Page 31 of 31 FirstFirst ... 21293031
Results 751 to 775 of 775
Thread: Welding table picture thread
  1. #751
    Mar 2021
    Near Roanoke, VA
    Re: Welding table picture thread
    Thanks Shootr. The “spokes” bug me. They would look better if the were all aligned to the center of the column but then the load bearing area looked too small.
    It will look better when he runs the chain between the 4 sprockets,, then motorizes it,,
  2. Likes arcflash liked this post
  3. #752
    This what you talking about?
  4. Likes SweetMK, Bruce liked this post
  5. #753
    Holes for the table today. Twelve 5/8"D on 6" centers and one square hole for 2" receiver material
  6. Likes whtbaron, Shootr, VaughnT, Bruce liked this post
  7. #754
    You worry too much. I'd paint it Lincoln red and call it a day.
    2nd thought.... that candy purple to match your new table...I do like the upright receiver though...Ohhh.... I like that file handle too... nice work!
    Cut 50 Plasma
  8. Likes VaughnT liked this post
  9. #755
    Between my farmer buddies and me, I think we found a match for your spoked wheel. It's a gauge wheel from a horse drawn Cockshutt plow (somebody improved the colors on this one...) ... it is an old one.
    Cut 50 Plasma
    Good sleuthing. Maybe a gauge wheel for a big one way disc ?
    Maybe some regions call them a disc plow. Anyhow an offset disc with only one gang.
  11. #757
    Discs would have been later... by the time you started adding more horsepower and tillage, the wheel designs started changing to compensate for the higher demands. That's what threw me off with yours... the center reminds me of a large auger pulley more than a wheel. A lot of the later wheels would have heavier rims, weights added and often a solid center rather than spokes, or more round spokes. I know the spokes on that one aren't an exact match, but I think it's a later version of a very similar machine rather than a heavier machine.
    http://www.cockshutt.com/history.html
    Cut 50 Plasma
    However... I have been wrong before...this one also looks very close but it was a Chattanooga plow manufactured in the US, unless Cockshutt made a similar version up here. The Chattanooga was bought out by IHC. Apparently you could flip from one disc to the other for going back and forth on the field.
    Cut 50 Plasma
  13. Likes Bruce liked this post
  14. #759
    This is what I was talking about with the heavier wheels on the later machines....
    Cut 50 Plasma
  15. Likes Bruce liked this post
  16. #760
    Those wheels look similar in type. I think you are right. The ridged wheel was designed to be directional.
    I kept looking at it as a clod buster or (oversized) press wheel
    for a seed drill
  17. Likes whtbaron liked this post
  18. #761
    Still... I think it puts you back into the late 1800's, early 1900's.... interesting piece of history in your new table...
    Cut 50 Plasma
    I cut up a piece of 1/2" plate for a shelf ...
    Rolled up some 1/4"x2" flat bar for the edge
  20. Likes VaughnT, Bruce, psacustomcreations liked this post
  21. #763
    Shelf tacked in place....
  22. #764
    You sure do some sexy work!
  23. Likes Bruce liked this post
  24. #765
    Feb 2010
    Bandera,TX / MN
    With all those sprockets on there you should be able to do 5 axis hammering!
  25. #766
    Thank you, V!
  26. #767
    Come on over and you can show me how it’s done!
  27. Likes N2 Welding liked this post
  28. #768
    May 2004
    Richmond/Midlothian,VA
    That is one wicked table.
    Bruce
    The Welding Chef
    Lincoln Weld-Pack 3200
    NORWELD Stick
    Stanford Hill Farm
  29. Likes Lis2323 liked this post
  30. #769
    Welded in the 2” vertical receiver stub...
  31. Likes whtbaron, VaughnT, Bruce liked this post
  32. #770
    Done welding ...
    I can stand on the shelf so it should be fine
  33. #771
    250 pounds.
    Not as heavy as I thought.
  34. Likes Bruce liked this post
  35. #772
    Officially DONE
  36. Likes whtbaron, Bruce, VaughnT, Shootr, Tool Junkie liked this post
  37. #773
    250 is no slouch... with that wide base that will be good and sturdy. Looks right at home.
    Cut 50 Plasma
    Is this a car... or is it really a mobile fixture table??
    Cut 50 Plasma
    Haha. For complex curves.
  40. Likes whtbaron liked this post
Page generated in 1,624,548,517.05408 seconds with 14 queries
