Re: Show us what you welded today
Originally Posted by
whtbaron
I was deep tilling on a Friday night... long weekend (Canadian Thanksgiving) so I was cursed. Broke a retaining pin in the deep tiller that I had welded before... probably about 3 or 4 yrs ago.
Attachment 1732067
Decided this time I would try the magic rods I bought to fix the CAT loader and see if they last any longer than the 7014 I likely used last time. Not much room to work due to the design and it has to be ground down to fit so I can't add reinforcement. Good news is that this is the only one I've broke so I'll have to grab a couple new ones for spares. Pretty blue rods go well with the Dialarc.
Attachment 1732068
Attachment 1732069
Snug fit but a little persuasion from the BFH got me back in business.... holding good so far...
Attachment 1732070
Attachment 1732071
I guess I never noticed, but do you own a milling machine and lathe? Be a fast fix to just make another pin (unless you happen to be me, and insist on making it to ISO 9001 standards, which would get it back in the field sometime in 2025 at my pace)
farmersammm
No milling machine or lathe... but I'm really good with the grinder. I was thinking about that too. If I could find a length of shaft material close to the right diameter, I could just drill it and be back in business. I might try it yet, but for a Friday night on the long weekend this was the quick fix. My only concern with a softer material is that instead of a clean break, it could bend before it snaps and be realllly difficult to get out of there. For most machines I have a pretty good stash of spare parts, but this one is a bit of an odd duck and I haven't found an exact match for a parts machine.
albrightree
Yes, I'm sure they will, they rarely disappoint me that way. It's for a sheet metal cover over 2 - 12"x16" cartridge filters on a powder dump station.
I guess its kind of job security. There is no end to fixing while the "inexperienced", and the "over eager" roam the plant with 8000lb fork trucks, or big vise grips and hammers .
Done using a Primeweld MIG180 scratch start in MMA mode :
Attachment 1732153
Set a 54 amps DC, 3/32"tungsten #6 gas lens 20 cfh Argon, 1/16" 308 filler , 1/8"x 1-1/2" Flat bar 304 s/s
An all too familiar concept. Ain't much electrical that'll stand up to a gorilla on a fork lift, loader, or excavator. You can train a monkey to drive a heavy machine, then it'll drive like a monkey.
Post Thanks / Like - 6 Likes, 0 Dislikes
Here’s the bend test piece that didn’t break
Miller 350 Dynasty
Miller Trailblazer
Miller 625 Plasma Died and needs a new circuit board so its an expensive boat anchor now
Lincoln Power MIG
Victor oxy/acetylene
Hyperthem 85
Post Thanks / Like - 8 Likes, 0 Dislikes
welded the su frame on this one and came out real good no bubbles.ran those welds end to end with no stopping, need to work on the last few inches on the weld. Had to trigger one of the straight up butt joints in the channel because there was a big gap. Ran all the rest out and it went good.
BluCllrPlt
Stormy here all day so decided to get in a little TIG practice. The “soccer ball” is 12 gauge steel. Did some of the welds with 309 SS just for practice. The Texas logo star is 16 gauge steel welded with 1/16” 309. Also made up an aluminum 3D star made from .125” 6061 welded with 3/32 4043. Did a little butt joint practice on .125 6061 using 4043, 4943 and 5356. The 4043 was the only one that would not stay together during my amateur U bend test.
How do you cut out the shapes for those projects? Do you buy templates or patterns? Or are you just good at geometry?
Lincoln Pro MIG 180
Chicago electric 225 Arc
Harris oxy fuel
Everyone who calls on the name of the Lord will be saved. Romans 10:13
The bosses pulled me in the office today after the morning meeting to tell me I've been doing good listening and the welding inspector wants to see me weld on the outside again. Red paint was thick on the hardock and not much wire wheeled off so it was popping a lot and filled the cup with berries and had to stop couple times but came out pretty good and the boss was happy and said she will like it
1 set of the back welds, core wire weld on the right
motolife313
No way.... is that a feeder with a proper built trolley I see, for once? Not a shopping cart?
Nice work btw
Post Thanks / Like - 3 Likes, 0 Dislikes
With that tank, save yourself a lot of grief in the future by putting in a drain, for water and crud, and even consider a large inspection plate?
Yep, there is a drain port on the bottom. I just didn't really mention it. The photo with the tank all tacked up actually shows it on the bottom (tipped on its side in photo). And the baffle is set up to allow it to fully drain from both sides. As for inspection ports, I have the big 6" port for the inlet filter that can act as one on one side of the baffle, and another 2" hole where the fill port is on the opposite side of the baffle. 2" is enough to look in but not enough to do much with. This should be a closed system, and probably not used too heavily so I am hoping for few issues or need for changing fluid.
I was expecting someone to say my welds were too hot...
-Dave
davec
I did better on the short sides as I made up a support out of 3/4" pipe, a pair of pipe flanges and a pair of Tees. The tees are 3/4" on the "Tee" side but 1" on the 2 thru sides so it would slide over a 3/4" pipe. I drilled and tapped a 3/8" hole on the outside of each Tee so I could lock it in place wherever I want. Worked pretty slick
And then the tank all complete and pressure testing. It didn't fully hold pressure, but the only leaks were at my temporary plugs as I checked all the welds with soapy water and they were all good. So it should be good to go!
Xsbank
++ on the inspection plate,, and look around, and find the biggest magnet you have,, put it in the tank, near the suction port.
You will be amazed how much the magnet will capture inside the tank,,,
If you can not find a big magnet, several small ones will work, also,,
I think TSC still sells cow magnets,, which are also good for hydraulic tanks.
SweetMK
I had to Google that. Thought maybe they attracted cows... like farmersammm
Yeah I was planning to put a rare earth magnet in the drain port plug which is near the suction port. Maybe I should do it another way?
-Dave
Attached to some sort of dipstick so you can take it out and clean it off without the need to drain the tank?
---Meltedmetal
whtbaron
You'd be surprised to find that a lot of pins aren't as hard as you think. The fact that this one is machined, leads me to think it's not very hard.
You can make a new one out of Fatigue Proof.....NOT Stress Proof, and you'll have a very high tensile pin that's easy to machine, and doesn't require post machining heat treatment to bring it up to hardness, or other desirable trait.
Fatigue Proof was developed by Niagra for this type of work. Other companies have simply copied the chemistry, and sell it as 1144 "Stressproof".......and it ain't the real deal. Even the color is different. Try to buy actual genuine Fatigue Proof, or Stress Proof. It should come with mill certs. I source mine from Alro, but I'm sure it's available from other suppliers.
This stuff is the real deal http://www.niagaralasalle.com/produc...gue-proof.html
Looks like cart is still in use.
Is that a special filter, or is it really that smokey in the shop ?
BTW Nice Welding.
Miller Synchrowave 180 sd
Miller Econo Twin HF
Lincoln 210 MP
Dayton 225 ac/dc
Victor torches
Snap-On YA-212
Lotos Cut60D
Primeweld 225 ac/dc
Primeweld mig180
Miller AEAD-200
farmersammm
So you're saying I'm not going to find that in an old shaft on an abandoned combine in the pasture?
Cord reel. 12 gauge 100’.
