Page 6 of 682 FirstFirst ... 456781656106506 ... LastLast
Results 126 to 150 of 17039
Thread: Show us what you welded today
  1. #126
    Re: Show us what you welded today!
    Quote Originally Posted by jamesyarbrough View Post
    some stairs and hand rail for the local baseball field. because the elderly were having a tough time stepping up 21 inches to get in the bleachers.
    Thanks for helping us old guys out, like the corners. Are you gonna close up the opening ??? I can see kids jumping in and out and having a good ol time. Or even grandpa cutting in front of grandma.
  2. #127
    Dec 2012
    Denison TX
    yeah I still got some work to do on the railings but it was time to roll up.
  3. #128
    Nov 2013
Size:  59.6 KBName:  image.jpg
Size:  69.3 KBName:  image.jpg
    Made some step bars for a willy's jeep today. Not mine though.
    Miller trailblazer301g
    Lincoln sa200
    Miller251
    Miller spectrum 625
    Victor oxy-acc
    2002 Chevy duramax 3500 dually 4x4
  4. #129
    Ontario, Canada
    I was off work today so i welded up a bracket for our 3 ton axle stands, i still got to build a bracket for the 6 ton stands eventually.
  5. #130
    Jan 2014
    That looks awesome. Thanks for sharing. Looks like a lot of work.
  6. #131
    Apr 2012
    Montreal area Canada
    Good idea, you did quality work on that , now get rid of these chains they spoil everything , your structure with a little gusset will be over rated for its job... Wall anchors will be the weak link. Name:  photo-70.jpg
  7. #132
    Nov 2012
    new york city
    these doors take lots of abuse. the mounting bracket is only attached to the top door rail by 5 spot welds and they break after prolonged kicking and slamming. after chopping off damaged sheet metal with a 4 1/2" cut-off wheel i re-positioned the bracket and welded it with 3/32 7018 at 100 amps. i then put a sheet metal cap over the welded bracket and then skip welded it to the door with 3/32 6010 at 65 amps. pics #'s 2 and 3 should be reversed. the center picture is the finished product. sorry for the poor picture quality. i took them with my flip phone.
    i.u.o.e. # 15
    queens, ny and sunny fla
  8. #133
    Ontario, Canada
    I was going to make gussets for it but i did'nt have enough steel laying around but i did have the chain so i just used that. The 2 lags that will be attached to the angle iron would be enough to hold the load but the top brace would make it a bit more secure. I finished painting it and mounted it to the wall this morning.
  9. #134
    Feb 2013
    Ontario
    Here is what I've been doing the last few days.
    They are for portable bleachers. The company has 75, and these took it to 80 sets.
    Miller 252
    Miller Bobcat 225
    Lincoln MigPak 180
    1959 Hyster forklift
    Harris OA torch
  10. #135
    May 2011
    did you pinch teh tubes down instead of coping? can't really tell from the pics
  11. #136
    Nov 2012
    new york city
    from where i sit the tubes look flattened. nice work. did you use a jig?
    i.u.o.e. # 15
  12. #137
    Feb 2013
    Ontario
    I don't have the right equipment to cope them......but I do own a sledge hammer
    Yep they are flattened just a little. And I used one of his old frames as a jig.....minor alterations and we were good to go.
    Miller 252
    Miller Bobcat 225
    Lincoln MigPak 180
    Harris OA torch
  13. #138
    Dec 2012
    Nassawaddox Va
Size:  58.3 KBName:  IMG_0425[1].jpg
Size:  87.7 KBName:  IMG_0469[1].jpg
Size:  55.3 KBName:  IMG_0436[1].jpg
    been working on my fire companies new brush truck build a hose bed and a little header cart repair too.
    Miller Bobcat 255
    Hobart 190 and spoolgun
    Lincoln AC 225
    Lincoln LN-25
    Rock and Roll hoochie coo
  14. #139
    Nov 2013
    Nice job on the brush truck. I had to mod some side boxes to fit beside a tank on ours. My guess is that's why you made these right?
    Lincoln sa200
    Miller251
    Miller spectrum 625
    Victor oxy-acc
  15. #140
    Jan 2014
    Made this so I could Wok outdoors. 210k btu burners, gets the job done.Name:  ImageUploadedByTapatalk1390321619.062897.jpg
Size:  19.2 KBName:  ImageUploadedByTapatalk1390321634.877523.jpg
    All bent 11 ga sheet metal besides the legs. Rolled the wind deflectors for the burners out of 11 ga also. Legs fold down so it can be used as a turkey fryer or fish boil as well. Valves are under the front tray. Side shelf (on floor in 2nd pic) attaches to hold your ingredients. Have a stainless griddle that covers the top as well.
  16. #141
    Saint Cloud MN
    Razor blades with my thumb control, .035 308 filler.
    Millermatic 210
    Esab 450I
    Thermal Arc 400 GTSW
    1972 SA200
  17. #142
    Utah
    That'll hold.
  18. #143
    Dec 2012
    Nassawaddox Va
    yeah the old brush truck was a regular tool body reading box and i chopped and narrowed the hose bed to accomodate the new super duty ford i put it in.
    Miller Bobcat 255
    Lincoln AC 225
    Lincoln LN-25
  19. #144
    Jun 2013
    BIG SKY COUNTRY
    My landlord owns a grocery store, he uses several of these carts for putting out freight:
    It was used as a "sawhorse", and someone cut most of the way through the closest bar with a Sawzall. (Sorry, did not take a "before" picture. Use your imagination.)
    So I used one of these to weld it:
    I laugh when I read about people needing lots and lots of amps. Paralleled machines, huge electrodes. Hiroshima, Fukushima, etc. Most of my work is done using more modest settings. This is as low as the Millermatic will run, I call it "Puppy Love".
    Here is the end result, cant tell where it was cut. Repainted with "Miller Blue", heat lamp to dry it.
    Hobbyist, bored, wee hours, etc......
    Hobbyist - At what point is a "hobby" out-of-control?
  20. #145
    Dec 2009
    Stevens Point, WI
    Welded in plugs yesterday.
  21. #146
    Nov 2013
    Iowa, USA
    We had some floor drains with covers made of plastic and when I drive over them with the forklift they break so I started to make some out of steel. I forgot to take a picture of the plastic one. But here is the steel one I made yesterday. Name:  image.jpg
Size:  109.1 KBName:  image.jpg
Size:  91.9 KBi painted the top orange to see them better. They are made from diamond plate less than 1/4 holes punched and thin pipe welded on the back
  22. #147
    Apr 2012
    Quote Originally Posted by VPT View Post
    Looks like a Ford 6.0 EGR?
    Bruce
  23. #148
    Jul 2012
    Gosnell, Arkansas, United States
    Here's a pic of my first descent tig bead I did last Thursday for my Right Handed Tig test. Made an A!!!
    Hobart Stickmate LX 235 AC
    Everlast Powerarc 140ST DC Inverter
    Powcon 300ST
  24. #149
    Dec 2009
    Stevens Point, WI
    Quote Originally Posted by Bruce Avison View Post
    Bruce
    Yeah I figured everyone has seen one of those by now, even chevy and dodge guys.
  25. #150
    Apr 2010
    Weird, was just going to google "Welding EGR" haha. Can't see myself spending $nearly $300 for a delete "kit" when I own a $4000 welder haha thanks for that, any tips?
Page generated in 1,713,282,979.75374 seconds with 19 queries
