Results 1 to 8 of 8
Thread: welding off a generator
    Hello - Ive been offered a workshop space at no rent but it is without electricity. I'd like to run my mig off a generator but want to make sure I get one with enough power and a steady enough current. My mig is a 135te Clarke mig 230v 50hz 1 phase 30-130 amps. Can anyone here say they have run a similar model off a genny? If so, could you recommend which specs I should be looking for in the genny?
    Thanks in advance.
    Dec 2007
    Los Angeles
    Re: welding off a generator
    Here in the USA we use 60hz so most members probably haven't run generator with 50hz
    Where are you located?
    Ed Conley
    MM252
    MM211 (Sold)
    Passport Plus & Spool gun
    Klutch 120v Plasma cutter
    SO 2020 bender
    Beer in the fridge
    Sep 2012
    Knoxville, TN
    Long story short, you need to look up the max inrush current for your welder, the at least double it for your generator's surge rating.
    Everlast PA160-STH
    ... and that's about it!
    whitewater, mt.
    Unless you get at least, I say again at least a 10k "Quality" generator you can trust your asking for trouble. Your machine wont stand dirty power i.e. fluxuations. surges, irregular voltage, generator running out of fuel and the like, it will be destroyed. If your overseas check the power where your at. Almost everything in the US is 50/60Hz.
    Arcon Workhorse 300MS
    Powcon 400SMT
    Powcon SM400 x 2
    Powcon SM300
    1968 SA200 Redface
    1978 SA250 Diesel
    Miller Super 32P Feeder
    Pre 1927 American 14" High Duty Lathe
    K&T Milwaukee 2H Horizontal Mill
    Bryan
    Apr 2012
    On a farm, north of Scranton, PA
    How much do you plan to spend on fuel? Our milk processing equipment uses a lot of variable speed drives and doesn't tolerate power fluctuations at all (goes into a safety shut down mode). During power outages, we run a 150kW generator powered by a big, old Detroit Diesel. Provides power with less fluctuation than line power. The generator was inexpensive (<$5000), but is a thirsty machine.
    I put it on a trailer for mobile power. It will run all of my welding and cutting equipment simultaneously without issue.
    Lincoln Precision Tig 185
    Lincoln Power Mig 256
    Everlast 140ST
    Smith O/A
    I see - I think with this advice I'll do what I can to get mains power in, rather than a generator. At that cost it seems far out of my reach.
    I'm in London, but the welder is 50 hz as you mentioned.
    Thanks for all your help, its much appreciated.
    Aug 2012
    AR
    Nigel, maybe you could approach the landlord and suggest cost-sharing for running power to the shop. Power may be cheaper in the long run, considering generator cost plus fuel. It would benefit both and make his/her place more attractive for renting if and when you move on to other quarters.
    Oct 2011
    Santa Clarita, Ca
    I ran my Miller MM175 for 5 years off of a Coleman 5000w generator I got at Home Depot. Ive now had it going on 10 years and it works as well as the day I bought it.
Page generated in 1,713,261,867.40551 seconds with 20 queries
