Page 136 of 137 FirstFirst ... 3686126134135136137 LastLast
Results 3,376 to 3,400 of 3409
Thread: Trailer fail pics
  1. #3376
    Sep 2011
    Jasper TX
    Re: Trailer fail pics
    The VW Bug had an option like that...
    Owner of Fast Leroy's Bar and Grill
    Liquor up Front, Poker in the Rear
  2. Likes Gxjetmech, jay gill, whtbaron liked this post
  3. #3377
    Jan 2012
    Quote Originally Posted by bead-boy View Post
    Unfortunately the gusset is of no use because the hitch is upside down in the receiver. I am guessing this was done to give more clearance for overloaded tongue weight.
    Without commenting on any other issues, the gusset does what it is intended to do regardless of whether it is up or down.
    Millermatic 211
    Lincoln Precision TIG 225
    Century 250 MIG
    Lincoln 225 AC Box (sold)
    I support my local welding store (Amazon, McMasterCarr, Cyberweld, EBay).
  4. #3378
    Apr 2014
    MN/WI
    That is correct. The gusset will prevent separation at top (in it's current orientation). But separation will occur at the bottom. The most stress is at the joint closest to the ball (load). That is why commercially made hitches are gusseted at the joint closest to the ball.
    Lincoln Idealarc TIG-300
  5. Likes Bruce, geezer liked this post
  6. #3379
    Jan 2009
    Sonoma County
    Quote Originally Posted by Gxjetmech View Post
    Anyone ever see a tow rig like this?
    Those roof mount rigs were advertised back in the day when that car was new. I don't recall I ever saw one on the road.
    I did see a nearly identical bumper-pull combo that had skidded along the center guardrail 100+ ft upside down with Gramps and Gran still strapped into their seat belts and both white as ghosts. What an adventure!
    The VW version had to be a joke. Just adding A/C to a VW would shorten engine life down to less than 10k miles. The wind resistance of that rig would limit it to boulevard speeds at most - before the engine burned up.
  7. Likes Gxjetmech liked this post
  8. #3380
    May 2004
    Richmond/Midlothian,VA
    What do you call this kind of set up, a fourth wheel?
    Bruce
    The Welding Chef
    Lincoln Weld-Pack 3200
    NORWELD Stick
    Stanford Hill Farm
  9. #3381
    I believe these rigs were only a novelty for shows. I'd be surprised if they could drive on a highway. I've seen one doing donuts, where the car drove around in circles but the trailer only oscillated.
  10. #3382
    Apr 2008
    May depend on what your pulling. I don't know.
  11. Likes Brazin liked this post
  12. #3383
    Jan 2015
    Quote Originally Posted by hvw View Post
    Looks bad. Could of at least sanded it then stained it for strength
  13. Likes whtbaron, Bruce liked this post
  14. #3384
    Should use pressure treated in outdoor applications. I would hate to see that for from the elements.
  15. Likes Bruce liked this post
  16. #3385
    To make things worse, he's got the grain running the weak way...
  17. #3386
    May 2004
    And they are driving around still?
    Bruce
    The Welding Chef
    NORWELD Stick
    Stanford Hill Farm
  18. #3387
    Jan 2009
    Sonoma County
    Quote Originally Posted by Weldalittle View Post
    And running the longer end of the plank on top instead of below, would have strengthened it considerably.
    Also he didn't need to narrow it most of the way out. That needlessly sacrificed some strength too.
    He didn't think this through before he began hacking that 2x4. What a maroon.
  19. Likes Bruce liked this post
  20. #3388
    Dec 2014
    Northern California
    The only serrious fail I see is that threaded bolt instead of an appropriate pin. What an idiot…no washer is needed.
  21. #3389
    Mar 2021
    Near Roanoke, VA
    In reality, the hitch could be made out of steel in less time than was needed to make the wood hitch,,
    There is a binder now available, called a Speed Binder, that uses a cordless drill with a 14mm socket to tighten the binder.
    The binder costs $119 (probably plus shipping)
    Some guy on YouTube timed using the Speed Binder compared to a normal hand turn load binder,
    Both binders were tight within a second or two of each other,, the guy making the video seemed shocked at the results.
    He should have included a lever load binder in the timing,, what does a lever binder take? 0.9 seconds?
    He admitted that he tested the Speed Binder with a ratchet and socket, in case the battery on the drill is not charged.
    instead of 16 seconds, it took over 2 minutes with a ratchet,, Woo-Hoo!!
  22. Likes Bruce liked this post
  23. #3390
    Four binders X 2 minutes, I don't see the value.
  24. #3391
    Jun 2014
    Still trying to figure this one out.................Name:  271385128_10226575224876199_1606843081794786607_n.jpg
  25. Likes whtbaron, robocow liked this post
  26. #3392
    Nov 2016
    So...just what I see is the entire weight of the truck is being held by the two original safety chains..!!? .. Have you noticed the little "V" bracket the original chains are hooked too? and the associated weldment to hold said bracket...?? Wow!!!
    Kell in Florida
    Everlast Powertig 200
    Everlast Supercut 51P Plasma
    Several vintage Idealarc 250 Round Tops
    Miller Dialarc 250 AC/DC - circa 1976
    "I don’t care that they stole my idea … I care that they don’t have any of their own."
  27. #3393
    Feb 2010
    Bandera,TX / MN
    There is a guy in town that has one longer than that. When he parks he blocks the driveway for other people.
  28. #3394
    It extention so have a spare tire.
    It may work on cartoons
    Quote Originally Posted by bfjou812 View Post
  29. Likes bfjou812 liked this post
  30. #3395
    Jun 2008
    Bang your ankle on that puppy going thu a parking lot and you'll do a faceplant...........Mike
  31. #3396
    Mar 2021
    Near Roanoke, VA
    The guy appears to be parked in a handicapped slot,,
    There is probably a mobility scooter that is designed to hook to that hitch,
    if the mobility scooter is light enough, the "tongue" weight is acceptable.
    They even have "U" bolts at each joint, to reduce rattle,, that hitch is expected to stay there for the life of the truck.
    Even the license tag is moved from the center, to the side (it can just be seen at the top of the pic) so that the spare tire is now legal.
    Many officers frown on blocking the view of the rear tag,, even if handicapped,,
  32. #3397
    Mar 2021
    Near Roanoke, VA
    Took this pic in Boston a week ago.
    That is a very common application for a bicycle carry rack,,
    Rather than pull a trailer, it simply holds a bike rack.
    There are other things designed to be carried as well like a rack for a 40 pound lawnmower.
    Lots of times, the item carried is also strapped to the vehicle, to give further support.
    My daughter has one on the back of her Toyota mini-van,, sometimes she carries six bikes,,
    I accuse her of overloading the hitch,, but, that is the cost of having four children,, EVERYBODY has a bike,,
  33. Likes mcspeed liked this post
  34. #3398
    Jan 2009
    Sonoma County
    Hey I resemble that remark!
    I welded a 1.25" stinger and ball mount that I already had, to one of those. This is to occasionally carry a small, ATV size, cargo rack behind my Focus Wagon. It works great.
  35. #3399
    Apr 2008
    The only thing that makes this deal safe to use are the eyebolts on there to hook the safety chains to
  36. #3400
    Dec 2014
    Northern California
    Bumper sticker explains everything…
    They vote and drive amount us…
  37. Likes Bruce, mcspeed liked this post
Page generated in 1,642,732,307.76297 seconds with 15 queries
