square vs round tube..?
7K views 15 replies 10 participants last post by  Vipernut
I am starting a project.....and started out with a materials list, that has some square tubing...1.5"x1.5" and 1/8 thick....Then I got to thinking, maybe I should use round instead of square....
when comparing the same size of round and square tubing, is one stronger than the other ?
Kansas....
#2 ·
Your 1.5 inch square tube has more material in it per inch that 1.5 inch round so the comparison is unfair. Yes round tubing is "better" but troublesome to fabricate. Also there is the little controversy about strength and rigidity. In most cases you want something rigid and so strength is not the first design goal. By the time you design something rigid enough , it is strong enough.
I suggest that you stay with square unless every ounce of material used is critical to the success of the project.
#4 ·
more info would be nice
what is being built???
to ask which is best (stronger) would depend on the
item being built
#5 ·
I am building a custom tube bumper for my 4x4 rig....
it's just general question. thought there might be someone out their that might have some engineering back ground....I really don't see that one would be much greater than the other in building a bumper...alot of people use round, just thought I would see if anyone had any experience using round vs square in there projects...
Kansas
#7 ·
Kansas,
If its just a bumper, I don't think that either would be a bad choice...Round does take more effort in joining and cutting. Its easier to bend for most people with economical benders.
#16 ·
Maybe if you paid more attention to the question and actually offered something useful, you wouldn't have noticed his sig :sleeping:
For the original poster - round would be an easier option as far as bending. A 4 1/2" angle grinder will work for fish mouthing tubing.
