Page 503 of 682 FirstFirst ... 3403453493501502503504505513553603 ... LastLast
Results 12,551 to 12,575 of 17039
Thread: Show us what you welded today
  1. #12551
    Nov 2014
    PDX PNW
    Re: Show us what you welded today
    Any decent weldor knows that. Thank you. 4th page is your weld that looks like you need some more practice
    https://weldingweb.com/vbb/showthrea...and-wire-speed
  2. #12552
    Started on my cannon today... Nah it's just an irrigation transition. I did remember to check my makings for the 6" lateral though. I love that marking tool. Name:  20210210_064552.jpg
Size:  101.4 KBName:  20210210_070824.jpg
  3. Likes ronsii, VaughnT, whtbaron liked this post
  4. #12553
    Also swapped some strap winches on a hay trailer, the driver wanted the winches on the rear. I managed to salvage the hooks but had to destroy the winches to get them out of the way. Name:  20210209_121837.jpg
Size:  82.9 KBName:  20210209_121805.jpg
  5. Likes ronsii, ezduzit liked this post
  6. #12554
    That's pretty cool. I take it you can slide the divider arm up and down the verticle rod?
  8. #12555
    Yep and the pointer rod is adjustable to "shoot" angled openings too. Big time saver.
  10. #12556
    It looks like it's easy to use a very accurate for that type of work. I once had to cut a 48" opening in a quonset hut and utilized a sliding divider type setup. Amazingly after cutting the pipe fit with less than 1/8" gap anywhere.
  11. Likes 12V71, ronsii liked this post
  12. #12557
    Re: Show us what you welded today!
    502 fix.
  13. #12558
    502 fix.
    Not yet... Check page 502
  14. Likes ronsii liked this post
  15. #12559
    Yeah, ran into that earlier on a couple different threads... I'm on the dirt job so just cel phone... Can't do too much
  16. #12560
    I've used this thing to fit a 12" pipe to a 24" pipe at 45 degrees. It's really accurate if you take the time to be careful with it.
  17. Likes ronsii, Joegreen02 liked this post
  18. #12561
    I'm in the office with the laptop. Got no idea what to fix though.
  19. Likes ronsii, whtbaron liked this post
  20. #12562
    Nov 2014
    PDX PNW
    Here ya go ronsii and I did weld most this box up including the big side one under the hydraulics There’s hydraulics under the bed in front on the gate alsoName:  ABD0E4DE-DA99-4CE6-9CEF-FB9503F271CC.jpg
  21. Likes ronsii, 12V71, whtbaron liked this post
  22. #12563
    Those boxes look familiar to me, they have a brand name? Just curious. Had a couple of Crysteel boxes on Kenworths from Portland that looked a lot like those without the high lift gates.
  23. Likes ronsii liked this post
  24. #12564
    I think that is the same brand of box we have on the kw is... It's from down south could be just a similar design though...
    Trying to beat the snow and get this pad in.... Really bad clay here
  25. Likes 12V71 liked this post
  26. #12565
    [QUOTE=12V71;8799976]Also swapped some strap winches on a hay trailer, the driver wanted the winches on the rear. I managed to salvage the hooks but had to destroy the winches to get them out of the way. Name:  20210209_121837.jpg
    I got smart... I cant find that style of strap hook anywhere, so I traced one out and and am having the CNC plasma guy at my steel supplier make me up about 40 of them. I think these were OEM to the trailer builder, but the truckers love them compared to the ones you can get off the shelf.
  27. Likes ronsii, ezduzit, motolife313 liked this post
  28. #12566
    [QUOTE=12V71;8799999]
    I saw that hook in your earlier post and wondered about the design...
  29. #12567
    [QUOTE=ronsii;8800001]
    Yeah, they can hang the "D" ring in the bottom and give the strap a good jerk from the other end and it stays hooked. The "double C" types don't always hold the ring when you jerk the strap.
  30. Likes ronsii, whtbaron liked this post
  31. #12568
    Ooh. Smart. I like those.
  32. Likes 12V71, ronsii liked this post
  33. #12569
    [QUOTE=Lis2323;8800008]
    Maybe I should have more made and sell a few?
  34. Likes ronsii liked this post
  35. #12570
    [QUOTE=12V71;8800014]
    That's what I would have done.
    At the very least have a stack on hand to sell "installed".
  36. Likes 12V71, ronsii liked this post
  37. #12571
    [QUOTE=Lis2323;8800020]
    "installed" was the idea of 40 units. Paul says that once he enters the program it's mine for as many as I want in the future.
  38. Likes ronsii liked this post
  39. #12572
    Take orders. Then you won't be tying up money.
    Minimum order set of 40.
  40. Likes Joegreen02, ronsii liked this post
  41. #12573
    Word of mouth with the hay haulers will be enough.
  42. Likes ronsii liked this post
  43. #12574
    Here's a back view of ours from today
  44. Likes ezduzit, 12V71, whtbaron liked this post
  45. #12575
    Jul 2018
    Cumbria, UK
    ooooooooooooooooohhhhh!
    *makes schoolgirl sound hearing a catty remark*
Page generated in 1,713,304,987.66997 seconds with 20 queries
