    Oct 2011
    france
    Thanks and no, they're actually bolts to mount and adjust the ("slats" i think you call them) to make a welding table top. There are already 2 mounted on the left and right, i need to go and buy the rest now ...
  23. #9398
    Oct 2011
    france
    oups, sorry munkul, motolife had already answered ! Yes that's exactly what it is
  24. #9399
    Feb 2012
    Built up one of my fab horses yesterday. Pretty slick little build kit. Stout finished product.
  25. #9400
    Feb 2019
    Austin, Tx
    One thing I've learned from making stuff is humility. Worked on my table today, trying to flatten out the top. Youtube convinced me its easy. Reality showed me its not. I started with a MAP gas torch, but decided that was not hot enough. With the Oxy torch, I started around the edges and worked towards the bulge in the middle. While I did get rid of some of the bulge, but ended up creating some depressions.
    Name:  2019-02-20 17.15.07.jpg
    From the bottom, you can see I have quite a bulge to remove. Since its over the cross members, maybe I should just drill some holes in the sheet and plug weld it. I still need to deal with some bulges, but maybe not as much. The top will be be completely covered with a laser cutter, so it not make too huge a difference whether it is dead flat or not. If need be, I'll make leveling mounts for the laser cutter.
    Name:  2019-02-20 17.15.28.jpg
    Name:  2019-02-20 17.40.11-rotated.jpg
    For next time, how would a professional fabricator handle welding the sheet to the frame to avoid warping? Plug welds along the cross members from the center out, and then along the outside, working from center to the corners?
    Thanks,
    Andy
    Everlast 256
Page generated in 1,713,266,177.52385 seconds with 19 queries
