Page 534 of 541 FirstFirst ... 34434484524532533534535536 ... LastLast
Results 13,326 to 13,350 of 13525
Thread: Show us what you welded today
  1. #13326
    Re: Show us what you welded today
    Attachment 1731283Attachment 1731284welded the sub frame and that's a straight up over head weld in the middle. Taking the floor down now. Going to be running some dual soon
    Nice!
  2. #13327
    Nov 2014
    PDX PNW
Size:  71.5 KBName:  20210917_143055.jpg
Size:  54.8 KBName:  20210917_143205.jpg
Size:  68.5 KBName:  20210917_143131.jpg
Size:  64.6 KBwent pretty good today
  3. Likes ezduzit, whtbaron, Lis2323 liked this post
  4. #13328
    Not much welding in this one... more metal carving. I needed to add a micro switch to my tractor's GPS so it would turn on and off with the PTO lever to get an accurate measure of the amount of field sprayed. The switch came with a generic one size fits all magnetic base that wouldn't work with a plastic dash full of gauges, so it was time to doctor up something strange to hold it.
    It came with one magnet, but I thought the extra leverage could be a problem, so I scavenged another one off a dead rotating beacon. With the switch attached, this is what things looked like.
    One idiot light is partially blocked, but it's the one for the air filter and I blow it out daily. I haven't had it come on in the field in 35 yrs so I don't think it's an issue. Working around the existing levers, steering column and light switches made things interesting... only below the dash is metal for the magnets.
    A quick test flight around the yard showed that it did indeed turn the mapping on and off with the PTO engagement, so success so far. I might end up making another version with stronger magnets if it won't hold on rough ground in the field.
    Cut 50 Plasma
    Nov 2004
    Southern Montana
    Well done.
  6. Likes whtbaron liked this post
  7. #13330
    Apr 2016
    CA
    I was working on a mini tractor earlier. A JD 316 and I had to make a part to support some hydro lines for a little 30 hydro tiller. It's not much but going from images out of a user manual I think I did ok. First pic is what I was trying to duplicate the rest is my progress making it.
    Name:  hook for 30 tiller hydro lines.jpg
    Name:  30 hydro tiller hook 1.jpg
    Name:  30 hydro tiller hook 2.jpg
    Name:  30 hydro tiller hook 3.jpg
  8. Likes whtbaron, Lis2323 liked this post
  9. #13331
    Apr 2021
    Made some pinewood derby - sorry, "pinecar derby" (since this is unsanctioned by BSA or whatever they're called now) - trophies out of some crap wrenches and other scrap laying around. I still need to write "1st Place Overall" on both then clear coat the walnut bases. It was a fun, quick project that our church youth group and primary kids will hopefully enjoy (only had time to make a 1st place trophy for each group). Sorry if the pic is rotated, or if you can see them at all with all the mess in the background .
    Name:  Pinewood Derby Trophies.jpg
  10. Likes robocow liked this post
  11. #13332
    Mar 2004
    hueytown, ala
  12. Likes whtbaron, robocow liked this post
  13. #13333
    Apr 2021
    Thank you kind sir - what is this wizardry to rotate the photo?!
    Quote Originally Posted by jniolon View Post
  14. #13334
    Mar 2004
    hueytown, ala
    I use Paint Shop Pro... I just copy the pic off the forum, paste it into PSP and the rotate it 90 degrees, save and repost
    I use an old version 5 that I was used to for years... easy to learn and play with
    http://www.oldversion.com/windows/paint-shop-pro/
  15. Likes whtbaron liked this post
  16. #13335
    Picassa is another old Google program available at oldversion.com. It's very simple to use and gives you some primary photoshop options without the headaches of learning the Photoshop program. Easy for resizing files that are too big off your camara too.
    Cut 50 Plasma
  17. Likes jniolon liked this post
  18. #13336
    All this hi tech talk. I don't own a desktop or a real camera.
    I don't even understand the "resizing" comment.
    I suppose it's a good thing I only have my small phone camera,huh?
  19. #13337
    Well there's certainly nothing wrong with the quality of your pictures, so keep doing what you are doing...
    Cut 50 Plasma
    This morning I needed a right angle impact wrench for a close quarter area, so I built one. The 5/8" nut keeps the air hammer punch on target. Name:  20210920_102342.jpg
Size:  86.9 KBName:  20210920_102329.jpg
  21. #13339
    Later got to go weld some irrigation pivot feet back down.Name:  20210920_130512.jpg
  22. Likes whtbaron liked this post
  23. #13340
    Nov 2014
    PDX PNW
Size:  38.3 KBName:  received_384165686572320.jpeg
Size:  40.3 KBName:  received_342161264358284.jpeg
  24. Likes whtbaron, ezduzit, 12V71 liked this post
  25. #13341
    I like the punch guide!
  26. Likes Mac's Crew, CAVEMANN, 12V71, Vern1 liked this post
  27. #13342
    I really like that reinforced tower structure design.
    Welds are “beauty”
  28. Likes ezduzit, motolife313 liked this post
  29. #13343
    Nov 2014
    PDX PNW
Size:  51.7 KBName:  received_2386596308142394.jpeg
Size:  28.8 KBName:  received_184950393718227.jpeg
Size:  37.8 KBthe boss welded above the side and top set of welds on dog house. Gota weld the inside of it tomorrow had a little issue today with the core wire wanting to run cold and trap the slag. Usually I blow the wire off but didn't today. Figured maybe a wire problem or shielding gas, it wanted to run cold mid weld and pop on the slag, stopped the first time after a couple inches and burned it in 2nd and third time. It seems to be eating cups too. The boss wanted to not trust me about it at first and gave me ****. We had a big problem with the machine a while ago and then the other machine wire feeder gave us problems. it's going through the cups. I'll start getting small holes in the weld and it will get worse and worse. You can actually get away with making a small weld but were welding dump trucks lol. The boss can make the worn out cup work. He does a fast whip and pause. I watched and when he pulls the wire out of the puddle and it under cuts the base metal then he fills it in and gets a nice flat wetted bead. But that's not my style. When I notice those bubbles I just get a new cup and not a hole after that or hours of grind welds.
  30. Likes ezduzit, Lis2323 liked this post
  31. #13344
    Sep 2021
    USA
    Re: Show us what you welded today!
    A pic of what i welded today.
  32. #13345
    Pics or it didn't happen.
  33. #13346
    Sep 2021
    USA
    I didn't weld anything today. It was a joke. (:
  34. #13347
    Sep 2021
    Two stage shaker table for arrowhead hunting.
    First sifter is 3/8" expanded metal, second sifter is 1/4" hardware cloth to catch bird points and small chips and artifacts.
    Cheers,
    Vern1
    Terminal Tinkerer and Voider of Warranties
  35. Likes whtbaron, ezduzit, BD55, Lis2323, 12V71, VaughnT, rhunt liked this post
  36. #13348
    Sep 2021
    Here less than a hour and already learning how to make more cool and necessary tools!
    Thank you for sharing, Sir!
    Cheers,
    Vern1
  37. #13349
    Pensacola , Fla
    Always interesting to see what others do for work or fun, different areas of the country and world produce different things. Thanks for sharing you never know what may get someone off the couch and into the shop.
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  38. #13350
    Sep 2015
    West coast of Florida
    Nice, I'm using version 7 still works on my win 10 desktop.
    I remember they offered at one time a version as shareware, that's where I first started with them
    Richard
Page generated in 1,635,100,546.58427 seconds with 13 queries
