Results 1 to 25 of 41
Thread: Best engine driven machine for MIG
    Feb 2014
    Hello everybody, I apologize in advance if this topic has already been discussed in another thread. I am new to these forums and struck out searching for something similar. I am trying to get my independent welding business off the ground and have purchased a small trailer that I am in the middle or restoring and outfitting for my needs. And I have come to the point where I need a large generator so I can stop turning down jobs. I have a 110v lincoln MIG, miller syncrowave 180sd, miller plasma cutter as well as a good torch. So I have talked myself into needing (and really wanting ha!) a miller bobcat 250 or comparable.
    I need to have the fallowing available on the rig:
    220v MIG/flux cored
    AC TIG
    and a generator large enough to handle everything else:
    Compressor, miller 220v plasma, saws etc.
    It looks like a bobcat can be three machines I need combined but everything I have read about these engine driven machines is focused on their stick welding capabilities, but I am more concerned about how the MIG / flux cored and AC TIG(less so as I already have the syncrowave) processes and power output.
    Can you guys shed some light on whether or not I am on the right path with my needs? thanks in advance for any help, and again I hope I'm not bringing up a topic already available in an old thread.
    May 2012
    Albany NY
    Re: Best engine driven machine for MIG
    No remote capabilities with the bobcat. And you will need a highfrequency box to do AC tig on aluminum and even then your back to no remote so you can't adjust the amperage as you're welding. I do run my extreme 12vs off my bobcat and it works great
    Feb 2014
    Thanks for the input! What would you suggest that has remote capabilities?
    May 2012
    Albany NY
    A miller trailblazer has the option to run a remote but I don't think they have AC and you would still need a high frequency box to do aluminum. I'm not sure if the smaller lincoln rangers have AC or the option for a remote. Your likely going to be hard pressed to find a smaller unit that will run your 180sd as they have a pretty healthy current draw. What do you want to be able to do with your set up?
    Feb 2014
    I need a machine or combination of machines that will run or produce:
    220v MIG
    220v flux cored
    220v AC/DC TIG
    220v plasma cutter
    110v air compressor
    Various 110v shop tools, saws, grinders etc.
    Feb 2014
    I have the capability now to do all of that now except the 220v MIG/flux cored (provided I can power the syncrowave)
    May 2012
    Albany NY
    With the bobcat you have 42 Amps of 220 power that will determine what you can and can't run off it I'm betting the syncrowave draws more than that when it's at the upper end of of its current range
    Feb 2014
    Yea, I have it tapped into my 30amp WH circuit at the house and I have yet to trip it, so I'm not too worried about it (maybe wrongfully) but I really want to know what machine will MIG/flux cored as well as or better than say a Millermatic 212
    May 2012
    Albany NY
    I don't use a mig welder like that I run flux core self and dual shield with my voltage sensing miller feeder it works great off my bobcat
    Feb 2014
    So you primarily use your bobcat as just a generator for wire feed welding?
    Feb 2014
    And if so what process do you use with the bobcat?
    May 2012
    Albany NY
    No my wire feeder is a suitcase style so it doesn't have a plug on it it runs off my regular stick leads
    Feb 2014
    Gottchya, you'll have to excuse my ignorance but what is the difference between what your 12vs can do and the bobcat itself?
    May 2012
    Albany NY
    My 12vs feeds wire like a mig welder the bobcat just supplies the voltage
    Oct 2013
    NOVA
    Lucas,
    I think you are missing with the bobcat that it doesnt have a mig welder built into it. It is capable of powering a suitcase wire feeder, but it is not standalone capable of mig. You will either need to use it to power a 220V mig or buy a voltage sensing wire feeder to run off of it.
    Multimatic 200
    Ellis 1800
    Haberle S225 9" cold saw
    MM 300; Spoolmate 30A w/ WC-24
    TB 302G
    Dynasty 280 DX Tigrunner
    May 2010
    Port Orchard, WA.
    I'd look at the Lincoln 305-G with an LN-25, and spool gun.
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Feb 2014
    Yea Droopy, I did not realize that. Is there a machine that will do what I need? And what is with this diagram? Name:  ImageUploadedByTapatalk1393353121.955369.jpg
    Feb 2014
    And thank you CEP, I will check out that Lincoln 305
    May 2010
    Port Orchard, WA.
    I have the same spool gun, here is what it can do on 16-GA aluminum.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Feb 2014
    Looks good, I have never used an aluminum spool gun, how different is the process from MIG welding?
    May 2010
    Port Orchard, WA.
    Quote Originally Posted by Lucas_Jackson View Post
    Same thing, well maybe just a little heavier than a regular Mig gun.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Maryland
    Not 100% sure what your needs are but.
    From Miller, only the uber expensive Trailblazer does AC - the air pack one with the built in air compressor - like $12000 list expensive.
    The Bobcats do AC, but it will not be the quality you get from your Syncrowave.
    For under $5000, Lincoln Ranger GXT will do AC and has some sort of a TIG module for remote + high frequency. You can get the GXT for under $4000, but the TIG module will set you back $2000ish.
    If you need compact reliable stuff, you won't go wrong with Miller or Lincoln, however, a Generator plus some inverter machines is probably the cheaper way to go (if you have the space).
    Quite frankly, I'd look into things like stand-alone generators + stand alone air compressors and use more efficient inverter machines. Upgrade the welders you have (used late model Dynasty + Inverter based MIG - Thermal Arc or Multimatic etc.) You can use those welders at your shop as well. Yeah, you have to load them on the truck everytime you go out on a call. When that gets old, and you have enough business - then buy the dedicated engine driven welder. One caveat, with the inverters I wouldn't want them on a trailer. I know everything is tougher these days, but bouncing a dynasty on a trailer seems to be a sure fire way to shorten the life span. I'd have a padded cabinet in the back of a truck. A 200 Dynasty plus a 200+ MIG will get you into light trucks - and some trailer repair. Beyond 200 amps you are really starting to talk about water coolers etc. A serious TIG. On the MIG side of things.
    I don't know what your budget is, but if you look at upgrade + new generator + sell what you don't need anymore, your probably money ahead of where a dedicated engine driven welder would be. And if you go used... I've seen XMTs on Craigslist for $1500, Dynasty 200s for $2500, Wire feeders for $500 (yes suitcases are typically expensive but who buys just a suitcase? Not a lot of buyers...) Figure what you have is pretty quick sell at $1500, a bit longer if your holding out for more. That will buy you the generator. So you've upgraded all your equipment plus 100% mobile for $4500.... The cost of just an engine drive. (and you have to add suit case to that).
    If your business is booming, next year buy that engine driven welder.
    I think its a universal truth that everyone that has their own business wishes they started earlier and spent less (or more wisely) when they did start.
    Con Fuse!
    Miller Dynasty 350
    Millermatic 350P
    -Spoolmatic 30A
    Miller Multimatic 200
    Hypertherm PowerMax 1000G3
    Miller Maxstar 200DX
    Feb 2014
    That is great advise, and I definitely want the work to justify the tool not the other way round, (which I've been known to do in the past haha)
    What does a syncrowave go for nowadays? I would love to upgrade to a dynasty with more control given the gap between the two isn't wider than my wallet
    Los Angeles
    If you are not familiar with engine drives the brochure is a little misleading because to to do MIG you have to use a a suitcase feeder or plug a Mig machine into the auxiliary power receptacles.
    http://www.millerwelds.com/om/o4419e_mil.pdf
    Look through the manual section 6.3 for the Typical Mig set up for an engine drive
    MM211 (Sold)
    Klutch 120v Plasma cutter
    Los Angeles
    http://weldingweb.com/vbb/showthread.php...mig&highlight=
    Check out Yorkie's set up if you want to go with a stand alone generator.
    MM211 (Sold)
Page generated in 1,713,273,068.41600 seconds with 19 queries
