Page 530 of 535 FirstFirst ... 30430480520528529530531532 ... LastLast
Results 13,226 to 13,250 of 13361
Thread: Show us what you welded today
  1. #13226
    Apr 2018
    Re: Show us what you welded today
    That is a smart question, i don't know yet because DOT in north texas inspect trailers just one time a month, i will take the triler this week to metal scrap company to scale the total weight substracting the original Weight equal the weight that i add
  2. #13227
    Mount Tabor VT
    Sean, an extra son started the project of refurbishing a 9 ton trailer. He added about 25 more lights than it had originally. Each group of lights were cut into holes on a flat surface. To accomplish this, he added several pieces of channel steel. I figure hundreds of pounds added to a trailer only marginally big enough in the first place.
  3. #13228
    Nov 2014
    PDX PNW
Size:  39.4 KBlooks ok
  4. Likes ezduzit, 12V71, farmersammm liked this post
  5. #13229
    Quote Originally Posted by cordoba View Post
    I upgrade my trailer to 16,000 lbs dump trailer
    using a few tools, mig welder, chop saw, clamps, two grinders and a lot of metal
    How does it handle a heavy load when dumping? It looks niceName:  tkqe4fh-smiley-two-thumbs-up175028_285604.gif
  6. #13230
    Apr 2018
    I just tested with 7,000 pounds load and trailer handled it like piece a cake, i have not chance to dump more than that yet but i think will be easy dump 13,000 lbs, if you see in video I reinforce the center and back side of the platform dump area (box) where the load stress more when dumping
  7. Likes farmersammm, whtbaron liked this post
  8. #13231
    Kewl!!
  9. #13232
    Southern California
    Very nice!
    Be prepared for the flood of requests to help with this or that. Most of my family and friends have immediate access to a pickup truck these days, but none of them have a dump bed setup!
  10. Likes cordoba liked this post
  11. #13233
    Feb 2016
    Oregon
    Very nice!
    My help would be limited to helping them back up to put the trailer on their truck hitch.
  12. Likes N2 Welding, VaughnT liked this post
  13. #13234
    Aug 2018
    I didn't get a picture of it,but the other day at work we had to put in a temporary metal wall for a shield. Used some sheet metal probably 1/8 inch. Just grabbed what was available cut it to fit the holes and welded it in with some 7018. I picked the bad side to run. I basically had to weld "blind" on one panel. Second panel was flush so it was alot easier. When I left work this morning the "wall" was still there so I'll call it a win,win.
  14. #13235
    Nov 2014
    PDX PNW
Size:  96.4 KBName:  20210809_130228.jpg
Size:  76.7 KBName:  20210809_143051.jpg
Size:  86.9 KBName:  20210809_143126.jpg
Size:  83.1 KBthe down hill welds are dual shield. We keep running into lots of porosity going down on the frame here with hard wire. Not sure the problem, even triggering makes bubbles come out when the weld I'd cooling. I cleaned all the edges where plasma was. Dual shield doesn't get contaminated. I'm thinking maybe a machine problem. The straight up butt joint is tricky. I'm moving very fast for it, running 23.6 volts on hard wire and 25 on core. Any ideas on what could be causing the contamination. I run into the same problem on the front gusset welds. The down hill wants to get bubbles. I can see the bubbles in the weld floating as I weld
  15. Likes ezduzit liked this post
  16. #13236
    Nov 2014
    PDX PNW
Size:  92.9 KBName:  20210809_142955.jpg
Size:  85.4 KBName:  20210809_143110.jpg
Size:  85.7 KBName:  20210809_143230.jpg
Size:  101.9 KBnow time to take 2 weeks off because my little boy has covid supposedly, he's been playing with the fish tank water last week or so, I'm thinking it's that.the sides are single wall on this one so far. So you gotta move quick or the boss will be upset if it sucks the base metal in on the outside. Probably about double the speed I'm used to doing 3/16 to 3/16
  17. Likes ezduzit liked this post
  18. #13237
    Apr 2013
    Marina del Rey
    ...my little boy has covid supposedly...
    Hope he heals quickly.
  19. Likes motolife313, Lis2323, whtbaron liked this post
  20. #13238
    Well, it's been one of those weeks... At least I got it working again, we'll see for how long.
    Attachment 1729833
    Attachment 1729836
    Welding fail! Should have been in the other thread but I thought I'd do a followup on this one in case somebody else was in the same boat. How long did my welding job on the ACME rod last? In this case about a week or until I really pushed on it again... just by hand, no hammers or extensions, which is how I broke it the first time. I suspect some cracks from old abuse. I stole a Chinese 6" vise out of the Waldo shop to replace Rae for now. I thought about borrowing the ACME rod, and it was the same size/pitch, but the actual threads are a different width so it was in the no-fly zone unless I modify the nut as well. It was also shorter so RAE is in the "project pile" for now and we'll see how long the Chinese vise lasts on the welding bench. Had to space it up a half an inch to clear the table since it's a shorter style.
    Cut 50 Plasma
    Iím surprised that RAE doesnít have a larger support shelf for the dynamic jaw.
    I seem to remember them being more substantial.
    But then again maybe thatís just my (habitual) wishful thinking. LOL
  22. Likes whtbaron liked this post
  23. #13240
    There was actually a big chunk broke off there when I got it... I ground it smooth to make it look better, but yes, there definitely should be more support there. I'm still surprised that 7/8 rod broke though... makes me wonder just how much abuse it took in it's previous life. Maybe someday I'll replace the ACME rod with a regular stainless one and use an extended nut to build a new nut... I could put a receiver on it for the welding table again.... I'm guessing regular thread would be painfully slow to open and close though...
    Cut 50 Plasma
    Usually justifiable, but exes always get a bad rep.
  25. Likes whtbaron liked this post
  26. #13242
    Today I UNwelded the slip on bracket for my Miller Maxstar (that I sold recently).
    I used some 14 gauge steel sheet to form the "tip-slide-drop" tray to secure my new Fronius Transpocket.
    Here it is mocked up on an existing welding cart. I will weld in a shelf support for it tomorrow.
  27. #13243
    Apr 2016
    CA
    Sure would be nice having a break to do bends like that. Looks good.
  28. #13244
    Jul 2018
    Cumbria, UK
    How do you like the Transpocket? Notice much difference between it and the maxstar, or too early to tell?
    I'd like a transpocket tig, the stick set I used was great on TIG but just missed having HF and a gas solenoid. The menu setup was very intuitive. It also has that really nice TAC function that I wish my Lorch had.
  29. #13245
    N 48į 38.680 W 080į 40.837
    I'm not a welder, but sometimes I have to do these things because I am too cheap to buy an item. I wanted a trailer ball quick hitch for my little (35hp) tractor, something I could back into a trailer, pick it up with the 3-pt hitch, move it across a yard and set it down etc. I bought the ball carrier so that I can use it on the road and not worry about liability. The rest is mine. Believe it or not, my TIG welding is improving with practice. I could have MIG'd it and had lovely smooth beads, but that's no challenge. It may not be pretty, but the welds are deep and strong.
  30. #13246
    Yes too early. I am hoping it will be as nice as my XMT 350 which I also sold.
    I donít know what manufacturer they use for their external electrical connections ( cables, Dinse, amphenol and wall plugs) but they are by far the nicest and best fitting I have ever encountered. Quality control is unbelievable.
  31. #13247
    Jul 2018
    Cumbria, UK
    It'll be close... they're all really good
  32. #13248
    Aug 2009
    Trinidad
    lil backyard bench
    MM 180
  33. Likes jniolon, John Bartley, LtBadd liked this post
  34. #13249
    Mar 2004
    hueytown, ala
    like the design but that metal seat would become a griddle here in Alabama in August
    j
  35. #13250
    Aug 2009
    Trinidad
    luckily it gets shade where it is there from the afternoon sun
    otherwise the hose is there to cool it down if anything lol
    Quote Originally Posted by jniolon View Post
    j
    MM 180
Page generated in 1,632,680,161.02410 seconds with 13 queries
