Page 588 of 600 FirstFirst ... 88488538578586587588589590598 ... LastLast
Results 14,676 to 14,700 of 14998
  1. #14676
    My old man rarely gave me compliments and I worked with him every day until he died
    He had high standards and his expectations were that everything was to be done right. (probably from his stint in the army)
    Silence was his form of praise.
  2. Likes Kirtman0405 liked this post
  3. #14677
    Seward, Ak
    Quote Originally Posted by IAMsteelworker View Post
    Yeah I'm not sure if it was or not. If it was someone did a decent job hiding it. No evidence of being welded before to the eye.
    The piece on the left looks like there is some undercut from another weld, where this break happened
  4. #14678
    Seward, Ak
    Quote Originally Posted by ArcTan View Post
    It will make more sense tomorrow. It's an adapter to increase a 6" pole to 8" for a small solar array. The 6" pole is already mounted in concrete I presume, so this will be welded to the top of it to allow an 8" pole mount to be installed.
    Thanks. Unfortunately Go Fund Me hasn't funded a PAPR yet. I wore my regular respirator and kept my head far enough away that the cross breeze took away most of the smoke.
    "Go fund me" The millennial version of the organ grinders monkey, with sunglasses holding a tin cup
  5. #14679
    PDX PNW
Size:  70.5 KBwhy I think guys should use core wire at home and you can weld little small stuff with it. .045 core wire at 25 volts and about 300 wire speed. 3/16 plate overhead weld. Usually I run hardwire here but last 2 boxes I ran the core wire. Really tough to run it downhill tho. I’ve learned to long arc it to make it run colder downhill.
  6. Likes whtbaron, Lis2323, ezduzit, Don52 liked this post
  7. #14680
    Fenders on the welder cart today
  8. #14681
    You should sell those.
    Very nice.
  9. #14682
    Very nice.
    with all the stuff he has built and sold lately ^ this was my though as to why he is building it.
  10. #14683
    Jeeeesus!!! You got that much free time, I'd put you to work.
  11. Likes whtbaron, LtBadd liked this post
  12. #14684
    May 2022
    Barbados ����
    Re: Show us what you welded today!
    Nicee....When I Always Have Problems Cleaning After Welding Up Handrails...Speaking Of Round Bar Though...I Think I Gotta Start My Welds A Different Spot🤦🏾*♂️
  13. #14685
    May 2022
    Barbados ����
    Now That's Clean....How'd You Get Your Measurements?
  14. #14686
    Dec 2020
    Virginia, USA
    I like it! Have ya thought about a spring loaded latch for that swingy-outy bit? One less thing to drop on the ground and bounce up under the workbench.
  15. #14687
    that was the plan but the only ones I had in my parts room were too big and I didn't feel like going to the store
    so i went full blown farmer fab lol
  16. Likes whtbaron liked this post
  17. #14688
    Dec 2020
    Virginia, USA
    Nothing wrong with that! I have a bunch of those "hex head pins" kicking around. A lot of them have cross pins made out of bent stick electrodes.
    "It ain't stupid if it works!"
  18. Likes Lis2323 liked this post
  19. #14689
    Modified forklift LPG tank clamps for securing my welding cart tanks. Used weld on hinges
    this cart is taking a while. Limiting myself to one part/section a day to prolong the fun
  20. #14690
    Oct 2019
    Australia
    That's a really nice cart. An enormous amount of time goes into a nice tricked up cart like that, but once it's done it's there for life and shows off your skills to anyone that comes through your shop. You also see it every day with pride and it can become a family heirloom even. Fitting addition to a well organised shop with top notch tools and gear in it.
  21. Likes N2 Welding, Roert42 liked this post
  22. #14691
    Sep 2020
    VT
    Lis, your work is so nice it makes my project look like junk... Oh wait it actually is
    Repairing/improving my ripper that I broke last fall.
    https://weldingweb.com/vbb/threads/3...23#post8837323
    Glen
    Red-D-Arc EX300 (Miller XMT304)
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
  23. Likes ezduzit, motolife313, 52 Ford, albrightree liked this post
  24. #14692
    That’s nice work, AT!. I’ve modified lots of loader buckets but never had to do any heavy repairs like that.
  25. #14693
    Thank you, Woznme!
  26. #14694
    Dec 2020
    Virginia, USA
    I like that clamp setup. A lot better than a piece of chain or a ratchet strap.
    Have you considered a standing platform behind the cylinders and some electric motors on the wheels? That way you can just hop on the cart and drive it around the shop.
    Here I made you a picture
  27. Likes Roert42, NotaVegetarian, SweetMK liked this post
  28. #14695
    Seriously though I did try to buy the electric shopping cart retriever used in parking lots when Target closed up shops in Canada. The plan was to use it for moving a welding table.
  29. Likes 52 Ford, SweetMK liked this post
  30. #14696
    Dec 2020
    Virginia, USA
    Really not a bad idea!
    Naturally, I have a solution for moving the welding table, too.
    Go buy a surplus M274 Mule. Already has a flat deck on it. It's about the right height. Just throw a piece of 1/2" plate on it there any yer good to go!
    Need to level it? Adjust the tire pressure!
  31. Likes N2 Welding, SweetMK liked this post
  32. #14697
    Dec 2020
    Virginia, USA
    No spare tire? No problem!
  33. Likes N2 Welding, NotaVegetarian liked this post
  34. #14698
    Pretty cool. I’ve never seen one before. I LIKE it!
  35. Likes 52 Ford liked this post
  36. #14699
    Brethren, Mi
    I like the cart, perfect job to do a piece at a time. Time makes for great finish and paint.
  37. #14700
    Brethren, Mi
    I built a few things we sand, tape the welding joints and prime before assembly. Spatter doesnt stick, easy to resand and prime again. Not that it matters in the case of shop equipment, most paint looks and lasts but where we using epox primers, usually an industrial grade to reduce the cost they can mottle a little etc, doesnt hurt on most equipment but show piece or car truck finish we scotchbrite a little between coats. They blame it on thje paint sometimes when its really the primer. I got a bunch of equipment paint tricks and paint follows welding. Its what is seen in the end.
    You should be shipping that stuff somewhere to a "collector: crowd, you have good design, useful art. Benches should be in a "gallery"
Page generated in 1,657,033,669.43171 seconds with 15 queries
