Results 1 to 14 of 14
Thread: Miller DEL-200 Welder Excitation
    Aug 2009
    My DEL-200, small Miller Diesel Driven welder will not excite and generate either a arc or power to the plug. I've checked all wiring, fields and windings, all are good, replaced all rectifiers, and put new diodes in. After checking all, still no spark or outlet power. The welder did setup, in a storage room for a few years, not used, however, welded prior to. Machine is in good condition and runs well, seems to have lost its' ability to excite.
    Feb 2009
    Lafayette, Louisiana
    Re: Miller DEL-200 Welder Excitation
    Sounds to me like you need to flash the exciter field. What follows is the procedure to flash the exciter field for DC generators that are engine driven. If you feel this is inappropriate to your machine don't use it. Instead PM Duane55 and ask him the procedure for Miller welders. What I'm giving you is the procedure for SA 200 Lincoln welders for sure, and reading the text I'd say it works for any DC generator.
    Flashing the exciter field consists of passing current through the fields using an external source of 6 to 125 volts of DC power from a storage battery or DC generator. If using a DC generator, keep the generator turned off except when actually applying the flashing current. To flash the fields:
    1. Turn the welder off. Raise one exciter brush off the commutator.
    2. On Lincoln welders, attach the positive lead from the external DC source to the right hand brushholder.
    3. Carefully holding an insulated section of the negative lead from the DC source, touch its lug or clamp to the left hand brushholder for five seconds. Pull it away quickly to minimize arcing. Remove the lead from the right hand brushholder, replace the brush on the commutator, start the welder and the generator voltage should build up.
    Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.
    -Cree Indian Proverb
    SA 200 Lincoln
    Victor Torches
    Aug 2009
    Thanks, we will try. I remember, too many years ago, exciting the Lincolns that way. I used to overhaul them for my father, too many years ago to remember. He kept a fleet of Lincoln SA200s going with his welding business. Many torn down, many Continental blocks off to the Machine Shop.
    Feb 2009
    Let us know if it worked for you. There is always the possibility of it being something else, but the residual magnetism required to produce dc power in a generator is lost when sitting over time like your machine did. Rat nests are notorious too. Good luck!
    SA 200 Lincoln
    Victor Torches
    May 2008
    Orange, TX
    jc,
    PM sent.
    Duane
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    May 2008
    Orange, TX
    For anyone interested, a rotor field flash got jc464120's unit welding (good call gg) and a correction to the engine throttle switch circuit took care of a no AC power output condition in POWER mode.
    The whole process was carried out thru PMs so for the benefit of anyone who cares to know what was wrong I'm posting this update.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    How do you like your del200?
    i have one and it welds fine. had to upgrade to a TB302 for the AC output, but i still have the old one somewhere.
    id say it has a decent arc, but it doesnt half upset the neighbors
    G
    Dec 2015
    Hi. I have the opportunity to get a Miller DEL 200 Diesel. Can it be used with a HF TIG head? Thanks. Chris.
    Jan 2021
    Hi duaneb55 I just picked up a miller del 200 with serial number JB490078 I got it to run but am not receiving any power out of the outlets or electrode plugs. The welder sat outside for about 10 years. I cleaned up the brushes but am not sure what to do next?
    Jan 2021
    Jun 2023
    Duaneb55 can you pm me the steps to flash the exciter field on a del 200.
    May 2008
    Orange, TX
    Quote Originally Posted by Diamondewelding View Post
    PM sent but simply apply 12VDC + to the center slip ring brush lead (wire #21) for a second or two with the unit running. I the unit won't self excite you'll need to check flashing diode D4 for being failed open.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jun 2023
    Can anyone help me figure out which diode I need to order. I have a diode in the rectifier directly above “17” if you look in the manual. I assume it’s the same as 17 but want to make sure before I order
    May 2008
    Orange, TX
    Yes, the one above "17" is the same (straight polarity).
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
Page generated in 1,713,278,419.31361 seconds with 18 queries
