Page 609 of 613 FirstFirst ... 109509559599607608609610611 ... LastLast
Results 15,201 to 15,225 of 15309
Thread: Show us what you welded today
  1. #15201
    Sep 2015
    West coast of Florida
    Re: Show us what you welded today
    Everyone knows what gorilla welds are?
    Ugly but strong
    Richard
  2. #15202
    Dec 2020
    Virginia, USA
    Ugly but strong
    That seems to be the theme with folks on The Forum.
  3. #15203
    speak for yourself, please
  4. Likes 12V71, whtbaron, 52 Ford, xmmancharl, shortarc liked this post
  5. #15204
    Yea.... probably not that strong anymore....
    Cut 50 Plasma
  6. Likes N2 Welding liked this post
  7. #15205
    Brethren, Mi
    I got some that have much better appearance, those were simply showing how to heater up. Guy can get distracted with personal lessons.
  8. Likes xmmancharl liked this post
  9. #15206
    It is a good weld.
  10. #15207
    Brethren, Mi
    Found these 2 pieces I had made for temp deal 30 yrs ago, maybe more. At the time we never considered a grinder or any way to do this but a torch. Wanted a 3/4 draw pin and 7/8 hole. Well 13/16 . Today had to really look after some time and weather to see this all hand cut in couple minutes, only finish was chipping hammer.
  11. #15208
    Dec 2020
    Virginia, USA
    I just really got into using magnets for positioning. I almost always use clamps and squares.
    Well, I learned something... actually 2 things... that black layer between the two pieces of steel on a welding magnet is PLASTIC (rubber?). Also, the fumes from that black layer burning are enough to really screw up a weld.
  12. #15209
    Nov 2014
    PDX PNW
    Can’t get it that close to the weld or it will pull the wire into the magnet. I’m surprised you got the magnet to that point
  13. Likes xmmancharl liked this post
  14. #15210
    Dec 2020
    Virginia, USA
    Canít get it that close to the weld or it will pull the wire into the magnet. Iím surprised you got the magnet to that point
    Stick welding - if the magnet is big enough to bend a 6011, I'd be afraid to be near it. Plus, I was welding a corner joint on pretty thin metal. I DID notice a bit of funky arc blow and I do know that was from the magnet, I expected that.
    I never considered that it'd pull welding wire around, though. That's really interesting! I might have to try that... probably been 2 years since I plugged in the MIG... maybe a year and a half. Total, I probably have 20 hours on a MIG machine couldn't count the hours on a stick machine. I just never took the time to get proficient with wire welding.
    Like I said, I never really used magnets before. Just decided I'd try something different. I didn't expect I'd have to learn how to use a freakin magnet. LOL
  15. #15211
    Nov 2014
    PDX PNW
    I used to have a problem even getting a tack on with mig at my last job, if the magnet was too close. You were hear the metal undercut from the wire getting dragged a crossed it too fast towards the magnet. I’m surprised you stick weld if u got a mig. I got a lot to learn with stick, I was just thinking about firing one of mine up yesterday, I got 3 stick welders
  16. #15212
    Brethren, Mi
    For a real career welder wants to move around good stick skills are outstanding. Same for use of a torch.
  17. Likes motolife313, xmmancharl, 52 Ford liked this post
  18. #15213
    Dec 2020
    Virginia, USA
    I used to have a problem even getting a tack on with mig at my last job, if the magnet was too close. You were hear the metal undercut from the wire getting dragged a crossed it too fast towards the magnet. Iím surprised you stick weld if u got a mig. I got a lot to learn with stick, I was just thinking about firing one of mine up yesterday, I got 3 stick welders
    I was tought to stick weld when I was really young. Just seems easier to me. Once you get your technique down, welding 16 gauge or thinner isn't a problem.
    I didn't realize how out of practice I am till a few days ago when I was welding some 14 gauge. 2 or 3 years ago, I was welding up 16 gauge exhaust pipe without an issue. Just 3/32 6010 and 6011. I started with the wire welder, then decided I was better off with the stick machine LOL
    I've just never taken the time to REALLY learn MIG.
  19. #15214
    Mar 2005
    Under a Rock
    Drag it outside on a nice day and burn some rod. nothing more satisfying than seeing a 4" caterpillar of 7018 slag curling up off a hot weld bead.
    I need to fire up my old Idealarc also.... love that machine.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  20. Likes ArcTan, IAMsteelworker, whtbaron liked this post
  21. #15215
    Feb 2015
    Texas
    Welding up these display bases and after a dozen or so get burned out on the squirt gun and decided to play around with some aluminum. Butt welded these pieces with 4043 and put in the vise to check the quality. I make a lot of steel stars but the aluminum ones are more fun and lots of practice. Pieces are .125 6061 and welded with 4043.
    Miller 350 Dynasty
    Miller Trailblazer
    Miller 625 Plasma
    Died and needs a new circuit board so its an expensive boat anchor now
    Lincoln Power MIG
    Victor oxy/acetylene
    Hyperthem 85
  22. #15216
    Jun 2016
    Quote Originally Posted by BluCllrPlt View Post
    nicE trick bending the aluminum first and then tig welding back together in the vice!!! LOL
    lincoln 125sp
    dayton 250 ac/dc
    miller 211 w/spool gun
    ahp 200 sx tig
    lotos ltp5000d
    kubota b3200 FEL BH
    of course duramax diesel
  23. Likes 52 Ford, LtBadd liked this post
  24. #15217
    First job in 2 weeks that required welding, Had a Cat C15 in yesterday with 4 broken exhaust manifold studs. Used the wirefeed to build up the broken stud and then welded a nut to the nub. All of them were broken off 1/2 a thread in.
Size:  95.0 KBName:  20220819_060918.jpg
Size:  67.8 KBName:  20220819_061031.jpg
  25. #15218
    Mount Tabor VT
    And the victory is sweet!
  26. Likes 12V71, labparamour, 52 Ford liked this post
  27. #15219
    Apr 2016
    CA
    took me a couple weeks to complete but it's done and drying now. Explorer Seat Bracket to Bronco floor board.
  28. #15220
    Oct 2019
    Australia
    Gettin' some roots dye pen tested
  29. #15221
    Dec 2020
    Virginia, USA
    Nice. How long are you gonna let those welds dry for?
  30. #15222
    Like the dye pen test.
    Quote Originally Posted by Woznme View Post
  31. #15223
    Nov 2014
    PDX PNW
    Uphill 1/4Ē weld from today. We donít weld uphill often. The last time was probably the last pic I posted hereName:  76CF5F8C-ACE9-4DBA-BFD4-4D41A8B7D57F.jpg
  32. #15224
    Oct 2019
    Australia
    Caps dye pen tested. All good.
  33. Likes whtbaron, LtBadd, Lis2323 liked this post
  34. #15225
    Apr 2016
    CA
    plenty dry by now. its already been bolted up for a few days now.
  35. Likes 52 Ford liked this post
Page generated in 1,664,051,865.77224 seconds with 13 queries
