Page 3 of 3 FirstFirst 123
Results 51 to 57 of 57
Thread: My little Lincoln 225
  1. #51
    Sep 2010
    Sparks Nevada
    Re: My little Lincoln 225
    All this nostalgia for the tombstone buzz box makes me ill. I hate the dang things. Once I got access to a round top Idealarc I threw mine away....well, gave it away to a cousin. It was actually a Miller. It's sitting in his garage full of black widows now. Makes a nice home for them.
    Looked something like this here:
  2. #52
    Apr 2014
    MI
    I was following this thread back when you first started it. Then I completely forgot about it until I just stumbled across it again while scanning deep into the Lincoln forum.
    Wow, It turned out great!
    Those first couple of before pictures of your AC225 on the first page are neat too. That faded look just lets everybody know your buzz box has been around and probably laid more bead than that last guy who posted.
  3. #53
    Quote Originally Posted by Doug_ View Post
    I got a little more done today.
    I pulled the Amperes Selector switch apart and gave it a good cleaning.
    There wasn't much corrosion, pitting or arcing on the contact par of the switch.
    So it cleaned up nice.
    Even the contacts were clean.
    So I just hit them with a little scotchbright, 1500 sand paper and a clean cloth.
    I put some light grease on the contacts, contact bar and the ratcheting mechanism and reassembled the switch.
    I'll just clean off the transformer, check the connections to make sure their tight, hit the power switch with some contact cleaner and lube and the insides will be finished.
    How do you take the switch apart? When the machine was given to me the selector was stuck on 75. I turned it and the plastic popped out of the copper part that should be turned by the plastic piece. I got the plastic part back in the copper part but it pops out now when I try to turn it.Name:  IMG_0003.JPG
  4. #54
    After looking at the pictures closer posted by Doug I found the roll pin and got the switch apart. Cleaned it all up and put it back together. Same problem. Could the shorter plastic end be worn so as not going into the other piece completely? Great pictures by the way Doug.
  5. #55
    Found my problem. The copper piece was bent so that it would let the short plastic piece pop out.
  6. #56
    Apr 2013
    West Coast of Florida
    Quote Originally Posted by tazassape View Post
    tazassape
    I'm glad you were able to find the problem. a little dielectric grease on the contacts will help the parts slide a little easier also.
  7. #57
    Apr 2013
    Quote Originally Posted by Bob E. View Post
    Hey Bob,
    Thanks for the comments. It was a lot of fun restoring that old welder and you're right it has burned a lot of rods.
Page generated in 1,627,070,477.21361 seconds with 12 queries
