Page 19 of 20 FirstFirst ... 917181920 LastLast
Results 451 to 475 of 481
Thread: Oldest welder you guys are still using???
  1. #451
    Mar 2017
    bar stool
    Re: Oldest welder you guys are still using???
    Never saw that toy at any shows Kevin.
    Is it a contact spot welder like jewlers used to use or does it establish a pulsed arc?
  2. #452
    Jun 2007
    I think it's a contact spot welder...
  3. #453
    Mar 2017
    bar stool
    I tend to agree. Someplace I have a 1970s vintage Jeweler.s welder - that seems to be mostly an AC supply with provision for a 1/32 carbon. It will provide a lot of heat into copper wire when held between the ground and "stinger". Seems to function similarly to a Rigid soldering machine.
    Phone dial on yours indicates it delivers pulsed output using the dial.
    Does the lower post come up to meet the upper electrode when the butterfly handles are depressed?
  4. #454
    Sep 2018
    Ive got a 60's or 70s lincwelder 225 that runs like a champ!
  5. Likes Kentucky liked this post
  6. #455
    Aug 2006
    P&H Chemetron ac/dc 300 HF from the late 60’s I believe.
    I have a 1973 Lincoln Idealarc R3S-250 with LN7.
    A Union Carbide/Linde V1-253 with a Union Carbide wire feeder. Unknown age.
    A Millermatic 200, got it new in 86.
    Deltaweld 651 from 1991
    Goldstar 302, 1997
  7. #456
    Jan 2021
    1965 model. Pretty worn out. Right lead hardly operable. Bad wiring down to the left power leg. Can still be used, but needs daily upkeep and lots of fuel additives to stay running.
  8. #457
    Feb 2021
    I have a 1929 SAE200 "Torpedo" that I bring to jobs where the three phase power is not steady(the rotation smooths it out) and they don't have a transformer to use a 230 volt welder....trying to use 2 of the 3 legs makes for some weird welding...Oh ya they pay for the power!!! These are a SA200 generator with a huge three phase motor in the middle but with alot more arc control(like a SAE300)....heavy as all ++++ but fun to use(if your not paying the power bill)
  9. Likes MinnesotaDave, 52 Ford liked this post
  10. #458
    Dec 2022
    North Fl.
    I have a 1965 Lincoln 300/300 tig I use daily
  11. Likes 455dan liked this post
  12. #459
    Aug 2009
    Wanganui, New Zealand
    Quote Originally Posted by Bobbyc View Post
    I’d love to see that! Photos?
    Gear: Esab power compact 205 with tbi industries torch
    BOC Smootharc 185dc tig
    Miller Syncrowave 350LX
  13. #460
    Jun 2017
    AJO, ARIZONA
    I have an old WW2 era MID STATES 300 AMP AC machine, I don't use it much but it works great. Spec plate says 100% duty cycle at full output, I think the stinger handle would get to hot to hang onto after a while.
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    JEFF
  14. #461
    Apr 2017
    I have a 96 year old welder that I've been using for about 40 years. Welds beads like nobody's business. Perfect stack of dimes on stainless and aluminum.
    I hope to live as long as little Jimmy as his friends call him. Last year his wife told him to retire. He said they couldn't afford to live on the piddly social security that he gets.
    Only job he won't do is on a ladder.
  15. #462
    SoCal-LA
    Quote Originally Posted by henry42 View Post
    That will be me at some point. I just can't get enough of stainless and alum.
  16. #463
    Brethren, Mi
    I am tired of welding and grinding. I am buying new suits a Cadilac and some dancing lessons.
  17. Likes Oldendum liked this post
  18. #464
    Jan 2023
    Warsaw NC
Size:  225.3 KBI have an old Craftsman Welder with an Oman single cylinder engine. It’s hard to start but welds decent when it gets going. The engine serial number indicates it is an early ‘70s’ unit.Name:  93B7379A-6AAA-4EA8-9BDF-1796FDA09921.jpg
  19. Likes 12V71, whtbaron, Garfield43 liked this post
  20. #465
    Dec 2022
    North Fl.
    1965 Lincoln 300/300 Tig I’m still using everything works fine on it.
    keep ‘em clean and they will run for along time.
  21. #466
    Sep 2015
    Eastern,KY(Appalachia)
    1966' idealArc..
  22. #467
    Jan 2020
    Haven't dug into history records yet, eldest undetermined but likely in this order. Betting two are close, dead heat for 3.
    Somewhere before Miller, after Weld N Power is round top Lincoln 250 AC/DC Idealarc, no good pics.
    This Weld-N-Power 200 is spiffy, not sure it qualifies as 'portable'; mounted on un-wheeled skid. 2 cyl Wisconsin THD
    Slightly younger, fully analog Miller CP-250TS with Millermatic S-52E wire feed piggyback
    If 1960's has anything to do with appearance, this is a 70's yuppie. AIRCO 300 Squarewave
    "Welder" is a broad category, oldest in this stable must be this water cooled spotwelder.
    Devoid of tags, not even cast-in name, solid iron case, every inch copper wire. And Heavy. Works perfectly, wants range selection plunger repaired.
    It'll burn HRS 1/8" to 1/8", HRPO 10ga to 10ga, & galv 14 or 12, big enough for me.
  23. Likes 52 Ford liked this post
  24. #468
    Dec 2022
    North Fl.
  25. Likes Toolmaker51 liked this post
  26. #469
    May 2021
    Landrum, SC
    Me. :P
    Lincoln 330MPX
    Lincoln Power Mig 256
    Lincoln LN-25X Wire Feeder
    Lincoln AC/DC 225
    ¼ Ton of Torches OFC-A/OFG-A
    Air Carbon Arc Gouging
    CAC-A
    Lincoln Tomahawk 1000
    Ingersoll Rand T-30-14hp-25cfm
    Instagram: #Freebird Welds
  27. Likes Lis2323, 52 Ford, SweetMK liked this post
  28. #470
    Dec 2020
    Virginia, USA
    Quote Originally Posted by Freebirdwelds View Post
    Me. :P
    Still weldin' fine, just makes a lot more noises than used it.
  29. Likes Freebirdwelds, SweetMK, Toolmaker51 liked this post
  30. #471
    Aug 2009
    This will be once its fully restored. I will do a nut and bolt full restoration on it. I saved it from the scrapyard this morning. Serial number is so old Millers website doesn't recognize it. HH098775
    The Miller sticker on the side is interesting. Red ring.
  31. #472
    Jun 2008
    Central California
    Quote Originally Posted by William Payne View Post
    What is the Model or Part Number on it? That would bring up some information, showing which manuals applied during which time periods.
    FWIW, either my Millermatic 200 or the Syncrowave 250 (I forget which) has a Serial Number starting with HK. The other unit might be earlier; I should check later today about both.
  32. #473
    Aug 2009
    Quote Originally Posted by Oldiron2 View Post
    I think I’ll start a thread on the restoration of this welder. It will be done properly.
Size:  91.5 KBName:  DAD86EE0-6991-4B4F-9F07-D75C72F55E8E.jpg
Size:  122.0 KBName:  CAB001C2-2F88-4AB6-B224-FFF835B2D0BB.jpg
Size:  128.0 KBName:  F54369F4-63E5-497D-9605-39E1CE143741.jpg
Size:  175.7 KBName:  9702B7DC-AB72-4425-B132-6A1F569E22B0.jpg
  33. #474
    Aug 2009
Size:  130.8 KBName:  871EB6AD-D4E3-4BA6-B6B6-48EB74A95813.jpg
  34. #475
    Dec 2022
    North Fl.
    They were good running machines. We had very little problems with them.
Page generated in 1,713,266,107.24934 seconds with 20 queries
