Page 441 of 540 FirstFirst ... 341391431439440441442443451491 ... LastLast
Results 11,001 to 11,025 of 13500
  1. #11001
    Re: Show us what you welded today!
    I just got one also when clicking on #440...
    But obviously this page #441 works...
  2. Likes 12V71 liked this post
  3. #11002
    Started on another battery box for a camp trailer.
    Mostly 1 inch x 1/8th angle iron for the frame, 2 inch for the two long members and I got a couple sheets of 11gauge steel from my buddy to skin it with the 11 gauge would have been plenty strong even without a frame but I get more support this way as it will be mounted on the two outermost bottom cross pieces.. not sitting flat on anything.
  4. #11003
    Got a chance to work on the batt box again after work today.
    Tacked in a piano hinge.
    Busted out the plasma to finish cutting the sheet panels... much easier and quicker
    Welded on some links for padlocks. Just gotta sand it up and throw some paint on er'
  5. Likes Lis2323, 12V71 liked this post
  6. #11004
    Got the rear wheels on:
  7. Likes scsmith42, Capt B, Lis2323 liked this post
  8. #11005
    Cool, those wheels are a good size match... Makes for a nice mobile look.
  9. #11006
    These homemade hubs are a real time suck. I need a lathe something bad.
  10. #11007
    Looks like an anhydrous ammonia tanker
  11. Likes ronsii, TimmyTIG, Weldalittle, 12V71 liked this post
  12. #11008
    Dec 2014
    Northern California
    Slap an engine on that thing and you got a beast!
    Been following the build...looks awesome...need to eventually see some output photos of consumables...
  13. Likes LtBadd, scsmith42 liked this post
  14. #11009
    Outside of Raleigh, NC
    Thatís looking great!
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
  15. Likes TimmyTIG liked this post
  16. #11010
    Thanks, SC! I'm liking the way it's turning out, too. Hopefully I can get the front wheels on today. I thought I was gonna have to go with steering rods, but that firebox is like a big ol' counterweight on the other end, there's not gonna be that much weight on the front, I think I can get by with a rigid axle with a central pivot point. Be a lot less work and figgering.
  17. #11011
    Jun 2009
    New York
    Thats very similar to the steel angle iron that i pick up in my neighborhood on garbage night. you can always find those old bed frames being put out for trash. it isw a great source of cheap angle iron for small projects around the house. For non critical uses, like home security frames for windows, or a frame to support an ammo box jeep center console, its ok.
    Millermatic 211
    Everlast 200DX
    Thermal Arc 181i
    Klutch ST80i lunchbox stick welder
    Lincoln Weld-Pak 100
    Century Stick welder
    Powermax 30 plasma cutter
    Henrob 2000 torch
    Logan 200 lathe (60 years old)
    Clausing 6339 Lathe (for sale)
  18. Likes ronsii liked this post
  19. #11012
    Quote Originally Posted by yesindeed View Post
    LOL!!! This is all A36HR just a lot of it has a pre-patina storage finish on it I always wirewheel the stuff before welding but it still messes with the welding process of ER71tgs wire... but if I took the time to grind all the patina in a weld fusion zone I'd never get anything done
  20. #11013
    Here's another quick fix had to do with minimal grinding... the ramps on our big tex trailer take a real beating everytime the cx60 gets on and off And it would appear that during the construction of the ramps they did NOT grind the edges of any of the cut sheet products... because anywhere there is and edge weld there is a crack running the length of the weld exactly(within a thousandth of an inch) where the edge of the sheet is...
    Had to add some reinforcing bars to the ramps where the 'ramp feet' come back up into the back of the ramp for support while the load is on the hinge point, the original weld is a 'T' intersection tack weld
  21. Likes Lis2323 liked this post
  22. #11014
    San Jose, CA Kelseyville, CA
    ronsii,
    A couple of Qs for you. Not being a professional fabricator it's taken me some time to learn, but I do keep picking up things as I go...I started to fix a hitch a year or two back and then thought I used the wrong concept so went to confer with a fabricator. I thought it was brilliant that he added a piece of diamond plate behind the frame I stick welded, so he was able to save my work (that made me feel good in itself as I had completed about 50% of the work). He did kinda like you have on this diamond plate where he welded 2" strips spread out about every 6 inches, and I know I most likely would have tried to weld the entire seam even if I had thought to add the diamond plate. He explained to me that it didn't need any more weld and would only warp the plate by welding the entire seam. Warpage is something I need to understand better, but kind of learning. How do you determine how much weld is needed for a given task? Do you just guess?
    Also, I was curious, is that fugly rebar how Big Tex did that originally? Why not use a plate on top of the angle, similar to how the one was done on the corner behind that weld?
    I've seen some pretty poorly built trailers, some of the vendors seem to have some pretty tight pockets in regards to structural design, and this doesn't seem to be isolated to any one vendor. Was this rebar just someone else's crappy repair?
  23. #11015
  24. Likes 12V71 liked this post
  25. #11016
    Quote Originally Posted by TraditionalToolworks View Post
    ronsii,
    My beautimous piece of rebar is not stock I put it in just as an intersection piece where bigtex normally had a 1 inch long fillet weld along two pieces of sheet. here you can see the green line... this is where they put a little fillet weld to handle 1/2 the entire load the ramps take! well needless to say it doesn't last long.. as the top of the weld cracks out quick and then it's done.
    My point on the DP sheet cracking was I'm pretty sure they didn't prep the cut edge which was more than likely plasma cut and would have had a nitride edge coating thus leading to the mass cracking on every weld.
  26. #11017
    Morton, Washington
    Now it's a proper farm trailer.
  28. #11018
    Sep 2015
    SE Pa
    Is the distance from tires to fire box going to cause problems?
    Looks good
  29. #11019
    There's about a 3 inch gap. I figure I can either put a shield of some sort outside, or put fire bricks inside to stop the heat. Gotta fire it up and see what's needed.
  30. #11020
    Maybe fenders?
  31. #11021
    I don't think it's gonna get all that hot right there, heat rises. Most of the fire will be further back towards the door. See what happens when I do the first cook, I can always throw a piece of plywood in there temporarily, if need be.
  32. #11022
    Jan 2011
    W. Wisc
    Heat doesn't rise, hot air does - convection. The problem you MAY run into is the heat radiating from the firebox as the steel gets hot and radiates out which is where the risk of cooking the tires comes from. Radiation doesn't rise, it just goes directly outward. Metal fenders with an air gap on both sides would probably do the trick as a heat shield, if it is an issue. As you say, you can try it first and see how it goes... or put on fenders and be safe if you like. Either way, I'm sure you got it covered...
    -Dave
  33. Likes TimmyTIG, timrb liked this post
  34. #11023
    Iím surprised you used just a center leg.... instead of 2 uprights.
    ... just an observation, not a criticism.
    Looks good.
  35. #11024
    I’m surprised you used just a center leg.... instead of 2 uprights.
    Looks good.
    I considered that, and it was going to be a whole lot more work. So I decided to give this a try, first, just to see how well it would work. And, it turned out to work really nicely, so I'm leaving it. I pulled it all around the yard with the riding mower, and it tracked like a dream. I could even pull it around in the grass pretty easily by hand, without the mower.
  36. #11025
    Feb 2009
    Central CA
    Nevermind
Page generated in 1,634,442,215.96541 seconds with 14 queries
