Page 518 of 523 FirstFirst ... 18418468508516517518519520 ... LastLast
Results 12,926 to 12,950 of 13069
  1. #12926
    I one exactly what you mean. I do the same thing at times.
  2. #12927
    Finally had an actual welding project show up at the shop today.
    Installing a hitch on a huge disc harrow so they can pull their choice of implements behind it. I also get to run hydraulic lines from the hitch to the front. Name:  20210503_140314.jpg
Size:  103.8 KBName:  20210503_140329.jpg
  3. Likes ezduzit, Munkul, whtbaron liked this post
  4. #12928
    You’re gonna get spoiled working on new equipment. And all topside no crawling on your belly.
  5. Likes 12V71, Weldalittle liked this post
  6. #12929
    Apr 2013
    Marina del Rey
    He can just pull up a chair and do it.
  7. Likes 12V71 liked this post
  8. #12930
    Quote Originally Posted by ezduzit View Post
    Actually there is a bunch of on your knees overhead stuff on this one. And boy, new stuff is nice. Hasn't been bent or rusted or twisted...
  9. Likes ezduzit, Munkul liked this post
  10. #12931
    Apr 2013
    Marina del Rey
    You're going to be too spoiled to go back to real work.
  11. Likes 12V71 liked this post
  12. #12932
    Rats... got the structural stuff done today and had a truck come in for a laptop hookup and forgot to take pics. I'll get some tomorrow, got a big box of hydraulic parts to finish the whole job anyways.
  13. #12933
    The thing I see most, is how people add plate like that, but only weld the perimeter. They don't realize that plate flexes, and the middle needs a weld to develop full strength. Nice to see it done right.
  14. #12934
    UPS finally got here today around noon with my hydraulic components, grrr. Got it all mounted up and measured out for hoses, should have a bundle of hoses in the morning and it's off to the races. 38 feet of disc ought to be a good test for a 500 hp John Deere track tractor. Name:  20210505_132941.jpg
  15. Likes Lis2323, ezduzit, whtbaron liked this post
  16. #12935
    What's the folded transport width?
  17. #12936
    I never thought to measure that. I would estimate right at 14 feet.
  19. #12937
    Got this one first thing this morning, kind of ugly. Really rusty thin wall pipe with a split that was probably caused by a line of rust pits.
    Cut a patch from some 10 gauge pipe and shape it to fit, after brushing the heck out of the pipe. First pass looks pretty cobby but the objective is to float the rust out of the base and NOT BURN THROUGH.
    By the second pass there's a bit more mass to burn in a good weld without the chance of burn through.Name:  20210511_071824.jpg
    On the 3rd pass you can get brave and carry some more weld down to the pipe.
  20. #12938
    Apr 2013
    Marina del Rey
    Nice repair, but I think you're fighting a losing battle on that one.
  21. #12939
    I hear you, been doing these repairs for years. That field has young spuds that need all the water they can get for another 30 days and that patch job may last out the season until September. These guys have replaced nearly 10 miles of old steel with high pressure PVC, what they have here is about 100' of the old steel that has the tie in to the circle pivot. Once the spuds get well established they will have a 3-4 day window to replace that section with 1/4" wall epoxy coated pipe. They have been replacing 4-5 of those sections every winter.
    Oh, the above repair was done with 1/8" 6011C at 72-74 amps off my Trailblazer 302.
  22. Likes ezduzit liked this post
  23. #12940
    And I got a start on the next project. Name:  20210511_143156.jpg
    Building two of these to a custom width.Name:  20210511_102951.jpg
  24. Likes ezduzit, whtbaron liked this post
  25. #12941
    Aug 2018
    Been in a structural steel class for work. Eventually I'll take my 3&4g test to get certified, would like to get pipe to, but way things are looking won't get there. Lol. Bit rusty to say the least.
  26. #12942
    Sep 2020
    VT
    I've been helping a friend make a cage for the pigs he'll be getting soon. He wants to be able to lift it with the forks on his tractor, or tow it around on skids. He will be adding some plywood for the floor, and sheet metal for the roofing.
    Glen
    Hobart Champion 16
    Miller XMT 304 CC/CV toasted
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
  27. Likes Shootr, Lis2323, whtbaron, LtBadd liked this post
  28. #12943
    Colorado Springs
    Love the bacon bobsled. Nice work.
    Sent from my SM-G975U1 using Tapatalk
    Lincoln 175
    Monkey Wards 230v. Stick
  29. #12944
    Aug 2018
    Todays practice piece. 1 inch plate,3/32 7018 root pass, second went to 1/8 inch 7018 with a weave. Alot better, but still not happy.
  30. Likes 12V71 liked this post
  31. #12945
    Sep 2020
    Lima, Peru
    Again, it's trivial, but I'm learning to build my own miniature scaffolding. I found some small rails that will allow me to gain access to finish the cement work I still need to do overhead. Construction
    As I'm just learning to weld and do metal work.... in trying to make the first pole for the scaffolding, I did this:
    Name:  1 vice.jpeg
    So, I fixed the broken vice with this:
    and with this vice, i was able to make the support poles and the locks to attach them.
Size:  82.3 KBName:  2 on.jpg
Size:  138.5 KBName:  1 unfinished.jpg
    Once I get the floor finished and the cement sets, I have a floor mount I'll be able to put the vice on, because my first project will be a simple welding table, using the 4"x4" leg RCA building table frame, until I'm able to get (build) a proper welding table. I'm thinking 3'x7' with the holes for clamps. not sure how thick, though. It might see a lot of heavy work.
  32. Likes 12V71 liked this post
  33. #12946
    Bilbao, Spain
    Quote Originally Posted by Mr.GfC View Post
    Again, it's trivial, but I'm learning to build my own miniature scaffolding...
    Some things are cheaper tu buy than to build. Plus, you will be confident the thing is not going to collapse when you are working on it way above the ground. I bet you can find used scafolding for sale somewhere close...
    Mikel
  34. #12947
    May 2021
    Landrum, SC
    Big Oops, one is a 1" and the other is an 1 1/2". Got them cut off and still have to prep and fab the replacements. More to follow.
    Name:  186513729_280405523779834_8450496134685618701_n_fb2b66b2b03e173c503b5c8aa57759f9bb45ccfb.jpg
    Name:  185510339_280405520446501_521109971569923735_n_7426cac3ff14af45ceca1c1279b62820361887b4.jpg
    Lincoln 330 MPX
    Modified Tombstone
    Lincoln Activ8X / LN-25X-TVT
    Magnum PRO 250LX GT Spool Gun
    ¼ Ton of Torches OFC-A / OFG-A
    SMAW FCAW GMAW
  35. #12948
    Quote Originally Posted by Freebirdwelds View Post
    What is that part of?
  36. #12949
    May 2021
    Landrum, SC
    Excavator Grapple
    Lincoln 330 MPX
    Modified Tombstone
    SMAW FCAW GMAW
  37. #12950
    Excavator Grapple
    Aha. Thanks !
  38. Likes Freebirdwelds liked this post
Page generated in 1,624,572,821.20070 seconds with 14 queries
