Page 30 of 31 FirstFirst ... 2028293031 LastLast
Results 726 to 750 of 775
Thread: Welding table picture thread
  1. #726
    Re: Welding table picture thread
    Quote Originally Posted by ccogg View Post
    Even without any holes it’ll be a big step up from the floor! But peg board could make layout any future holes easy.
    Good idea. Use a 1/4” transfer punch.
  2. Likes ccogg, whtbaron, Bruce liked this post
  3. #727
    ...peg board could make layout any future holes easy.
    Oh no. That'd be far too easy and sensible. Can't have that!
    Might have better coverage and flexibility with removable pins that can be relocated in the guide bar. A transfer punch should be used for location or a drill guide inserted into the bars’s holes. Actually a guide bar may not be practical for a large table. By the time you lay out and accurately drill holes on an 8 foot guide bar you may as well just layout on the table itself.
    The thickness of the plate is your drill guide. With an annular cutter in your mag-drill, there's nowhere for it to go except where you want it. You're table's 4x8, so you only need a guide bar that's 4' long. Depending on your spacing, that's no great number of holes.
    Here's a vid that shows the guide bar in action on a big table.....
  4. Likes ccogg, Bruce liked this post
  5. #728
    That seems like a like of drilling... kind of boring if you pardon the pun.... my plan is to use the guide bar to clamp to, and avoid drilling all the holes.
    Cut 50 Plasma
  6. Likes ccogg, Bruce liked this post
  7. #729
    I got tired of moving a small (2x2’) 3/4” plate I had around and decided to make a small welding table.
    I’ll just post pics as I go along. No plans as usual. Just winging it.
    Got a bit of a start on it yesterday. Cleaned up a section of heavy wall 6” pipe for the pedestal..
    Cleaned up the plate, radiused two corners with the oxy-acetylene and dressed them best I could on the 12” disc grinder. Heavy sucker.
    Here it is upside down on the welding table ..
    Tacked up square (hopefully)
  8. Likes whtbaron, VaughnT, Bruce liked this post
  9. #730
    Dam... you're ahead of me again. The sewer grate thread a while back had me looking at the cast grids that came out from under the sow crates when I dismantled the raised flooring. My oldest grandson is getting into welding at school and is starting to do his own projects at home. We might have to make 2. I know for small projects I really liked clamping things to my post anvil... a little higher than most tables ( I think it's around 39 or 40") and the ability to walk around it as you work is nice for small items. Even with your fancy new table, I think you'll find that a very handy size.
    Cut 50 Plasma
    There is always a need for a small table for exactly the reasons you mentioned. I have had so much use out of the one I built when I was 15. LOL
    I am using this cast iron wheel for the base. Cockshutt Plow Brampton Ontario. I assume it’s a seed packer wheel or?
    I just tapped the holes to accept 5/8” NC bolts and drilled matching holes in a spare sprocket.
  11. Likes SweetMK, Shootr, Bruce liked this post
  12. #732
    That is an odd one. Most of the early Cockshutt grain drills I am familiar with would have used double disc or hoe openers with no packing wheels. Most packing wheels on earlier hoe drills tended to be lighter construction, round spokes with a flat face. That pointed face would be better suited to something directional, but at 24" it's too small for the front wheel of a tractor. I'm thinking something like a harrow cart? Or maybe a front set of wheels on something pulled by horses?
    Cut 50 Plasma
  13. Likes Bruce liked this post
  14. #733
    I'm thinking something like this... but even these are flat faced wheels...
    Cut 50 Plasma
  15. Likes Bruce liked this post
  16. #734
    Hmmm.
    Thought for certain you would know. A friend had it in his stash and gave it to me when he moved. He wasn't sure of if its use and me being a "row crop" guy didn't have a clue.
    Its configuration is similar to packer wheels on our Brillion equipment but way bigger diameter.
  17. #735
    LOL... I'm old, but I'm not THAT old! Horse drawn stuff is a little before my time. I know I pulled some similar wheels off an old piece of my Grandfather's equipment, but I'm not certain what that looked like in it's entirety either. I think it was similar to the photo above but I'm not sure if the dolly was on the front of a plow or a disc. I'll try posting your pic on a farmer's site and see if anyone recognizes it.
    Cut 50 Plasma
    Here's a better pic. 58 pounds. (26kg)
    This is gonna be a heavy sucker ....
  19. Likes Bruce, whtbaron liked this post
  20. #737
    TGIF
    Thankfully god invented forklifts
    See ya on the flip side
    Got a wedgie
    All tacked up
  21. #738
    Feb 2010
    Bandera,TX / MN
    Are you hooking up a drive motor to that sprocket to have a rotary table?
  22. Likes Bruce liked this post
  23. #739
    Quote Originally Posted by arcflash View Post
    I thought about it but ideally the top should be round and it seemed like too much work
  24. #740
    Feb 2010
    Bandera,TX / MN
    You've got time!
  25. Likes Lis2323 liked this post
  26. #741
    I thought you just sold a really good rotating table?
    Cut 50 Plasma
  27. Likes Bruce, Lis2323 liked this post
  28. #742
    oh yeah...
    Some days I want love
    EVERY day I want money
  29. Likes whtbaron liked this post
  30. #743
    Yea... money can't buy me love, but it will rent me a really good time...
    Cut 50 Plasma
  31. Likes Lis2323 liked this post
  32. #744
    Yep! My "welding table" consists of my Ultra Jig from Yesteryear Forge clamped in the bench vise. Only 12x12, but I don't do much of any large pieces and it's really nice to be able to get all the way around the piece.
    I've been thinking about getting one of those drill press tables from Fireball Tool to use as a welding table in the vise. Lots of holes for clamps and a little more surface area than the Ultra Jig, but not much more weight since it's got so many holes through it!
  33. Likes whtbaron liked this post
  34. #745
    I rolled up a tool hanger today. I'll have another look at it in the morning to see if I like it or not.
  35. Likes Shootr, VaughnT, whtbaron, Rondo liked this post
  36. #746
    Arizona
    It has my vote. Nice!
    Yeswelder MIG-205DS
  37. #747
    Thanks Shootr. The “spokes” bug me. They would look better if the were all aligned to the center of the column but then the load bearing area looked too small.
  38. #748
    Oct 2012
    Hood River, OR
    I’m not sure what you mean by “load bearing area”. I agree that the spokes look a bit off. What about just a single spoke in the middle and then the curved holder just cantilevers on both sides?
  39. #749
    That’s a thought....maybe I’ll try making the single middle spoke more substantial and see how it looks
  40. Likes ccogg liked this post
  41. #750
    You worry too much. I'd paint it Lincoln red and call it a day.
    Cut 50 Plasma
  42. Likes VaughnT liked this post
Page generated in 1,624,193,018.07723 seconds with 13 queries
