Page 36 of 41 FirstFirst ... 263435363738 ... LastLast
Results 876 to 900 of 1009
Thread: Welding table picture thread
  1. #876
    Re: Welding table picture thread
    I think you are a very good painter….. yo yo yo.
    I'm glad you appreciate the shades of blue. I didn't even use an airbrush.
    *nor would I know how to use one.
  2. #877
    I picked up a nice airbrush at auction once for $5. Auctioneer's assistant held it up and said he thought it was some kind of dental equipment. He didn't know what it was. Worked out well for me.
    I noticed your teeth appeared whiter. Wasn’t gonna mention it…
  4. Likes whtbaron, arcflash, BD1 liked this post
  5. #879
    Oct 2012
    Hood River, OR
    I’ve been doing most of my welding on the floor or using a 2’x2’ scrap of 1/4in plate on a black and decker folding table. But it’s time for an upgrade! I just brought home a 40”x96” piece of 1” plate. (It was free, but I had to cut it down from an 18ft piece with a Milwaukee cold saw - didn’t go super well.) I got to try out the new SSQA on my tractor with a set of forks and was impressed - huge improvement in ease and capacity over the old bucket forks:
    Most of the materials are surplus/leftovers. Here’s the plan:
    I was planning to use some 6in formed angle that I have under the table to stiffen it, but it turns out they aren’t super straight. Probably overkill anyway. (If there is such a thing!) This version uses some very straight 2.5x0.5 cold rolled bar I have that seems a little light, but the price is right, it’s only a 6ft span and I hope it’s enough to help with any potential sag. Thoughts?
  6. #880
    Looks portable too.
    Quote Originally Posted by ccogg View Post
  7. Likes NotaVegetarian liked this post
  8. #881
    Sep 2012
    Upstate NY
    If worried about sag why not build an adjustable truss rod or 2?
    Bolting the top to the table is always less risk of warping than welding it, even with minimal but enough welding.
  9. #882
    Outside of Raleigh, NC
    My brother has a welding table around that size. His has 3” channel at the top and bottom, but nothing in between. It’s a nice setup.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
  10. Likes Lis2323 liked this post
  11. #883
    Oct 2012
    Hood River, OR
    3in channel running right under the plate, where I drew the 0.5x2.5 bar? And at the bottom, where my lower shelf is? I debated one shelf vs two. I’ll probably throw scraps/cutoffs on the lower one and clamps/grinders(?) on the upper. But I debated only doing one. I have a 5ft wide piece of flattened expanded that is big enough for two so that was the deciding factor so far. I think I have some 3in channel leftover from trailer ramps so I’ll think about that under the top instead of the bar - might be a little stiffer.
    Thanks for all the suggestions so far…
  12. #884
    How about a partial intermediate height shelf...
  13. Likes NotaVegetarian, whtbaron liked this post
  14. #885
    Oct 2012
    Hood River, OR
    I’ll keep that in mind, but my collection of cool stuff is significantly more limited than yours…
  15. Likes Shootr liked this post
  16. #886
    Fredericksburg, VA
    I have a 3/4" by 48x96 table. There is no sag in it. The only reason it is not straight is the previous owners were beating on it. I have about the same spacing for legs you have except for the diagonals you see in the pic attached The legs on mine are made from 2x4 channel doubled up.
    In my opinion, a 1" top is not going to sag by itself with just the four legs in that span. But that also depends upon what you are placing upon it. Heavy machinery, sure. Typical shop welding you see on here, I doubt it.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  17. Likes whtbaron liked this post
  18. #887
    Agreed. I've put over 2000 pounds (on a pallet so under 16 sq ft footprint )on a 3/4" 8'x4' table with NO bracing.
    1" would be a non issue.
  19. Likes whtbaron, Shootr liked this post
  20. #888
    Oct 2012
    Hood River, OR
    That’s good to know. I won’t sweat it until a problem arises. Nothing on my little kubota is heavy enough for the table to even notice and I can’t afford to build anything that would weigh enough to be a problem!
  21. #889
    I was thinking along the same lines... one inch material is pretty strong so basically anything under it for support in the center should make it bullet proof. I have mixed feelings about the dual shelves. I have 2 under one side of mine, and they both get used, but it makes it more awkward to get things in and out. You're going to be getting down on your knees for that bottom shelf, so your age may help determine how often you want to be down there. If I was going to do it again, it might just be a single shelf slightly below knee height.
    May 2021
    Landrum, SC
    As Lis has said 1" will be a non issue. When this 3" slab was well over 3500lbs it has been in the center of this table with out an issue. Plus another 500 - 1000lbs of crap along with the plate. Granted it uses wore out 1" curved screens as legs.
    Lincoln 330MPX
    Lincoln Power Mig 256
    Lincoln LN-25X Wire Feeder
    Lincoln AC/DC 225
    ¼ Ton of Torches OFC-A/OFG-A
    Air Carbon Arc Gouging
    CAC-A
    Lincoln Tomahawk 1000
    Ingersoll Rand T-30-14hp-25cfm
    Instagram: #Freebird Welds
  23. Likes VaughnT liked this post
  24. #891
    Fredericksburg, VA
    One advantage to not having shelves under the table is welder storage.
    I roll my Miller 252 under the table when not in use.
    Millermatic 252 MIG
  25. Likes Lis2323 liked this post
  26. #892
    Arizona
    Quote Originally Posted by Freebirdwelds View Post
    Now that is a bitchin' piece of art! Probably need a wall like the containment vessel of a nuclear power plant to hang it on, but those things need a little sprucing up anyways.
    Yeswelder MIG-205DS
  27. Likes whtbaron liked this post
  28. #893
    May 2021
    Landrum, SC
    Coincidently right now it is almost shaped like the state of South Carolina. But man that hunk still weighs well over a ton. lol
    Lincoln 330MPX
    Lincoln AC/DC 225
    CAC-A
  29. Likes Shootr liked this post
  30. #894
    The kid manning your hacksaw is gonna have some arms on him...
  31. Likes Freebirdwelds, Shootr liked this post
  32. #895
    May 2021
    Landrum, SC
    Lincoln 330MPX
    Lincoln AC/DC 225
    CAC-A
  33. Likes Shootr liked this post
  34. #896
    This welding table is off to its new home today. A fence and gate building business purchased it.
  35. Likes whtbaron, Freebirdwelds, scsmith42, Shootr liked this post
  36. #897
    So if I buy the rough ones off my Craig's list for a grand, can I still turn a healthy profit on the resale with improvements?? We were talking about the potential for that style sagging in the center... it seems to me tying the legs together close to the bottom would add strength as well and wouldn't require as much steel as a built frame.
    As well as creating a shelf support.
    And yeah I picked up about $1400 after allowing for a few improvements and trucking.
  38. Likes whtbaron liked this post
  39. #899
    I bought this last night for a new welding table build. It’s quite a distance away so I will need to get it shipped to my friends warehouse in Vancouver and worry about getting it home later.
    It weighs about 800 pounds and is in a residential area with no forklifts around.
    Pics:
    Fully raised height 45”
    9” lowered
    110V hydraulic power pack
    36” x 48” table top. 4000# capacity
    I will probably make removable work surfaces including a 48”x60” welding table top (or?)
    Just more stuff to think about..
  40. Likes whtbaron, VaughnT, Munkul liked this post
  41. #900
    Looks like a well built unit... think you'll need something to keep the sparks/grinding dust away from the hydraulic rods/seals?
Page generated in 1,713,243,748.04383 seconds with 20 queries
