Page 535 of 542 FirstFirst ... 35435485525533534535536537 ... LastLast
Results 13,351 to 13,375 of 13532
Thread: Show us what you welded today
  1. #13351
    Mar 2005
    Under a Rock
    Re: Show us what you welded today!
    Quote Originally Posted by Vern1 View Post
    Two stage shaker table for arrowhead hunting.
    Very nice.
    Do you have any pictures of the counter balance / shaker mechanism?
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  2. #13352
    Sep 2021
    Very nice.
    Here is a shot during mockup stage. The "flywheel" is a 50 pound barbell weight from Academy.
    The shaft is standard 1" gokart axle I had laying around that was chopped down to make idler and crank shafts.
    The hole in the weight was 1-1/16 and not well centered so I chucked it in lathe and centered/cleaned it out to 1-1/8 and used shim to center on 1" axle. I used a gokart hub keyed to shaft on each side for support and ease of mounting.
    The flywheel took most of the shake out of the machine and it runs amazingly smooth.
    Shot of other side showing crank assembly.
    It's another gokart hub keyed and welded to shaft with a 3/4" bolt set at 1" offset for 2" total stroke.
    The table swings from top suspended on 12" links and the double belt reduction gives 112.5 strokes per minute with motor running at 1800RPM.
    The small pulleys are 3" and large are 12" and I use a simple cam-over lever to tighten belt and engage the shaker.
    The original heim joint on crank is still alive after 10 months of hard use - we have a pillow block to replace it but it's still working so...just lube it!
    Video of test run #3.
    Cheers,
    Vern1
    Terminal Tinkerer and Voider of Warranties
  3. Likes 12V71, whtbaron, Munkul liked this post
  4. #13353
    Nice work
  5. #13354
    Got some pics of Monday's project. Rusted out vertical pivot pipe. Of course it's a custom fit thing. Pretty easy though, got all the wiring out of the way today, pick up parts monday morning and get to it. Name:  20210924_134401.jpg
Size:  84.7 KBName:  20210924_134528.jpg
  6. Likes ezduzit, Lis2323 liked this post
  7. #13355
    Mar 2021
    Near Roanoke, VA
    I think I would have fixed that with Flex Seal,,,,,,,,,,,
  8. Likes 12V71 liked this post
  9. #13356
    You see the JB weld under the collar at the top? Seriously. That and a long clamp and innertube got a spud crop grown this season.
  10. #13357
    Mount Tabor VT
    Looks like somebody already did.
  11. Likes 12V71 liked this post
  12. #13358
    Mar 2021
    Near Roanoke, VA
    Are you gonna bury a couple of sacrificial blocks, and wire them to the replacement that you install?
    The guys will come back in 10 years and wonder why your part looks like brand new,, and everything else got older,,
  13. #13359
    It's been tried. Not much difference. this pipe is in the 20 year old range, which isn't bad for the application considering the chemicals they pump through the systems.
  14. #13360
    Mar 2021
    Near Roanoke, VA
    AHHHHHHHH,, chemicals,,, magnesium will not help with chemicals,, and fertilizer,,,
  15. #13361
    Mar 2005
    Under a Rock
    Made a pedestal for Fido.
    Hypertherm PM 45
    HTP 221
  16. #13362
    Sep 2021
    USA
    I helped my neighbor weld some plates on the bottom of his air compressor tank legs today so he could bolt wheels on it. Sorry i didn't have a phone so no pictures. I'm not sure i want you guys seeing my welds anyway, although they are not bad for a amateur
    Lincoln Pro MIG 180
    Chicago electric 225 Arc
    Harris oxy fuel
    Everyone who calls on the name of the Lord will be saved. Romans 10:13
  17. #13363
    JB weld is great for repair industry. You see JB weld now what charge goes up.
    QUOTE
    1) remove JB weld
    2) clean where JB weld was.
    3) smell from cleaning JB weld off the part.
    4) use welding to do job right
    Now a happy customer 😀 with job done right.
    You happy for big pay day.
    Win Win
  18. #13364
    QUOTE
    1) remove JB weld
    Now a happy customer �� with job done right.
    Win Win
    Dave, there is nothing left to weld to. Replacement of the pipe is the only fix. I didn't get to that one today, it rained and the wind blew pretty hard. No crop in the field so not a big rush.
  19. #13365
    That thing looks more like Kujo than anything I've ever seen. Was that the effect ya was lookin' for??
  20. Likes John T liked this post
  21. #13366
    QUOTE
    1) remove JB weld
    Win Win
    But Dave, I'm a great JB Welder, and it's soo much easier to grind...
    Cut 50 Plasma
  22. Likes N2 Welding, 12V71 liked this post
  23. #13367
    I kid you not... I was in the local garage yesterday and there was an electrician's work van on the hoist. The brake line had been repaired with JB Weld.... so there, enough with the farmer fix jokes from you sparky guys!
    Cut 50 Plasma
  24. Likes 12V71, Lis2323, farmersammm liked this post
  25. #13368
    Yes it is!!!!... apparently.
  26. Likes whtbaron liked this post
  27. #13369
    Got out from the truck repairs today and got the pivot riser pipe chopped out and the new one installed. 3 hours onsite. Name:  20210929_095310.jpg
Size:  133.0 KBName:  20210929_095259.jpg
  28. #13370
    All ready for next year
  29. Likes 12V71 liked this post
  30. #13371
    Yup, it will probably do a couple more revolutions to get some moisture in before winter, and maybe some liquid cow poo for fertilizer and draw the lagoon down at the dairy. These guys have 2 different pipeline systems for both.
  31. #13372
    My friend used to grow turf near Spokane. I think he got his water from the Alcan settling ponds that were waste water from cooling during production I believe ?
  32. #13373
    Alcan, or Alcoa, Alcoa had a rolling mill out on Trent avenue that used a ton of cooling water. I do seem to remember a turf farm out that way.
  33. #13374
    Yes. Probably Alcoa. I think it was their land too. He had to knock down all the sand dunes I think. Long time ago....
  34. #13375
    Apr 2016
    CA
    Made some more progress on the suitecase weight bracket today. Tried to purchase two of the spring loaded keepers for the top of the bracket locally but the place was sold out. Have an offer in on ebay for a couple. In the meanwhile I am using a couple of 5/8" bolts to hold it in place for mock up and welding. The bolts hold it on there in place so it won't shift around and warp while welding it up. This is all I could get done before 10pm. Shut it down at 10. Tomorrow is another day.
Size:  50.0 KBName:  5784680A-0F35-488B-8FCA-784119845188.jpg
Size:  72.4 KBName:  2B5FF0DF-79AA-410D-9993-2DC95D721F6F.jpg
Size:  89.6 KBName:  E3389E0B-172E-4DB6-8167-00D2FEBB8C91.jpg
Size:  66.4 KBName:  E654AA3A-C2AD-4495-95D9-09A01D8EA4F3.jpg
  35. Likes ezduzit, Shootr, whtbaron, farmersammm liked this post
Page generated in 1,635,138,024.54386 seconds with 13 queries
