Results 1 to 25 of 25
Thread: bench grinder, variable speed
    Aug 2012
    AR
    I currently have a single speed bench grinder, but now have a need for a variable speed one. Got some Christmas stocking $$ burning a hole in my pocket :-)
    First, are they worth a flip, reliable, etc.?
    What brands do you guys recommend for a variable speed model?
    I will not buy a Craftsman for several reasons, so they are out of the question. I trust the recommendations here much more than the other internet reviews since they are usually "loaded" with employee and paid reviewers' comments.
    Hope everyone had a Merry Christmas :-)
    Re: bench grinder, variable speed
    What do you plan on using it for ?
    Aug 2012
    AR
    Buffing off light rust, polishing some welds, general light grinding and wire wheel work. Don't like to use the higher speeds with a wire wheel. I now do most of the wire wheel stuff with the angle grinder/wire wheel. The slower speed with the wire wheel is much better :-)
    Piedmont, SD
    Hunt around on eBay for an old belt driven grinder (1st pic) a Reeves variable sheave (2nd pic) and the motor of your choice. With a bit of cobbling you should be able to come up with a superior machine to what is available...or at least available for less than 5-6 times the price. Barring finding an old belt driven grinder, you can always get a couple of pillow block bearings, a section of CR shafting, thread the ends, add a pulley and have the same thing. (3rd pic)
    Lincoln PrecisionTig 275
    Miller 251
    Miller DialArc 250
    Bridgeport mill
    Hossfeld bender & dies
    Logan shaper
    Jet 14 X 40 lathe
    South Bend 9" 'C'
    Hypertherm 900
    Ellis 3000 band saw
    21"Royersford Excelsior
    Two shops, still too many tools.
    Feb 2009
    Central Illinois
    Would a dimmer switch rated at around 15 amps work? Not sure my self just thinking out loud.
    Dan
    Piedmont, SD
    Quote Originally Posted by DanD78 View Post
    Dan
    Could be wrong, but I believe dimmer switches or router speed control switches only work for universal motors.
    Miller 251
    Miller DialArc 250
    Bridgeport mill
    Logan shaper
    Jet 14 X 40 lathe
    South Bend 9" 'C'
    Hypertherm 900
    Ellis 3000 band saw
    Nov 2012
    charlotte, nc
    I use this slow speed grinder 1720 rpm for the last two years.
    for $100 on sale I think it is a good deal.
    it's not variable, but i have a wire wheel on it and a green aluminum grinding stone on it, my other grinder has the standard dark gray stones for steel, coarse and fine, and my 3rd and last grinder has red deburring wheel on it.
    of all my grinders I like the slow speed one the best. Doesn't feel like it's going to take off like a bat out of hell.
    Oct 2011
    Jacksonville Florida
    Quote Originally Posted by AluminumWelder View Post
    Looks about like the grinder I bought for grinding tungsten, also low speed. Paid around $100 and it had a 100 grit and a 130..I think. Really like the grinder, got it from a store called "Woodcraft"
    Edit.. Just watched the video, it was made by Woodcraft Looks like they changed the labels a little.
    Airco Ac/Dc 300 Heliwelder
    MillerMatic 200 (stolen)
    Miller Maxstar 150STL
    Miller Maxstar 161STH
    Miller AEAD200LE
    Hobart MIG
    Lincoln Idealarc 250
    Aug 2012
    AR
    Quote Originally Posted by tackit View Post
    I have a 6" VS Craftsman I like, one wheel is wire brush the other a medium stone, if it would break I would buy another. Why do you not like Craftsman bench grinders?
    As I mentioned in my OP, I will not buy another Craftsman tool. Had a couple of experiences lately with them where they would not honor the warranties. For example, first time use of a plain beam type torque wrench, the wrench broke, returned for replacement, they refused saying "it has moving parts".
    More interested in other brands like Dewalt, Porter Cable, Milwaukee, Skil(maybe), Jet, Grizzly, etc.
    Also, I'm not interested in building a belt-driven one.
    As I recall, speed controls only work on motors with brushes...do the bench grinders use brushes? Never took one apart :-(
    What about a fixed 1800 RPM ? Here's a BALDOR . http://www.buschshineproducts.com/1-...rpm-p-167.html
    Nov 2010
    Houston Pennsylvania USA
    I am curious about the Craftsman disposition too.
    I have one of these. http://www.grizzly.com/products/G0597
    Aug 2012
    AR
    shortfuse I found this info on sears website concerning beam torque wrenches, I wouldn't let them off the hook.
    it posted smaller than I copied it, it says "If this Craftsman hand tool ever fails to provide complete satisfaction it will be replaced free of charge."
    Tackit, I'm gonna check into the "warranty" further. Thanks.
    Bilbao, Spain
    Why don't just get a 3ph big *** grinder and then use a single phase input 3phase output VDF? That should do the trick. And usuallly industrial 3ph equipment is sold cheap because not everyone can power it. Anything that goes with motors can be dealt with using VDF. Sadly the welders cannot.
    Mikel
    Costa Rica
    Bench grinders are for gurlz.
    Make ya wunna these.
    http://www.cootebeltgrinder.com/
    Bubble gum
    Tooth pix
    Duct tape
    Black glue
    GBMF hammer
    Screw gun --bad battery (see above)
    Aug 2012
    AR
    Those Coote's ARE nice:-)
    Costa Rica
    Aint nothing to make.One day job. Set it up for a 12 speed pulley system. 1 horse 3450 will rip your arm off. Call Sunray for some wheels and fab up frame and a tracker system
    Bubble gum
    Tooth pix
    Duct tape
    Black glue
    GBMF hammer
    Piedmont, SD
    Like Burpee said, build your own...this is a welding forum. Get a better machine, built to your exact needs, all for far cheaper than some plastic fantastic off the store shelf. If you want cheaper than a Reeves variable sheave go with step pulleys.
    Miller 251
    Miller DialArc 250
    Bridgeport mill
    Logan shaper
    Jet 14 X 40 lathe
    South Bend 9" 'C'
    Hypertherm 900
    Ellis 3000 band saw
    Piedmont, SD
    For anyone wishing to build your own, check this site out.
    http://tube.7s-b.com/Belt-grinder/page2.html
    Miller 251
    Miller DialArc 250
    Bridgeport mill
    Logan shaper
    Jet 14 X 40 lathe
    South Bend 9" 'C'
    Hypertherm 900
    Ellis 3000 band saw
    Jun 2011
    Oregon
    To change the tracking you, tip the Idler wheel. The belt will follow the crown. the crown is made by grinding a slight curve across the idler wheel. You can even ad the crown on a flat idler by rapping a couple raps of tape around it. Mac
    Piedmont, SD
    I see and understand the tracking mechanism but I don't see a way to tighten the belt, unless their is an adjustment slot I'm not seeing.
    Tack, take a look on the horizontal strap the idler mounts to...bit longer than it needs to be past the pivot, unless it connects with a spring on the other side of the frame.
    Miller 251
    Miller DialArc 250
    Bridgeport mill
    Logan shaper
    Jet 14 X 40 lathe
    South Bend 9" 'C'
    Hypertherm 900
    Ellis 3000 band saw
    Piedmont, SD
    No, not what I was suggesting at all. Probably a better idea to wait for Burpee to hopefully add a second picture dealing with the other side we can't observe clearly, but I was speaking/typing of the horizontal strap the idler wheel is mounted to in the picture. Note how below the pivot it extends well past the pivot towards the rear? (you can't tell for sure at the top) maybe it's just extra strapping serving no useful purpose, but that is where most would add a spring to tension the idler for the belt.
    Miller 251
    Miller DialArc 250
    Bridgeport mill
    Logan shaper
    Jet 14 X 40 lathe
    South Bend 9" 'C'
    Hypertherm 900
    Ellis 3000 band saw
    Piedmont, SD
    Actually Burpee may not be able to provide any more pics of that sander/grinder. While looking on Google Image Search for a shot of the tensioning mechanism I found the same picture posted and clicked on the link. Turns out to be somebody else's build. Here is a picture from that link on the builder's other sander/grinder project detailing the tension mechanism. BTW, just doing the same thing as Burpee and providing a pic of what you can build easily. Here's a link to the post.http://www.projectsinmetal.com/free-...2-belt-sander/
    Miller 251
    Miller DialArc 250
    Bridgeport mill
    Logan shaper
    Jet 14 X 40 lathe
    South Bend 9" 'C'
    Hypertherm 900
    Ellis 3000 band saw
    Jan 2013
    ...Shoulder of Orion...
    @ Burpee - a local dude (new blacksmithing and knife making) ecently asked me about these sanders. Look to be built like tanks, and highly versatile. Say you had the steel (1/4", 3/8"), what's your estimate on the $ for pieces/parts? Note: haven't done an ounce of research yet or examined the link posted by WyoRoy.
    Injecting this project into the 2014 build file. Mahalo!
    Jan 2013
    @ Roy - alright. Thanks. The journey continues...
    The belt sander with the V belt looks like an accident waiting to happen. Should at the least cover the top wrap of the sanding belt to contain it when it breaks. A guard on the V belt would go a long ways.
Page generated in 1,713,311,379.87814 seconds with 19 queries
