Page 5 of 135 FirstFirst ... 345671555105 ... LastLast
Results 101 to 125 of 3359
Thread: Trailer fail pics
  1. #101
    Canada
    Re: Trailer fail pics
    Saw this on another site. Couldn't help but share it...
    Name:  Trailer hitch.jpg
  2. #102
    Jul 2013
    La Porte, TX
    Quote Originally Posted by Canadian Welding View Post
    Mind if I steal the idea for my 97 Olds?
    Gravel
    The difference between theory and practice is that in theory there is no difference.
  3. #103
    Jul 2011
    Bossier Parish La.
    Isn't that called a Red Neck, Goose Neck hitch? What trailer weight rating is it good for? Ought to be good for at least 12,000 Lbs.
  4. #104
    Canada
    Quote Originally Posted by Bistineau View Post
    Aw ya. 12000 easy. Throw some hockey pucks in there for a bump stop and you will have 30000 EASY!
  5. #105
    Canada
    Quote Originally Posted by Gravel View Post
    Go ahead. I am now installing them on civics as well!
  6. #106
    Sebeka and Bemidji MN
    This is still my fav
    Syncro 350
  7. #107
    near dayton ohio
    I saw one of these on a Cadillac coup deville once. the guy pulled a skid loader and hay bales on a dove tail gooseneck trailer. atleast he did have a brake controller in it too.
    Lincoln 225 ac (my first machine)
    farmhand 115vac 70amp mig/fc toy
    miller aead 200le (my main machine)
  8. #108
    Apr 2014
    California
    Yikes!
  9. #109
    near dayton ohio
    the one I saw was attached to the frame through the trunk and had a guard between the ball and the window.
  10. #110
    Sep 2009
    I saw this one on the way home last night. I didn't want to stay behind it to get a better picture.
  11. #111
    Sep 2009
    Sorry don't know how to rotate the picture
  12. #112
    Jul 2013
    La Porte, TX
    Won't hurt a bit if it hits your grill.
    Gravel
  13. #113
    Sep 2009
    I should mention the gate was in the trailer because it broke off and took the rear cross member of the trailer with it. Those boards were waving at people, and the side were flexing all over the place on every bump. The lights weren't working either, but that is pretty common around here.
  14. #114
    west texas
    Quote Originally Posted by Michgriz View Post
    What state is that?
    old Miller spectrum 625
    Lincoln SP-135 T, CO2+0.025 wire
    Miller model 250 and WP-18V torch
    Craftsman 100amp AC/DC and WP-17V torch
    Century 115-004 HF arc stabilizer
    Home made 4 transformer spot welder
    Home made alternator welder
  15. #115
    Sep 2009
    Michigan, I would say about half the trailers I see don't have working lights. I think there is something about if you can see the tow vehicle lights you don't need them or something like that. My trailers get checked out before every trip and don't leave unless all lights are working.
  16. #116
    west texas
    Thats too bad.
    I would say most of the new trailers have working lights. Most of the old ones dont.
    Problem is most of the trailers around here are real odd.
    Most trailer light problems are caused by bad ground, where they connect the wire to the frame. I think that is idiotic unless you can some how avoid ever coming in contact with liquid water.
    Its not really not that hard to put all the lights on a ground wire and use all weather proof connectors.
    If you do that you wont have a light problem till a bulb burns out or you let some one barrow your trailer and they break a light or 2 off.
    I replaced the lights with LEDs on my trailer and put everything on a ground wire with sealed connectors in 2008 and I may have replaced a flat 4 connector since then.
  17. #117
    Mar 2014
    Nifty idea. I should add one of those to my 1992 Chevy Silverado 1/2 ton pickups hood. No really I should as a hood ornament.
    Course I wouldn't actually use it to move a trailer.
    Chad
  18. #118
    Nov 2008
    I remember seeing something like that when I was a kid...ohh..the campgrounds we went to.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
  19. #119
    May 2012
    Ontario, Canada
    Well hell, we've seen this photo six times already, let's go for 7
  20. #120
    Canada
    Quote Originally Posted by Chad22 View Post
    Chad
    Haha, that would be great!
  21. #121
    Dec 2012
    Woodstock, Ga
    Quote Originally Posted by toofast_28 View Post
    Attachment 699801
    Maybe this isn't a total fail, but a buddy picked this up at auction for $100 and wanted me to fix it. It's getting scrapped. From the best we can tell it got rear ended. Still rolls though. Probably salvage the axle.
    Lights still good LOL
    Magazines have issues, everything else has problems
  22. #122
    Dec 2012
    Woodstock, Ga
    Just goes to show ya, one really cannot make a VW look any worse that the manufacture .
  23. #123
    Sep 2009
    I almost thought I recognized that truck.
    Anywhere near the Lansing area?
    Could be, I work on the NE side of Grand Rapids. It was heading North toward Rockford.
  24. #124
    west texas
    One coming out of the scrap yard.
  25. #125
    Canada
    Quote Originally Posted by mad welder 4 View Post
    It shoulda stayed in there.
Page generated in 1,624,072,012.77523 seconds with 12 queries
