Page 565 of 587 FirstFirst ... 65465515555563564565566567575 ... LastLast
Results 14,101 to 14,125 of 14653
Thread: Show us what you welded today
  1. #14101
    Apr 2013
    Marina del Rey
    Re: Show us what you welded today
    That crack occurred from bending too sharp a radius.
  2. Likes drillerjoe, metalman21 liked this post
  3. #14102
    Nov 2014
    Southern CT
    Quote Originally Posted by ezduzit View Post
    No doubt bending aluminum causes micro fractures on the outside of a bend. I repair a lot of these type of coolers and vibrations along with a possible stressed connection often is the cause. I think this one is in a pavement roller - extra shake-rattle-roll.
    Ernie F.
  4. #14103
    Nov 2014
    PDX PNW
    Little bit on this boxName:  20220126_152930.jpg
Size:  81.1 KBName:  20220126_152925.jpg
Size:  73.2 KBName:  20220126_152954.jpg
Size:  55.6 KBName:  20220126_153010.jpg
  5. Likes whtbaron, ezduzit, 12V71, Lis2323, Don52, Shootr liked this post
  6. #14104
    That's more overhead than I want to do... ever. Looking good Moto...
    Cut 50 Plasma
    You and me both... Anymore getting my arms above my shoulders just plain... Hurts.
  8. Likes William McCormick liked this post
  9. #14106
    Oh, yeah. I actually had a welding job in today. Cylinder lug torn off a big box scraper, 3/4" plate, you can see the notch that started the tear, hopefully the gussets will hold it for another 30 years.
Size:  107.4 KBName:  20220127_130410.jpg
Size:  107.4 KBName:  20220127_130319.jpg
Size:  107.1 KBName:  20220127_130350.jpg
  10. #14107
    Mount Tabor VT
    I wasn't aware a machine such as that existed. The tractor tows it must have at least eight tires? Looks to be a remarkable piece of engineering.
  11. Likes whtbaron, drillerjoe liked this post
  12. #14108
    You could pull it with a 2 wd if you were content to take really small bites, but yea, you would really want a 4wd with at least 250 hp on there. By the looks of the required welding, they've had some power on it. We had to replace the hitch on a 5.5 yd push-off scraper after somebody put too much horsepower on it. They are quite common in the Red River Valley where the terrain is unusually flat.
    Cut 50 Plasma
  13. Likes 12V71 liked this post
  14. #14109
    Feb 2019
    Snyder TX
    I have a 10' box blade like that, I pull with 160 HP 2 wheel drive. Can't fully load it up, but most roads & turn rows are packed so it runs about 1/2 full.
  15. Likes 12V71, whtbaron liked this post
  16. #14110
    I had a 12 foot Schmeiser like this one
    I used it for light leveling /seedbed prep in peat soil with a under 100 HP tractor, FWA and duals front AND rear.
    Purchased new from a Washington state dealer near 12V IIRC.
    A big hydraulic cylinder on the rear roller was used to remove weight onto the transport wheels but I added two cylinders for blade lift too.
  17. Likes 12V71 liked this post
  18. #14111
    That manufacturer is less than 20 miles from my location in same county.
  19. Likes Lis2323 liked this post
  20. #14112
    This one has 18 feet of cut, they pull it with this 530 horsepower Monster.
  21. Likes whtbaron, Lis2323 liked this post
  22. #14113
    Nov 2013
    san antonio tx
    More fencing stuffs. Lots more to do yet
  23. Likes 12V71, whtbaron, ezduzit liked this post
  24. #14114
    Nov 2013
    san antonio tx
  25. Likes whtbaron, ezduzit, farmersammm liked this post
  26. #14115
    That's nice work. I know of 2 Ranches here that have done 14 miles of replacement corner posts and rotted out rock jacks using 2" galvy and a rock drill. They did all the corners very similar to yours.
  27. Likes drillerjoe liked this post
  28. #14116
    Mar 2021
    Near Roanoke, VA
    Oh, yeah. I actually had a welding job in today. hopefully the gussets will hold it for another 30 years.
    Is that built out of the same steel as the bridge in Frick Park that fell today??
    It looks similar, except, your grader has more paint,,
    You should quote fixing that bridge.
    (the Frick Park Bridge was Cor Ten,,,,,,,,,,,,,,,, )
    I guess Cor Ten and snow-salt do not mix,,,,,,,, Who (besides anyone!!) would guess salt is bad for Cor Ten ??
    The pres will fix it,,,,,,, he was there today,
  29. Likes drillerjoe, Roert42 liked this post
  30. #14117
    I have had some experience with Cor-Ten, It is a "self painting" steel meaning it will develop a tight rust that stops the weathering process... But overlapped riveted joints etc. that collect moisture and salt will just keep rusting internally. I've talked to a couple of "Engineer" types that consider Cor-Ten rustproof, WRONG, but they have degrees. Oh well, this is the result.
  31. #14118
    No matter the material , rust jacking is issue. I've seen the buildup get almost an inch thick before. Anyway I'm sure Brandon will take advantage of any and all photo-ops provided he can remember where he is.
  32. Likes 12V71 liked this post
  33. #14119
    Mount Tabor VT
    Bridges have a long life expectancy, maybe my suggestion won't work. My old C65 had a rust jacking problem in the two layer frame. Experts told me it'd be ten years before it'd lead to frame failure.
    The "new" truck has a single layer frame I can pressure wash & paint. Wherever anything is bolted to it, it got putty knifed on Texaco Compound L Rustproofing Grease. All layers are sandwiched with this gunk. Been using it since 1974 with good results. A 1971 Jeep body was showing signs of early rust, I buttered underneath, and even on the surface anywhere rust showed through the paint. These many years later, it took a ride in raging flood waters, the frame is ruined, but the body remains solid.
    Might a product like this limit rust between layers on a bridge?
    Silver Bridge just above my house, was built in 1933. Its support members were a massive steel I beam truss assembly each side of the deck. It is owned by Green Mountain National Forest. A few years back Fed engineers decided the deck was deteriorating. It was made of concrete slabs most of the rebar in them running crossways of the bridge, supported by the massive trusses. The rebar inside the concrete wasn't treated for rust prevention & 1-1/2" diameter rebars were rust jacking, breaking concrete. Trusses, galvanized, were good as new.
    Instead of Cor Ten, why not galvanized bridges? New bridges cost many millions, why not stainless steel rebar in the concrete, or at least galvanized?
  34. #14120
    Nov 2013
    san antonio tx
    Thank ya sir. I think there are 12 more slight turns to make for this one. I believe this is only a 100 acre area
  35. #14121
    Nov 2013
    san antonio tx
    Put this simple entry in here today. I will be hanging a gate there and installing a cattle guard on the caliche road section.
    Do not adjust your screen, yes that second Gen has a full dash top.
    You may also be inclined to have a peek but I assure you, under that truck you will not find a leak.
  36. Likes 12V71, whtbaron, Lis2323 liked this post
  37. #14122
    Nov 2013
    san antonio tx
  38. Likes whtbaron, 12V71, ezduzit liked this post
  39. #14123
    Nov 2013
    san antonio tx
    Only thing left is the cattle guard.
  40. Likes whtbaron liked this post
  41. #14124
    I read up on matching the rod material to the base material to be welded, I went with a large rod because of the sloppy fitment and the ground is on shiny metal. I've tried AC, DC, standard and reverse polarity and I've upped the amperage to 250, but I'm still having problems striking an arc. Suggestions?Name:  IMG_7650.jpg
    Cut 50 Plasma
  42. Likes arcflash, okw liked this post
  43. #14125
    Apr 2016
    closer than i got to any welding today.....
  44. Likes whtbaron liked this post
Page generated in 1,652,974,788.66595 seconds with 13 queries
