Results 1 to 22 of 22
Thread: brazing fittings onto beer keg
    May 2010
    Ct.
    I want to modify a beer keg and am wondering if brazing might be easier or cheaper than buying s.s. wire and tri mix for mig.
    Would brazing have to be done with some sort of filler containing nickel, chromium etc.?
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
    Nov 2012
    new york city
    Re: brazing fittings onto beer keg
    silver solder may work.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Feb 2008
    North of Philly
    Silver solder would be my choice. Just make sure to clean up the flux after you are done.
    Ronald Reagan
    May 2010
    Ct.
    I never thought of using silver solder.
    Millermatic 180
    Purox O/A
    Pa
    aren't kegs made out of aluminum?
    Millermatic 211
    Miller Syncrowave 350lx with cooler and tigrunner
    Thermal Dynamics cutmaster 81
    1955 National Cylinder Gas O/A setup with original patina
    Jun 2008
    Any one I've drained ...err seen has been s/s.
    Ditto re the silver solder, just make sure that wherever you put the fitting it doesn't buckle away from the heat while you're soldering it. Once you get it blue (too hot) your going to have to stop and clean it and start again.....Mike
    Nov 2012
    new york city
    if you chose to go that route make sure you use food grade silver solder. no lead, zinc or cadmium.
    i.u.o.e. # 15
    Oct 2013
    N. Arizona
    I modified a keg to serve as a pressurized fuel tank for a race car.... silver solder worked fine.
    Feb 2014
    Iowa
    Quote Originally Posted by That Guy There View Post
    All I've seen are.
    Jul 2011
    Quote Originally Posted by Teggy1 View Post
    All I've seen are.
    EVERYONE I've seen are stainless. I've never seen an aluminum one. They look like they're aluminum but they are not.
    TA Arcmaster 300
    CM3
    XMT 304
    S22P12 suitcase feeder
    X-Treme 12VS
    Optima pulser
    TA161S
    Maxstar 150STL
    Hypertherm PM45
    OP setup
    Stihl 020AVP, 039, 066 Magnum
    Jan 2013
    ...Shoulder of Orion...
    @ jpump5 - check out this article on welding, brazing, and silver soldering on 304L SS beer kegs:
    http://morebeer.com/brewingtechnique....6/palmer.html
    Options abound. The method you select will depend on your skill level, tooling, and desired outcome.
    May 2010
    Ct.
    -ManoKai-Thanks for the link,it's just what I was(or should have been) looking for.
    As for keg material,I don't know that I've ever seen an aluminum beer keg.
    Millermatic 180
    Purox O/A
    Mount Tabor VT
    Maple syrup (properly pronounced surup) equipment was for centuries made of stainless steel sheet products bent and soldered with 50/50 lead and tin. 20 years ago, the people who worry about that sort of thing started worrying about lead exposure. Syrup from all over VT was tested, consistently found to be low in, but not free of lead. A study ensued, and it was found that most of the small amount of lead in syrup was found in the ground water that makes up 99.something % of sap. Oh well by this time the consuming public being made aware of it, wanted equipment to be lead free. At first we used antimony solder instead if lead. Tough stuff to work with! Silvabright, a solder with a three metal composition worked better. These days it is all done with Tig. The welders, who were formerly solderers are masters with a tig torch. This fall at G.H.Grimm I had the treat of watching one of them make a simple kettle. They have, for each joint a machined back up fixture through which they flow purge gas.
    Either TIG or solder work, TIG being the easier technique. Purge gas being the challenge in a vessel you can't get inside. I'd ask Steve, (Otto Nobetter), he does this stuff.
    A small number are aluminum.
    Solder must be done with a big electric copper. It is tricky to get the first of the stainless hot enough to begin to melt solder. The liquid flux has a short half life, once the joint is begun it is easier, a process much like TIG except flux, and copper not gas and torch. Clean with Scotchbright and wire brush.
    Feb 2014
    Iowa
    Quote Originally Posted by Drf255 View Post
    I've only cut two apart. One for a still, while in college, and another for a fuel tank on a dune buggy, which was TIG welded to add an aluminum filler. After doing some research, kegs are made from BOTH materials, less commonly aluminum. So while my previous experience with aluminum kegs led me to believe the appearance of stainless steel keg was aluminum, there are kegs made from both materials.
    Feb 2014
    I've seen some coated inside and out with a coating. Would hate to melt that and then drink it.
    Using Tapatalk
    Nov 2012
    new york city
    i believe miller uses rubber coated kegs.
    i.u.o.e. # 15
    Mount Tabor VT
    We've made some beer vessels. Kegs are hard to come by. Breweries don't want to sell them. Buying a keg of beer paying the 50 dollar deposit and not returning it is enthusiastically discouraged. They are selling un labeled ones at high price for maple syrup storage. Open topped containers aren't a problem, purging is relatively easy. Closed top, I haven't done I'm not sure how to purge, maybe fill the whole container with gas.
    I haven't seen coated kegs.
    Oct 2007
    central michigan
    the old Falstaff mini kegs that held a case of beer equivalent may have been aluminum. I have one on the garage shelf in Michigan,but i'm in florida and cant check it.
    miller thunderbolt 250v
    lincoln square wave tig 175 pro
    lincoln idealarc mig sp250
    everlast tig 210EXT
    everlast power plasma 50
    chicago electric (hf) 130 tig/90 arc
    chicago electric 90 amp flux wire
    3 sets oxy/acet
    Feb 2014
    Moncton, New Brunswick, Canada
    The majority of breweries switched to stainless in the early 80s. Prior to that there were a lot of aluminium kegs that were filled from the side and then tapped with a spear from the top.
    Oct 2008
    New Jersey (yeah it sucks)
    Get a quote from Skolnik...A couple of us wino's bought a few drums years ago and prices were not really that bad.
    http://www.skolnik.com/product.php?p...ss_steel_drums
    Mar 2009
    western ma
    I have "Silver Soldered" several fittings into SS kegs. My son is a home brewer and is constantly up grading. Ditto on the food grade silver. Just be sure everything is clean.
    Oct 2012
    East Van BC
    you can use a nickel rod to braze stainless, much cheaper than silver, but does not flow as nice.
    SqWave 200
    Millermatic 190
    Airco 200 AC
    Hypertherm PM45
    Boice-Crane Band Saw
    Victor O/A
Page generated in 1,713,240,860.87626 seconds with 18 queries
